Flexible 16x16 NeoPixel RGB LED Matrix
PRODUCT ID: 2547
DescriptionFor advanced NeoPixel fans, we now have a bendable, Flexible 16x16 NeoPixel LED Matrix! Control all
256 ultra-bright LEDs using a single microcontroller pin, set each LED as you wish to scroll messages or
draw little images. This matrix has a thick flexible PCB backing that can be gently bent and curved
around surfaces
You can use this matrix just like any other NeoPixel-compatible product.
Don't forget, with 256 LEDs, you could use over 15A of current if you turn on all the LEDs on to white
(which we really do not recommend because we don't think the flex PCB can handle that much
current). Try to keep the current draw at undrer 5A, you can use our 5V 4A or 5V 10A power supply. For
portable use, if you are drawing less than 3A, try out this 5V@3A UBEC .
We also have a flexible NeoPixel Matrix in 8x32 if you love that 4:1 aspect ratio.
Please note: Flexible PCBs are not designed for repeated flexing! While we think this product may work
in wearables or other situations where the matrix is bent around, we do not offer any guarantees or
refunds if you end up cracking the LEDs or traces! This is for advanced users only, who already know
how to use NeoPixels and are comfortable with the high current requirements and protecting the
matrix from damage. There are no returns, refunds or replacements for damaged product.
Don't forget to read our NeoPixel Uber guide for more information on how to care and feed your
NeoPixels!
Technical Details
o
o
o
o
o
160mm x 160mm x 2mm / 6.3" x 6.3" x 0.08"
Weight (with IDC cables): 46g
WS2812 Datasheet
SK6812 Datasheet
May ship with either WS2812B or SK6812-based LEDs. They are the same brightness,
color and protocol
https://www.adafruit.com/product/2547 1-8-18
很抱歉,暂时无法提供与“2547”相匹配的价格&库存,您可以联系我们找货
