Industrial Co., Ltd.
LCM MODULE
TC1602A-09T
Specification for Approval
APPROVED BY
CHECKED BY
I SSUED: V00 2009- 06- 04
PDF 文件使用 "pdf Fact or y Pr o" 试用版本创建 ÿwww. f i nepr i nt . cn
PREPARED BY
TC1602A-09T
CONTENTS
FUNCTIONS & FEATURES ---------------------------------------------------------------------------------------------------------- 3
BLOCK DIAGRAM ---------------------------------------------------------------------------------------------------------------------- 3
MODULE OUTLINE DRAWING ----------------------------------------------------------------------------------------------------- 4
INTERFACE PIN FUNCTIONS ------------------------------------------------------------------------------------------------------ 5
ABSOLUTE MAXIMUM RATINGS (Ta = 25℃) ---------------------------------------------------------------------------------- 5
DC ELECTRICAL CHARACTERISTICS ------------------------------------------------------------------------------------------ 5
LED BACKLIGHT CHARACTERISTICS ------------------------------------------------------------------------------------------ 5
CONNECTION WITH MCU------------------------------------------------------------------------------------------------------------ 6
Typical V0 connections for display contrast ------------------------------------------------------------------------------------ 6
MPU Interface 4-Bit/8-Bit ----------------------------------------------------------------------------------------------------------- 6
AC CHARACTERISTICS ------------------------------------------------------------------------------------------------------------- 7
OPTICAL CHARACTERISTICS ----------------------------------------------------------------------------------------------------- 9
COMMAND TABLE ------------------------------------------------------------------------------------------------------------------- 10
RESET FUNCTIONS ------------------------------------------------------------------------------------------------------------------ 12
DISPLAY DATA RAM (DDRAM) --------------------------------------------------------------------------------------------------- 14
CHARACTER GENERATOR ROM ----------------------------------------------------------------------------------------------- 15
RELIABILITY TEST CONDITION --------------------------------------------------------------------------------------------------16
PRECAUTION FOR USING LCM MODULE ------------------------------------------------------------------------------------17
OTHERS ----------------------------------------------------------------------------------------------------------------------------------18
APPENDIX A: DATE CODE RULES ----------------------------------------------------------------------------------------------18
APPENDIX B: CHANGE NOTES -------------------------------------------------------------------------------------------------18
Ver.V00 2009-06-04
-2-
PDF 文件使用 "pdf Fact or y Pr o" 试用版本创建 Àwww. f i nepr i nt . cn
www.tinsharp.com
TC1602A-09T
Construction
: COB(Chip-on-Board)
Display Format
: 16x2
Characters
Display Type
: STN, Transmissive, Negative, Blue
Controller
: SPLC780D1 or equivalent controller
Interface
: 4-bit\8-bit parallel interface
Backlight
: white\side lights
Viewing Direction : 6 O
’clock
Driving Scheme : 1/16 Duty Cycle, 1/5 Bias
Power Supply Voltage : 5.0 V
VLCD Adjustable For Best Contrast : 5.0 V (V
OP.)
Operation temperature : -10
℃ to +60 ℃
Storage temperature : -20
℃ to +70 ℃
BLOCK DIAGRAM
VSS
VDD
V0
RS
CONTROL IC
R/W
E
SPLC780D1
DB0~DB7
Or equivalent
LCD PANEL
DRIVING IC
LED+
LED-
Ver.V00 2009-06-04
BACKLIGHT
BACKLIGHT
-3-
www.tinsharp.com
TC1602A-09T
Pin
No.
1
2
3
Symbol Level
Description
VSS
VDD
V0
0V
+5.0V
4
RS
H/L
5
R/W
H/L
6
7
8
9
10
11
12
13
14
15
16
E
DB0
DB1
DB2
DB3
DB4
DB5
DB6
DB7
LED+
LED-
H/L
H/L
H/L
H/L
H/L
H/L
H/L
H/L
H/L
+5.0V
0V
Ground.
