Graphic VFD Module
GU140x16G-7002
CLICK HERE FOR COMMANDS LIST
Ref: MC-017 Dec.02
The module includes the Vacuum Fluorescent Display
glass, driver and micro-controller Ics with refresh RAM,
character generator and interface logic.
This module have 8 bit parallel & CMOS sync or asyn
Character Graphic, Transformerless display
Size compatible with LCD Module (U-Version)
Single 5V power supply
High Brightness Blue Green display
Operating temp -40°C to +85°C
Proportional and scalable fonts
Screen saver & window definition function
8 level brightness control function
8 bit Parallel, CMOS serial Interface
The module can simultaneously display graphic pattern
and / or characters on screen.
Sample software available
3.5
140 x 16 Dot
Display Area : 69.85 x 11.45
29.0
37.0
serial interface.
116.0
108.0
3.5
Φ3.5
10.4
Unit : mm
ELECTRICAL SPECIFICATION
Parameter
Symbol
Power Supply Voltage VCC
Power Supply Current ICC
Logic High Input
VIH
Logic Low Input
VIL
Logic High Output
VOH
Logic Low Output
VOL
COMMON FONT
INTERNATIONAL FONTS
n=0
Value
5.0VDC
260mADC typ.
0.8VDC min. Vcc max.
0VDC min. 0.2VDC max.
3.5VDC min. 3.8VDC min.
0VDC min. 0.6 DC max.
n=19
OPTICAL and ENVIRONMENTAL SPECIFICATIONS
Value
Parameter
80.00 x 36.00
PCB Size (X x Y mm)
52.5 x 11.45
Display Area (X x Y mm)
0.33 x 0.58 / 0.47 x 0.73
Dot size / Pitch (X x Y mm)
700 cd/m2 Typ.
Luminance
Color of Illumination
Blue Green (Filter for more colors)
Operating Temperature
-40°C to +85°C
20 to 80 % RH (non condensing)
Operating Humidity
SOFTWARE COMMANDS - Popular codes, more included
Command
Code
Write Character to Display
20H~FFH
1FH 24H xL xH yL yH
Cursor Set
1BH 40H
Initialize Display
Specify International Font
1BH 52H n
Vertical / Horizontal Scroll Mode 1FH 02H / 1FH 03H
1FH 28H 61H 40H p
Screen Saver
Display Blink
1FH 28H 61H 11H p t1 t2 c
Bit Image Display Group
1FH 28H 66H 11H xL xH
Font Magnified Display
1FH 28H 67H 40H x y
Brightness Level Setting
1FH 58H n
CMOS Serial Interface - CN2
Pin Asyn. Sig Syn. Sig
1
Vcc
Vcc
2
SIN
SIN
3
GND
GND
4
SBUSY
SBUSY
5
NC
SCK
6
/RESET
/RESET
Parallel Interface - CN1
Pin
Sig
Pin
Sig
1
GND
2
Vcc
3
NC
4
RS
5
/W
6
/RD
7
D0
8
D1
9
D2
10
D3
11
D4
12
D5
13
D6
14
D7
Please inquire for full specification.
** Subject to change without notice **
Atlanta
Boston
Chicago
Dallas
1-888-326-3423
1-888-395-3423
1-800-779-5846
1-888-318-3423
Los Angels
1-888-795-3423
New York
1-888-296-3423
Canada
1-416-291-2946
很抱歉,暂时无法提供与“GU140X16G-7002”相匹配的价格&库存,您可以联系我们找货
