LPD6803 datasheet
General Description:
LPD6803 is a 3 channel constant-current driver and grey-level modulate output , it uses advanced
high-voltage CMOS technology, provide 3-way, designed to meet the needs of driving function
in the LED lighting system, especially in the dissociation with mutual grey level in the full-colour
lighting system..
LPD6803 includes serial shift register and concatenation driver circuit, grey level data shift
into serial shift register in the clock, and transfer saving , it transfer to interface 3 after
pulse-width modulate ,then output, serial shift register and grey-level counter can be
controlled by different clock signal. In the meantime, LPD6803 driver data signal and
control signal , and output next circuit.
Features:
◇ 3channel driver output, maxim current per channel is 45mA, LED light voltage can
reach 12V.
◇ Output adopt In-Rush online feedback contant-current driver structure, compatible with
constant-voltage module, it also can contact outside equipment and transfer to higher voltage
or current output driver.
◇ Built-In LDO voltage-stabilizing circuit, voltage range is 3-8v, and have 5V stabilizing
voltage output.
◇ Adopt self-add token-ring technology dual shift line, shift clock can reah 24MHz.
◇ Directly input grey-level data, it is transfer to 256 output with reverse-gamma
regulator after inside SUPER-PWM technology, e.g, adopt built-in oscialator as greylevel clock, it support FREE-RUN module output, especially can be used in low-cost
controller.
◇ Data clock signal is drived strongly to next chip to enhance level after built-in phaselock circuit.
◇ High-voltage CMOS technology, industrial design, with extra-good interference
immunity
◇ With SOP16/QFN16 Pb-Free package, meet the requirement of Rohs , also can provide COB
package or DIE.
Footprint:
1
LPD6803 datasheet
LPD6803
Foot
footprint function description
description::
Name
1 DIN
2 GMODE
3 OMODE
13 CMODE
4 DCLK
5,7,11 OUT1,OUT2,OUT3
6,8,10 FB1,FB2,FB3
15 DOUT
12 DCLK0
16 VCC
14 VOUT
9 GND
Function
Serial data input, built-in voltage pullup
Grey-level regulate mode: GMODE=1,adapt
line modulate,GMODE=0,adapt re-Gama 256
grade non-line regulate,built-in voltage
pull-up
Control output polarity: OMODE=1, output
is in-constant current/voltage drive
mode,CMODE=0, output is out drive
mode,voltage built-in pull-up
choose inside grey clock GCLK, CMODE=0,
GCLK=DCLK, CMODE=1, GCLK= inside
oscillator output, built-in pull-up
Serial data clock input, built-in pull-up
3-way driver output
Feedback input in constant current state
Serial data output, after inside strongly
drive
Serial clock output, after inside pll and
strongly drive
LDO power, range is 4.5v---8v
when VCC>5V, 5V stable voltage output,
when VCC10
THOLD
>5
PD
Inside
4
Range Unit