Power supply for logic operating.
Adjusting supply voltage for LCD driving.
A signal for selecting registers:
1: Data Register (for read and write)
0: Instruction Register (for write), Busy flag-Address Counter (for read).
R/W = “H”: Read mode.
R/W = “L”: Write mode.
An enable signal for writing or reading data.
This is an 8-bit bi-directional data bus.
Power supply for backlight.
The backlight ground.
ABSOLUTE MAXIMUM RATINGS ( Ta = 25℃ )
Parameter
Symbol
Min
Max
Unit
Supply voltage for logic
VDD
-0.3
+7.0
V
Supply voltage for LCD
Vo
VDD +0.3
V
Input voltage
VI
-0.3
VDD +0.3
V
Normal Operating temperature
TOP
-20
+70
Normal Storage temperature
TST
-30
+80
Note: Stresses beyond those given in the Absolute Maximum Rating table may cause operational errors or
damage to the device. For normal operational conditions see AC/DC Electrical Characteristics.
Parameter
Symbol
Condition
Min
Typ
Max
Unit
VDD
4.8
5.0
5.2
V
Supply current for logic
IDD
35
40
mA
4.8
5.0
5.2
V
-10℃
Operating voltage for LCD
VLCD
25℃
+60℃
Input voltage“H”level
VIH
0.7 VDD
VDD+0.3
V
Input voltage “L” level
VIL
0.2VDD
V
COLOR
Wavelength
λp(nm)
Operating
Voltage(±0.15V)
3.2
Spectral line half
width Δλ( nm)
Forward Current
(mA)
30
white
NOTE: Do not connect +5V directly to the backlight terminals. This will ruin the backlight.
Ver.V00 2009-06-04
-5-
PDF 文件使用 "pdf Fact or y Pr o" 试用版本创建 www. f i nepr i nt . cn
www.tinsharp.com
TC1602A-09T
CONNECTION WITH MCU
DB0-DB7
P1
P3.0
P3.1
MCU
P3.2
RS
R/W
E
LCD MODULE
TC1602A-09T
VCC
VDD
VR: 20~50K
V0
VSS
(1) Typical V0 connections for display contrast
Adjust V0 to 0V (VLCD=+5 V) as an initial setting. When the module is operational, readjust V0 for optimal
display appearance.
VDD
VCC
VLCD
VR
20~50K
V0
GND
VSS
We recommend allowing field adjustment of V0 for all designs. The optimal value for V0 will change with
temperature, variations in VDD, and viewing angle. V0 will also vary module-to-module and batch-to-batch due
to normal manufacturing variations.
Ideally, adjustment to V0 should be available to the end user so each user can adjust the display to the optimal
contrast for their required viewing conditions. As a minimum, your design should allow V0 to be adjusted as part
of your product’s final test.
Although a potentiometer is shown as a typical connection, V0 can be driven by your microcontroller, either by
using a DAC or a filtered PWM. Displays that require V0 to be negative may need a level-shifting circuit. Please
do not hesitate to contact Tinsharp application support for design assistance on your application.
(2) MPU Interface 4-bit/8-Bit
There are tow types of data operations: 4-bit and 8-bit operations. Using 4-bit MPU, the interfacing 4-bit data is
transferred by 4-busline (DB4~DB7). Thus, DB0 to DB3 bus lines are not used. Using 4-bit MPU to interface
8-bit data requires tow times transferring. First, the higher 4-bit data is transferred by 4-busline (for 8-bit
operation, DB7~DB4). Secondly, the lower 4-bit data is transferred by 4-busline (for 8-bit operation, DB3 ~
DB0). For 8-bit MPU, the 8-bit data is transferred by 8-busline (DB0~DB7).
