X/Y Stackable 0.180’’ 4-Digit 5x7 Dot Matrix
Alphanumeric Intelligent Display® Devices with Memory/Decoder/Driver
Lead (Pb) Free Product - RoHS Compliant
Red
SLR2016
Super-red
SLO2016
Green
SLG2016
Yellow
SLY2016
DESCRIPTION
The SLR/SLO/SLG/SLY2016 is a four digit 5 x 7 dot
matrix display module with a built-in CMOS integrated
circuit. This display is X/Y stackable.
The integrated circuit contains memory, a
128 ASCII ROM decoder, multiplexing circuitry and drivers. Data entry is asynchronous. A display system can be
built using any number of SLR/SLO/SLG/SLY2016 since
each digit can be addressed independently and will continue to display the character last stored until replaced by
another.
System interconnection is very straightforward. Two
address bits (A0, A1) are normally connected to the
like-named inputs of all displays in the system.
Data lines are connected to all SLR/SLO/SLG/SLY2016s
directly and in parallel as is the write line (WR). The display will then behave as a write-only memory.
The SLR/SLO/SLG/SLY2016 has several features superior to competitive devices. 100% burn-in processing
insures that the SLR/SLO/SLG/SLY2016 will function in
more stressful assembly and use environments. True
“blanking” allows the designer to dim the display for more
flexibility of display presentation. Finally the CLR clear
function will clear the ASCII character RAM.
The character set consists of 128 special ASCII characters for English, German, Italian, Swedish, Danish, and
Norwegian.
All products are 100% burned-in and tested, then
subjected to out-going AQL’s of 0.25% for brightness
matching, visual alignment and dimensions, 0.065% for
electrical and functional.
2006-01-23
FEATURES
• Very Close Multi-line Spacing, 0.4" Centers
• 4.72 mm (0.180") 5 x 7 Dot Matrix Characters
• 128 Special ASCII Characters for English,
Norwegian Languages
• Wide Viewing Angle: X axis 50° Maximum,
Y Axis ± 75° Maximum
• Fast Access Time, 110 ns at 25°C
• Full Size Display for Stationary Equipment
• Built-in Memory
• Built-in Character Generator
• Built-in Multiplex and LED Drive Circuitry
• Direct Access to Each Digit Independently and Asynchronously
• Clear Function that Clears Character Memory
• True Blanking for Intensity Dimming Applications
• End-stackable, 4-Character Package
• Intensity Coded for Display Uniformity
• Extended Operating Temperature Range:
- 40°C to +85°C
• Superior ESD Immunity
• 100% Burned-in and Tested
• Wave Solderable
• TTL Compatible over Operating Temperature Range
See Appnotes 18, 19, 22, and 23 at www.osram-os.com
for additional information.
1
SLR2016, SLO2016, SLG2016, SLY2016, SCD5584A
Ordering Information
Type
Color of Emission
SLR2016
standard red
SLO2016
super-red
SLG2016
green
SLY2016
yellow
Character Height
mm (inch)
Ordering Code
Q68000A8640
Q68000A8641
4.72 (0.180)
Q68000A8642
Q68000A8643
SLX2016 Z
OSRAM
XXYY
V
EIA Date Code
Luminous
Intensity
Code
Pin 1
Indicator
0.46 (0.018)
2.54 (0.100) 12 pl.
Non cumulative
5.08 (0.200)
Part Number
4.06 (0.160) ±0.51 (0.020)
Dimensions in mm (inch)
3.81 (0.150)
Package Outlines
0.3 (0.012) ±0.05 (0.002)
7.62 (0.300) ±0.51 (0.020)
19.91 (0.784)
2006-01-23
5 (0.197)
3 pl.
4.57 (0.180)
10.16 (0.400) ±0.38 (0.015)
2.54 (0.100)
Tolerance: ±0.25 (0.010)
IDOD5215
2
Maximum Ratings
Parameter
Symbol
Value
Unit
Operating temperature range
Top
– 40 … + 85
°C
Storage temperature range
Tstg
– 40 … + 100
°C
DC Supply Voltage
VCC
-0.5 to + 7.0
V
-0.5 to VCC +0.5
V
260
°C
85
Input Voltage, Respect to GND
(all inputs)
Solder Temperature
1.59 mm (0.063“) below seating plane, t < 5.0 s
TS
Relative Humidity
Optical Characteristics at 25°C
(VCC=5.0 V at 100% brightness level, viewing angle: X axis ± 50°, Y axis ± 75°)
(typ.) λpeak
Spectral Peak Wavelength
Yellow
SLY2016
(min.) IV
(typ.)
50
60
75
60
µcd/LED
660
635
565
585
nm
Notes:
1. Peak luminous intensity values can be calculated by multiplying these vaues by 7.
2. LED to LED intensity matching 1.8:1.0
Top View
14 13 12 11 10 9 8
Digit 3 Digit 2 Digit 1 Digit 0
1 2 3 4 5 6 7
IDPA5119
2006-01-23
3
Unit
Green
SLG2016
Time Averaged Luminous Intensity1)
Values
Super-red
SLO2016
Symbol
Red
SLR2016
Description
Pin Function
Pin Function
Pin
Function
Pin
Function
Pin
Function
Pin
Function
1
WR Write
8
D3 Data
5
D0 Data
12
BL Display Blank
D4 Data
6
D1 Data
13
CLR Clear
7
D2 Data
14
GND
2
A1 Digit Select
9
3
A0 Digit Select
10
D5 Data
4
VCC
11
D6 Data
DC Characteristics at 25°C
Parameters
Min.
Typ.
Max.
Units
Conditions
VCC
4.5
5.0
5.5
V
ICC Blank
2.3
3.0
mA
VCC=5.0 V
ICC (80 dots on)
80
105
mA
VCC=5.0 V
VIL (all inputs)
0.8
V
4.5 V
很抱歉,暂时无法提供与“SLG2016”相匹配的价格&库存,您可以联系我们找货
