5X7 Dot Character VFD Module
q
q
q
q
q
q
q
q
q
4 X 40 Characters 5mm High
LCD Compatible Design
Wide Operating Temp -40° C to +85° C
Single 5V Supply with Power Save Mode
High Brightness Blue Green Display
Selectable 4/8 bit M68 Interface
ASCII + Extended Character Font
8 User Definable Character RAM
4 Level Brightness Control Function
CU40045SCPB-W1J
The module includes the Vacuum Fluorescent Display
glass, driver and micro-controller ICs with refresh RAM,
character generator and interface logic.
The high speed 8 bit parallel interface is 5V CMOS
compatible suitable for connection to a host CPU bus.
Brightness control and power save functions are provided.
Please call for a full data sheet.
16 x ∅ 1.0 Pitch 2.54
1
23.16 47.0 54.0
15.42
26.32
137.35
183.0
190.0
3.5
3.5
1.6
13.0 max
8.0 max
Dimensions in mm & subject to tolerances. Mounting holes 3.5mm dia.
ELECTRICAL SPECIFICATION
Parameter
Symbol
Power Supply Voltage V CC
Power Supply Current ICC
Logic High Input
V IH
Logic Low Input
V IL
Logic High Output
V OH
Logic Low Output
V OL
CHARACTER FONT
Value
5.0VDC +/- 5%
520mADC typ.
Vss+2.2VDC min.
Vss+0.6VDC max.
Vcc-0.5VDC min.
Vss+0.4VDC max.
Condition
GND=0V
Vcc=5V
V CC=5V
V CC=5V
IOH = -1.6mA
IOL =1.6mA
The power on rise time should be less than 50ms.The inrush current at power on can be 2 x ICC .
The Icc current is 10mA maximum while in power save mode.
OPTICAL and ENVIRONMENTAL SPECIFICATIONS
Parameter
Value
Character Size/Pitch (XxY mm)
2.07 x 4.89/3.47 x 5.09
Dot Size/Pitch (XxY mm)
0.29 x 0.48/0.44 x 0.63
Luminance
700 cd/m2 (204 fL) Typ.
Colour of Illumination
Green
(Filter for more colours)
Operating Temperature
-40°C to +85°C
Storage Temperature
-50°C to +85°C
Operating Humidity (non condensing) 20 to 80% RH @ 25°C
SOFTWARE COMMANDS
Instruction
R/W
Clear Display
L
Cursor Return Home
L
Entry Mode Set
L
Display ON/OFF
L
Cursor/Display Shift
L
Function Set
L
Brightness Set
L
Set CG RAM Addr.
L
Set DD RAM Addr.
L
Read BUSY/Addr.
H
Write Data to RAM
L
Read Data from RAM H
RS
L
L
L
L
L
L
H
L
L
L
H
H
D0-D7
01H
02H-03H
04H-07H
08H-0FH
10H-1FH
20H-3FH
00H-03H
40H-7FH
80H-E7H
00H-FFH
00H-FFH
00H-FFH
PIN CONNECTIONS
Pin
Sig
Pin
Sig
1
D7
2
D6
3
D5
4
D4
5
D3
6
D2
7
D1
8
D0
9
E1
10
R/W
11
RS
12
NC
13
GND
14
V CC
15
E2
16
NC
TIMING PARAMETERS (min)
(E) nable Cycle Time
666ns
(E) nable Pulse Width 300ns
Hold after (E) nable
10ns
NORITAKE ITRON VFD MODULES
JUMPER LINKS
If pads JP1.2 and JP1.3
are linked for no longer
than 10us module will be
reset. If pads JP1.1 and
JP1.2 are linked Pin 12 of
CN1 = /Reset.
CONTACT
Noritake Sales Office Tel Nos
Nagoya Japan: +81 (0)52-561-9867
Canada: +1-416-291-2946
Chicago USA: +1-847-439-9020
Munchen (D): +49 (0)89-3214-290
Itron UK: +44 (0)1493 601144
Rest Europe: +49 (0)61-0520-9220
www.noritake-itron.com
Subject to change without notice.
IUK Doc Ref: 03455 Iss:2 5 Nov 2001
4x40, 5mm Dot Character
很抱歉,暂时无法提供与“CU40045SCPB-W1J”相匹配的价格&库存,您可以联系我们找货