Ver.V00 2009-06-04
-6-
www.tinsharp.com
TC1602A-09T
AC CHARACTERISTICS
(1) Write Mode (Writing data from MPU to SPLC780D1)
Write Mode Timing Diagram (Writing data from MPU to SPLC780D1)
(2) Read Mode (Reading data from SPLC780D1 to MPU)
Ver.V00 2009-06-04
-7-
www.tinsharp.com
TC1602A-09T
Read Mode Timing Diagram (Reading data from SPLC780D1 to MCU)
(3) Interface mode with LCD driver (SPLC100B1)
Interface mode with SPLC100B1 Timing Diagram
Ver.V00 2009-06-04
-8-
www.tinsharp.com
TC1602A-09T
ITEM
Contrast ratio
Response time(rise)
Response time(fall)
Viewing angle
SYMBOL
CR
Tr
Td
θf
θb
θl
θr
CONDITION
θ=0,Φ=0
MIN
25℃
25℃
TYP
3
MAX
250
350
UNIT
NOTE
ms
deg.
Note1: Definition Operation Voltage (Vop.)
Note2: Response time
Ver.V00 2009-06-04
-9-
www.tinsharp.com
TC1602A-09T
Note3: Viewing angle
COMMAND TABLE
Ver.V00 2009-06-04
- 10 -
www.tinsharp.com
TC1602A-09T
Ver.V00 2009-06-04
- 11 -
www.tinsharp.com
TC1602A-09T
RESET FUNCTION
At power on, SPLC780D1 starts the internal auto-reset circuit and executes the initial instructions. The initial
procedures are shown as follows:
Ver.V00 2009-06-04
- 12 -
www.tinsharp.com
TC1602A-09T
Ver.V00 2009-06-04
- 13 -
www.tinsharp.com
TC1602A-09T
DISPLAY DATA RAM (DD RAM)
The 80-bit DD RAM is normally used for storing display data. Those DD RAM not used for display data can be
used as general data RAM. Its address is configured in the Address Counter.
Timing Generation Circuit
The timing generating circuit is able to generate timing signals to the internal circuits. In order to prevent the
internal timing interface, the MPU access timing and the RAM access timing are generated independently.
LCD Driver Circuit
Total of 16 commons and 40 segments signal drivers are valid in the LCD driver circuit. When a program specifies
the character fonts and line numbers, the corresponding common signals output drive-waveforms and the others
still output unselected waveforms. The relationships between Display Data RAM Address and LCD′s position
are depicted as follows.
Character Generator ROM (CG ROM)
Using 8-bit character code, the character generator ROM generates 5 x 8 dots or 5 x 10 dots character patterns.
It also can generate 192’s 5 x 8 dots character patterns and 64’s 5 x 10 dots character patterns.
Character Generator RAM (CG RAM)
Users can easily change the character patterns in the character generator RAM through program. It can be
written to 5 x 8 dots, 8-character patterns or 5 x 10 dots for 4-character patterns.
Ver.V00 2009-06-04
- 14 -
www.tinsharp.com
TC1602A-09T
SPLC780D1-001A:
Ver.V00 2009-06-04
- 15 -
www.tinsharp.com
TC1602A-09T
No.
1
2
3
4
5
6
TEST Item
Content of Test
High temperature
storage
Low temperature
storage
Endurance test applying the high storage
temperature for a long time.
Endurance test applying the low storage
Temperature for a long time
Endurance test applying the electric stress
(Voltage & current)and the thermal stress to the
element for a long time
Under low temperature for a long time
Endurance test applying the electric stress(Voltage &
current) and Temperature/
Humidity stress to the element for a long time
High temperature
operation
Low temperature
operation
High
temperature/
Humidity storage
High
temperature/
Humidity
operation
(voltage & current)and temperature/
humidity stress to the element for a long time
Test
Condition
Applicable
Standard
70ºC 96hrs
-20ºC 96hrs
60ºC 96hrs
-10ºC 96hrs
40ºC 90%RH
96hrs
40ºC 90%RH
96hrs
Endurance test applying the low and high temperature
cycle.
