1655
    ADAFRUIT
    LED_5X5MM_SM
    LED照明灯 LED_5X5MM_SM Red,Green,Blue -40℃~+85℃ 4Pin
1655 数据手册
LED COLOR SK6812 Technical Data Sheet Product Overview SK6812 is a set of smart control circuit and a light emitting circuit in one of the controlled LED source. The outer type is the same with a 5050LED chip, each element is a pixel. Pixels contained within the intelligent digital interface data latch signal shaping amplification circuit, power supply circuit, a built-in constant current circuit, high precision RC oscillator, the output is driven by the patented PWM technology, effectively guarantee the pixels in the color of the light high consistency. Data protocol using unipolar NRZ communication mode, the pixel is reset after the end of DIN, accept the data transmitted from the controller to the 24bit, the first to send data by the first pixel to pixel extraction, internal data latch, the remaining data after the internal plastic the processing circuit after shaping amplification through the DO port output began to turn to the next cascade of pixels, each pixel through a transmission signal, reduce. Pixel using automatic shaping forwarding technology, makes the number of cascade without signal transmission limit of the pixel, only limited signal transmission speed. The LED has a low driving voltage, environmental protection and energy saving, high brightness, scattering angle, good consistency, low power, long life and so on. The control circuit is integrated in the LED above, more simple circuit, small volume, easy installation. Main Application Field: ● Full color LED string light, LED full color module, LED super hard and soft lights, LED guardrail tube, LED appearance / scene lighting ● LED point light, LED pixel screen, LED shaped screen, a variety of electronic products, electrical equipment etc.. 1/7 Document No.: SPC / SK6812 Rev. No.: 01 www.szledcolor.com LED COLOR SK6812 Technical Data Sheet Description: ● Top SMD internal integrated high quality external control line serial cascade constant current IC; ● control circuit and the RGB chip in SMD 5050 components, to form a complete control of pixel, color mixing uniformity and consistency; ●built-in data shaping circuit, a pixel signal is received after wave shaping and output waveform distortion will not guarantee a line; ●The built-in power on reset and reset circuit, the power does not work; ●gray level adjusting circuit (256 level gray scale adjustable); ● red drive special treatment, color balance; ● line data transmission; ● plastic forward strengthening technology, the transmission distance between two points over 10M; ●data transmission frequency up to 800Kbps, when the refresh rate of 30 frames per second, a cascade of not less than 1024; ● built-in powerpolarity protection module, powerpolarity will not damage. Mechanical Product Size (unit mm): 2/7 Document No.: SPC / SK6812 Rev. No.: 01 www.szledcolor.com LED COLOR SK6812 Technical Data Sheet Mechanical Size and Pin Map (unit mm): Pin Function: Item Symbol Pin Name Function description 1 VSS Ground The signal and power supply and grounding 2 DIN Data Input control signal input data 3 VDD Power power supply pin 4 DOUT Data Output control signal output data The electrical parameters (limit parameters, Ta=25 C, VSS=0V): Parameter Symbol Input voltage VIN Logic input voltage VI -0.5~VDD+5.5 V Working temperature Topt -40~+85 ℃ Storage temperature Tstg -50~+150 ℃ EST pressure VESD 4K V 3/7 Range V +5 Document No.: SPC / SK6812 Unit Rev. No.: 01 www.szledcolor.com LED COLOR SK6812 Technical Data Sheet The electrical parameters (such as no special instructions, TA=20 ~ +70 ~ 5.5V C, VDD=4.5, VSS=0V): Parmeter Symbol Min Typic al The chip supply voltage VDD --- 5.2 R/G/B port pressure VDS,MA X --- --- IDOH --- Max 26 49 --- Unit Test conditions V --- V --- mA DOUT conect ground, the maximum drive current mA DOUT conect +, the largest current DOUT drive capability IDOL --- -50 --- VIH --- 3.4 --- VIL --- 1.6 --- The frequency of PWM FPWM --- 1.2 --- KHZ --- Static power consumption IDD --- 1 --- mA --- The signal input flip threshold VDD=5.0V The dynamic parameters (Ta=25 C): Parameter Symb ol Min Typic al Max Unit Test conditions The speed of data transmission fDIN --- 800 --- KHZ The duty ratio of 67% (data 1) TPLZ --- --- 500 ns TPLZ --- --- 500 ns DOUT transmission delay 4/7 Document No.: SPC / SK6812 DIN→DOUT Rev. No.: 01 www.szledcolor.com LED COLOR SK6812 Technical Data Sheet RGB chip characteristic parameters: Color Wavelength(nm) Luminous intensity(mcd) Working voltage(v) Red 620-625 700-1000 2.0-2.2 Green 522.5-525 1500-2200 3.0-3.3 Blue 467.5-470 700-1000 3.0-3.3 The data transmission time (TH+TL=1.25µs±600ns): T0H 0 code, high level time 0.3µs ±0.15µs T1H 1 code, high level time 0.6µs ±0.15µs T0L 0 code, low level time 0.9µs ±0.15µs 0.6µs ±0.15µs T1L Trst 5/7 1 code, low level time Reset code,low level time 80µs Document No.: SPC / SK6812 Rev. No.: 01 www.szledcolor.com LED COLOR SK6812 Technical Data Sheet Timing waveform: Input code: Connection mode: D1 DIN DO D2 DIN DO PIX1 D3 PIX2 D4 DIN DO PIX3 The method of data transmission: reset code >=50us Data refresh cycle 1 first 2 4 b it D1 seco n d 2 4 b it seco n d 2 4 b it D2 reset code Data refresh cycle 2 th ird 2 4 b it first 2 4 b it th ird 2 4 b it seco n d 2 4 b it th ird 2 4 b it seco n d 2 4 b it th ird 2 4 b it th ird 2 4 b it D3 th ird 2 4 b it D4 Note: the D1 sends data for MCU, D2, D3, D4 for data forwarding automatic shaping cascade circuit. The data structure of 24bit: G7 G6 G5 G4 G3 G2 G1 G0 R7 R6 R5 R4 R3 B2 B1 B0 R2 R1 R0 B7 B6 B5 B4 B3 Note: high starting, in order to send data (G7 - G6 - ...... ..B0) 6/7 Document No.: SPC / SK6812 Rev. No.: 01 www.szledcolor.com LED COLOR SK6812 Technical Data Sheet The typical application circuit: 7/7 Document No.: SPC / SK6812 Rev. No.: 01 www.szledcolor.com
很抱歉,暂时无法提供与“1655”相匹配的价格&库存,您可以联系我们找货
    • 1+48.08134
      • 1+48.08134
      • 1+4.81649
      • 10+4.63899
      • 100+4.21299
      • 500+3.99999
      库存:4630
      1655
        • 1+46.757251+5.66672
        • 1+37.783601+4.58300
