NeoPixel 1/4 60 Ring - WS2812 5050 RGB LED w/ Integrated Drivers ID: 1768
DESCRIPTION
Page 1 of 2
Page 2 of 2
The biggest NeoPixel Ring yet! With four of these you can make a huge ring with 60
ultra bright smart LED NeoPixels are arranged in a circle with a 6.2" diameter. Each
order comes with just the quarter ring. Four of this item are required to make a
large ring. You will have to solder them together as well, so for the full ring of 60
LEDs, buy four and solder them together!
The rings are 'chainable' - connect the output pin of one to the input pin of
another. Use only one microcontroller pin to control as many as you can chain
together! Each LED is addressable as the driver chip is inside the LED. Each one has
~18mA constant current drive so the color will be very consistent even if the
voltage varies, and no external choke resistors are required making the design
slim. Power the whole thing with 5VDC and you're ready to rock.
There is a single data line with a very timing-specific protocol. Since the protocol is
very sensitive to timing, it requires a real-time microcontroller such as an AVR,
Arduino, PIC, mbed, etc. It cannot be used with a Linux-based microcomputer or
interpreted microcontroller such as the netduino or Basic Stamp. Our wonderfullywritten Neopixel library for Arduino supports these pixels!
(https://github.com/adafruit/Adafruit_NeoPixel) As it requires hand-tuned
assembly it is only for AVR cores but others may have ported this chip driver code
so please google around. An 8MHz or faster processor is required.
Comes with one quarter ring of 15 x individually addressable RGB LEDs assembled
and tested. We recommend you buy four to build the full circle as this is just the
1/4 of the circle.
http://www.adafruit.com/products/1768
2/23/2015
很抱歉,暂时无法提供与“1768”相匹配的价格&库存,您可以联系我们找货
