COM-12933
COM-12933
    SPARKFUNELECTRONICS
    EL INVERTER - 3V (CHASING)
COM-12933 数据手册
 EL Inverter - 3v (Chasing) COM -1 2933 RO HS       1  images are CC BY-NC-SA 3.0 Description: EL Inverters, if you are wanting to do anything with EL lighting you need one, period. This 3V EL Inverter is a special type that is intended to be used with a “chasing” EL wire. Unlike typical EL wires which only require a 2-pin connection, Chasing EL wire types require a 4-pin connection three for the cascading or “chasing” effect and one for common ground. Using this chasing inverter is as simple as it is to opperate its non-chasing cousin. Simply insert two AA batteries for power, plug in your Chasing EL Wire, and press the button to turn it on and select three different lighting effects (Slow Chase, Fast Chase, and Super-Duper Fast Chase). It is recommended that these inverters only run up to 5M of EL wire, you may not have enough power to support longer lengths. Each inverter is also equipped with a small belt clip making it easier to incorporate into mobile or e-textile projects. Dimensions: • Body - 3.5" x 1.3" x 1" • Cable - 4.5" L https://www.sparkfun.com/products/12933 11/24/2015
COM-12933 价格&库存
很抱歉,暂时无法提供与“COM-12933”相匹配的价格&库存,您可以联系我们找货
