Dot Graphic VFD Module
q
q
q
q
q
q
q
GU160X32-800A
160 x 32 Dot Graphic
Operating Temp -40° C to +85° C
Single 5V Supply.
High Brightness Blue Green Display
Selectable Parallel (i80/M68)/Serial Interface
Twin Screen Graphic RAM
16 Level Brightness Control Function
The module includes the Vacuum Fluorescent Display
glass, driver and control ASIC, with integral refresh Graphic
RAM and logic for parallel and synchronous serial
interfaces. The high speed 8 bit parallel interface is 5V
CMOS compatible suitable for connection to a host CPU
bus. Brightness control and power down functions are
provided. A full data sheet is available.
20.17 37.0 45.0
25.1
101.45
35.0
12.42 4.0
1.75
150.5
154.0
133.0
10.8 ± 1mm
1
77.0
PWR (JST-B3B-XH-A)
ELECTRICAL SPECIFICATION
Parameter
Symbol Value
Power Supply Voltage
VCC
5.0VDC +/- 5%
Power Supply Current
ICC
550mADC typ.
Logic High Input
VIH
4.0 VDC min.
Logic Low Input
VIL
1.0VDC max.
Logic High Output
VOH
4.7VDC min.
Logic Low Output
VOL
0.3 VDC max.
Reset Input Voltage
VRH
4.0 VDC min.
Reset Input Voltage
VRL
0.6 VDC max.
BLOCK DIAGRAM
Condition
GND=0V
VCC= 5V
IIH = 2uA
IIL = -600uA
IOH = -300uA
IOL = 300uA
IRH = 5uA
IRL = -600uA
OPTICAL and ENVIRONMENTAL SPECIFICATIONS
Parameter
Value
Display Area (XxY mm)
101.45 x 20.17
Dot Size/Pitch (XxY mm)
0.485 x 0.485/0.635 x 0.635
Luminance
350 cd/m2 Min.
Colour of Illumination
Blue-Green (Filter for colours)
Operating Temperature
-40°C to +85°C
Storage Temperature
-40°C to +85°C
Operating Humidity (non condensing) 20 to 80% RH @ 25°C
C/D
1
1
1
1
1
1
1
1
Dimensions in mm & subject to tolerances.
Mounting holes 3.5mm dia.
IDC (IMSA-9032B-26P)
The power on rise time should be less than 100ms.The inrush current at power on can be 2 x ICC.
SOFTWARE COMMANDS
Instruction
Set Display On/Off / Layer Merge
Set Display Brightness
Clear Display
Set Cursor XY Address
Set Display Start X Address
Set Write Address Mode
Scroll Display Vertically Up/Down
Read Cursor XY Address
Write Data
TIMING PARAMETERS (min)
i80/M68 Parameters
Time
Write /WR/EN Cycle Time
400ns
Write /WR/EN Pulse Width 100ns
Set Up To Write /WR/EN
30ns
Hold after Write /WR/EN
20ns
SCROLLING GRAPHIC DISPLAY
10.0 max
1.6
Instruction Byte
20H-2FH
40H-4FH
52H-5FH
60H-67H
70H-7FH
80H-8FH
B0H-BFH
D4H-D7H
00H-FFH
No. Bytes
2
1
1
3
2
1
1
3
1
Serial Parameters
Time
SCK Cycle Time
200ns
SCK Pulse Width
80ns
Set Up To SCK, /CSS=’L’
40ns
Delay After 8th bit, /CSS=’H’ 150ns
The pattern in GRAM can be scrolled around the display. Horizontal scroll is achieved by
increment/decrement of the Display Start X Address. The vertical scroll process considers
layer 0, then layer 1 as a continuous 64 bit high vertical area within RAM.
NORITAKE ITRON VFD MODULES
D0~D7
SO
SI
WR (R/W)
RD (ENCK)
CSS
C/D
FRP
/RES
DISPLAY
CONTROLLER
BD VFD
GRAPHIC
RAM
VCC
DC/DC + AC
Conv.
GND
FILAMENT (AC)
ANODE + GRID (DC)
GRAPHIC RAM
X ADDRESS
00H………………………….FFH
BYTE FORMAT
D0
D1
D2
D3
D4
D5
D6
D7
0H
1H
GRAM
Layer 0
2H
Y ADDRESS
…………….FFH
GRAM
Layer 1
3H
6H
The Graphic RAM is composed of 16384
bits arranged as (256 x 32 bits) x 2 and the
7H
access is operated by 8 bit vertical data
IDC DATA CONNECTOR
Pin
1
3
5
7
9
11
13
15
17
19
21
23
25
i80
M68 Serial Pin Sig
D7 D7
X
D6 D6
X
D5 D5
X
D4 D4
X
D3 D3
X
D2 D2
X
D1 D1 SO
D0 D0
SI
/WR R//W X
C//D C//D C//D
/RD ENCK SCK
/CSS /CSS /CSS
FRP FRP FRP
2
4
6
8
10
12
14
16
18
24
26
3 PIN POWER CONNECTOR
Pin
Sig
1
Vcc
GND
2
Test (Factory only)
GND
3
GND
GND
PCB
JUMPERS
(O)pen
(L)ink
GND
GND Interface J1
J2
Serial
L
O/L
GND
O
O
GND i80 Parallel
O
L
GND M68 Parallel
GND
CONTACT
GND
Noritake Sales Office Tel Nos
GND Nagoya Japan: +81 (0)52-561-9867
Canada: +1-416-291-2946
GND
Chicago USA: +1-847-439-9020
/RES Munchen (D): +49 (0)89-3214-290
Subject to change without notice.
IUK Doc Ref: 03469 Iss:1 23/7/01
Itron UK: +44 (0)1493 601144
Rest Europe: +49 (0)61-0520-9220
www.noritake-itron.com
很抱歉,暂时无法提供与“GU160X32-800A”相匹配的价格&库存,您可以联系我们找货