-10ºC/60ºC
7
-10ºC →25ºC→60ºC
10 cycle
30min←5min←30min.(1 cycle)
Supply voltage for logic system = 5V. Supply voltage for LCD system = Operating voltage at 25ºC.
Temperature
cycle
Ver.V00 2009-06-04
- 16 -
www.tinsharp.com
TC1602A-09T
Mechanical Test
Vibration test
Endurance test applying the vibration during
transportation and using
Shock test
Constructional and mechanical endurance test
applying the shock during transportation.
Atmospheric
pressure test
Static electricity
test
Endurance test applying the atmospheric pressure
during transportation by air
Endurance test applying the electric stress to the
terminal
10~22Hz→1.5mmp-p
22~500Hz→1.5G
Total 0.5hour
50G half sign wave 11
msede 3 times of each
direction
115mbar
40hrs
VS=800V,RS-1.5KΩ
CS=100pF, 1 t i me
Environmental condition
The inspection should be performed at the 1metre height from the LCD module under 2 pieces of 40W white fluorescent
lamps (Normal temperature 20~25℃ and normal humidity 60±15%RH).
Please remove the protection foil of polarizer before using.
The display panel is made of glass. Do not subject it to a mechanical shock by dropping it from a high place, etc.
If the display panel is damaged and the liquid crystal substance inside it leaks out, do not get any in your mouth. If the
substance come into contact with your skin or clothes promptly wash it off using soap and water.
Do not apply excessive force to the display surface or the adjoining areas since this may cause the color tone to vary.
The polarizer covering the display surface of the LCD module is soft and easily scratched. Handle this polarize
carefully.
To prevent destruction of the elements by static electricity, be careful to maintain an optimum work environment.
-Be sure to ground the body when handling the LCD module.
-Tools required for assembly, such as soldering irons, must be properly grounded.
-To reduce the amount of static electricity generated, do not conduct assembly and other work under dry conditions.
-The LCD module is coated with a film to protect the display surface. Exercise care when peeling off this protective
film since static electricity may be generated.
Storage precautions
When storing the LCD modules, avoid exposure to direct sunlight or to the light of fluorescent lamps.
Keep the modules in bags designed to prevent static electricity charging under low temperature / normal humidity
conditions (avoid high temperature / high humidity and low temperatures below 0 ℃).Whenever possible, the LCD
modules should be stored in the same conditions in which they were shipped from our company.
Ver.V00 2009-06-04
- 17 -
www.tinsharp.com
TC1602A-09T
OTHERS
Liquid crystals solidify at low temperature (below the storage temperature range) leading to defective orientation of
liquid crystal or the generation of air bubbles (black or white). Air bubbles may also be generated if the module is
subjected to a strong shock at a low temperature.
If the LCD modules have been operating for a long time showing the same display patterns may remain on the screen
as ghost images and a slight contrast irregularity may also appear. Abnormal operating status can be resumed to be
normal condition by suspending use for some time. It should be noted that this phenomena does not adversely affect
performance reliability.
To minimize the performance degradation of the LCD modules resulting from caused by static electricity, etc. exercise
care to avoid holding the following sections when handling the modules :
- Exposed area of the printed circuit board
- Terminal electrode sections
A. DATE CODE RULES
A.1. DATE CODE FOR SAMPLE
YP: meaning sample
TC1602A-09T
YP XXXXX
LCM part number
Sample array No.
A.2. DATE CODE FOR PRODUCTION
TC1602A-09T
LCM part number
YY/WW/XXXXXXXX
Production date and Production array
A. TC1602A-09T represents LCM part number
C. YY/WW represents Year, Week
YY
—Year
XXXXXXXX
WW
—Week
—Production array No.
B. Change Notes:
Ver.
V00
Descriptions
Editor
First Issue
Ver.V00 2009-06-04
Date
HXY 2009-06-04
- 18 -
www.tinsharp.com
很抱歉,暂时无法提供与“181”相匹配的价格&库存,您可以联系我们找货
