ELECTRONIC
ASSEMBLY
making things easy
blue line
The Blue Displays
THE NEW LOOK !
Blue displays with white character: „At last an alternative for the yellow/green standard displays“ many
customers are pleased. Of course: a fine display helps selling an equipment. The excellent contrast and
the wide viewing angle make the people convinced immediately.
What’s the secret of these new displays? The base are the built-in super
bright white LED dies. But to result an uniform and bright backlight you do
need a figured out light guide, too. The blue color and the wide viewing
Pinbelegung
angle came from a special polarisor for
Pin
Symbol
Pegel
Beschreibung
the
STN cell.
1
VSS
L
Versorgung 0V, GND
2
VDD
H
Versorgung +5V
Thanks to this high efficienct
3
VEE
Di spl ayspannung 0..0,5V
construction a 2x16 lcd requires
4
RS
H/L
Regi ster Sel ect
5
R/W
H/L
H: Read / L: Wri te
15~60mA
only. Additionally we provide
6
E
H
Enabl e
7
D0
H/L
Datenl ei tung 0 (LSB)
an ultra low power version with 1 LED chip for 2mA, too! Remember:
8
D1
H/L
Datenl ei tung 1
yellow/green
displays do need 100mA and more. Nevertheless
9
D2
H/L
Datenl ei tung 2
10
D3
H/L
Datenl ei tung 3
BlueLine displays are better readable than traditional yellow/green
11
D4
H/L
Datenl ei tung 4
12
D5
H/L
Datenl ei tung 5
displays - except in direct sunlight.
13
D6
H/L
Datenl ei tung 6
14
D7
H/L
Datenl ei tung 7 (MSB)
15
LED +
LED-Versorgung Pl us /Vorwi derstand!
LOW POWER
EA DIP162-DN3LW
The low power consumption save
money for power supply. And because
of the small heat of backlight there are much less problems to solve with
self-heating of device. That is why standard temperature range of 20..+70°C is enough normally. Even life time of white LED chip is limited, these
displays can be used or industrial equipment. If operation around the
char.
char. height outline dim. ordering information
1x16
9,66mm
122x33mm
EA W161B-ENLW
clock is necessary, backlight can be switched off or dimmed easily. You
2x16
5,55mm
80x36mm
EA W162B-N3LW
2x16
5,55mm
84x44mm
EA W162B-NLW
do not need any inverter or interface unit. All displays are absolute
2x16
9,66mm
122x44mm
EA W162B-BNLW
2x20
5,55mm
116x37mm
EA W202B-NLW
compatible with market standard HD44780. Interface is 4- or 8- bit data
2x20
12,7mm
190x54mm
EA E202-CNLW
2x24
5,55mm
118x36mm
EA W242B-NLW
bus. Optional you can have
2x40
5,55mm
182x33mm
EA W402B-NLW
4x16
4,75mm
87x60mm
EA W164B-NLW
all displays with integrated
4x20
4,75mm
98x60mm
EA W204B-NLW
4x40
4,89mm
190x54mm
EA W404B-NLW
RS-232 interface. Also all
128x64 Grafik
93x70mm
EA W128B-6N2LW
160x128 Grafik
129x102mm EA W160-7KHLW
graphic displays do have
240x64 Grafik
180x65mm
EA W240-6KH2LW
240x128 Grafik
144x104mm EA W240-7KHLW
built-in graphic controller
... weitere Displays auf Anfrage
like KS0107, or T6963. We
offer them with and without RS-232 interface. Order your
favorite display now! The whole range of various sizes is
available ex stock usually.
16
LED -
LED-Versorgung Mi nus
NEED MORE INFORMATIONS?
all dimensions in mm
At our web site you’ll find more informations and the complete data sheet: www.lcd-module.de/blueline
Or fax following inquiry:
Company .................................................................................................
Street .......................................................................................................
Postal code / city ....................................................................................
Phone / Fax .............................................................................................
making things easy
Lochhamer Schlag 17
D-82166 Graefelfing
Phone +49- (0)89- 854 1991
Fax +49- (0)89- 8541721
info@lcd-module.de
Printed: April 2005
Printing error reserved.
Your name ..............................................................................................
很抱歉,暂时无法提供与“EAW162B-N3LW”相匹配的价格&库存,您可以联系我们找货
