N286-01GTX
N286-01GTX
    TRIPPLITE
    TXRXSFP1GBPSRJ45
N286-01GTX 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cisco-Compatible GLC-T SFP Mini Transceiver, 1000Base-TX Copper RJ45, Cat5e, Cat6, 328.08 ft. (100 m) MODEL NUMBER: N286-01GTX Highlights ● Supports data transfer rates up to 1 Gbps ● Auto-sensing RJ45 port with Auto MDI/MDI-X support ● Transmits up to 328.08-ft. (100 m) with RJ45 cabling ● Low EMI and power dissipation ● Supports up to 1.25 Gbps bidirection communication System Requirements For a list of compatible switches, see the Switch Compatibility document in the Resources tab or the Technical Support page. Package Includes Adds a copper Gigabit Ethernet RJ45 connector to your 10/100/1000 network equipment. Complies with MSA (Multi-Sourcing Agreement) standards. 100% compatible with Cisco networking hardware. Description The N286-01GTX Cisco GLC-T Compatible 1000Base-TX Copper RJ45 SFP Mini Transceiver with an RJ45 Ethernet connector functions just like the Cisco® GLC-T transceiver module and is designed to operate with Cisco networking equipment. It also meets or exceeds the GLC-T's original specifications and complies with MSA standards. This 1000Base-TX copper transceiver is fully hot-pluggable, so you can install it without shutting down the network or rebooting your device. It supports data transfer rates up to 1 Gbps with auto-negotiation up to 328.08-ft. (100 m) and automatic MDI/MDI-X crossover support. Its metallic housing allows low EMI and power dissipation. It supports up to 1.25 Gbps bi-directional communication. Features 1000Base-TX Copper Transceiver with RJ45 Connector ● Hot-pluggable for installation without rebooting or shutting down ● Data transfer rates up to 1 Gbps ● Transmits up to 328.08-ft. (100 m) with RJ45 cabling ● 10/100/1000 auto-sensing RJ45 port with auto MDI/MDI-X support ● Metallic housing for low EMI and power dissipation ● Supports up to 1.25 Gbps bi-directional communication Designed for Use with Cisco Networking Equipment ● Functionally equivalent to Cisco GLC-T ● Meets or exceeds GLC-T specs ● Complies with MSA standards Specifications 1/3 ● N286-01GTX Cisco GLC-T Compatible 1000Base-TX Copper RJ45 SFP Mini Transceiver ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332197412 Brand Compatibility Cisco PHYSICAL Shipping Dimensions (hwd / in.) 1.10 x 2.20 x 4.80 Shipping Dimensions (hwd / cm) 2.79 x 5.59 x 12.19 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 0,84 x 1,32 x 5,69 Unit Weight (lbs.) 0.05 Unit Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range 32 to 158 °F (0 to 70 °C) Storage Temperature Range -40 to 185 F (-40 to 85 C) Relative Humidity 10 to 85% RH, Non-Condensing Operating Temperature 32 to 158 °F (0 to 70 °C) COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) Transmission Distance 100 m CONNECTIONS Side A - Connector 1 SFP+ (MALE) Side B - Connector 1 RJ45 (FEMALE) FEATURES & SPECIFICATIONS Data Transfer Rate 1 Gbps Multi-Source Agreement (MSA) Compliant Yes WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N286-01GTX 价格&库存
很抱歉,暂时无法提供与“N286-01GTX”相匹配的价格&库存,您可以联系我们找货
