317
    ADAFRUIT
    POCKETINVERTERELWIRE2-AA
317 数据手册
EL wire 2xAA pocket inverter PRODUCT ID: 317    Description A small, portable inverter for EL wire. Powers off of 2 AA batteries (not included!), it can drive 1 to 8 feet (about 2.5m) of our high-brightness EL wire for 10 hours. There is a button for selecting steady/blink/off modes. There's a removable clip on the back. Comes with a 2.5mm pitch female JST connector To connect a piece EL wire to this, you'll want a male connector wire The EL inverter requires a 'load' to stabilize itself. Do not run the inverter without at least 1 ft of EL wire attached! Otherwise the inverter can spike and damage itself Like all inverters we've used, the 2000 Hz oscillation is slightly audible. To reduce the squeaking, we suggest opening up the case padding it with thick foam tape/weatherstripping. Squirting some hot glue around the capacitors may also help. We managed to get it silent this way.  Technical Details Dimensions: o o Size: 101mm x 31mm x 19mm (4in x 1.25in x 0.75in) Weight (without batteries): 34g (1.2oz)        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“317”相匹配的价格&库存,您可以联系我们找货
    • 1+65.61405
