Adafruit 1.27" and 1.5" Color OLED
Breakout Board
Created by Bill Earl
https://learn.adafruit.com/adafruit-1-5-color-oled-breakout-board
Last updated on 2021-12-09 03:21:37 PM EST
©Adafruit Industries
Page 1 of 45
Table of Contents
Overview
3
• Board Technical Details
4
Assembly
5
6
7
7
8
Prepare the header strip
Position the display
And Solder!
Remove the protective film
Wiring and Graphics Test
8
• Hint:
• Installing the Arduino software
9
10
Drawing Bitmaps
11
11
12
13
14
14
15
Wiring for the Bitmap Example
Hint:
Bitmap Example Sketch
Insert the card
Copy the bitmap file
Load the bitmap example sketch
CircuitPython Displayio Quickstart
17
17
17
18
18
23
Preparing the Breakout
Required CircuitPython Libraries
Code Example Additional Libraries
CircuitPython Code Example
Where to go from here
Python Wiring and Setup
Wiring
ILI9341 and HX-8357-based Displays
ST7789 and ST7735-based Displays
SSD1351-based Displays
SSD1331-based Display
Setup
Python Installation of RGB Display Library
DejaVu TTF Font
Pillow Library
23
23
24
25
28
29
30
30
31
31
Python Usage
31
31
32
37
40
Turning on the Backlight
Displaying an Image
Drawing Shapes and Text
Displaying System Information
Downloads and Links
• Data Sheets:
• Schematic
44
44
45
Page 2 of 45
Overview
We love our black and white monochrome displays but we also like to dabble with
some color now and then. Our big 1.5" color OLED displays are perfect when you
need a small display with vivid, high-contrast 16-bit color. The visible portion of the
OLED measures 1.5" diagonal and contains 128x128 RGB pixels, each one made of
red, green and blue OLEDs. Each pixel can be set with 16-bits of resolution for a large
range of colors. Because the display uses OLEDs, there is no backlight, and the
contrast is very high (black is really black). We picked this display for its excellent
color, this is the nicest mini OLED we could find!
This OLED uses the SSD1351 driver chip, which manages the display. You can talk to
the driver chip using 4-wire write-only SPI (clock, data, chip select, data/command and
an optional reset pin). Included on the fully assembled breakout is the OLED display
and a small boost converter (required for providing 12V to the OLED) and a microSD
card holder. This design includes built-in logic level shifting so you can use it with
3-5VDC power and logic levels. Our example code shows how to read a bitmap from
the uSD card and display it all via SPI.
Page 3 of 45
• 1.5" diagonal OLED, 16-bit color
• SPI interface
• 3.3-5V logic and power
• Micro-SD card holder
• Dimensions: 43.17mm / 1.7" x 42mm / 1.65" x 5.42mm / 0.2"
Please note: all OLEDs have a “half life” — their brightness naturally diminishes over
time, albeit over many thousands of hours. This makes them a poor choice for alwayson 24/7/365 use. Best to turn off the display when inactive, or consider using a color
LCD for continuously running projects.
Page 4 of 45
Assembly
The breakout board comes fully assembled and tested. We include an optional strip of
header pins to make it easier to use this display in a breadboard. The header can be
installed in just a few minutes with your soldering iron:
Page 5 of 45
Cut the header to size and insert (long
pins down) into a breadboard to stabilize
for soldering.
Page 6 of 45
Place the display breakout on the header
so that the short pins protrude through
the holes.
And Solder!
Solder all pins to assure a good electrical
connection.
Page 7 of 45
Gently pull up on the tab to remove the
film.
The pinout ordering is the same for both the 1.27" and 1.5" version of the OLED!
oleddemo.fzz Fritzing File
https://adafru.it/sVa
The library supports flexible wiring to minimize pin conflicts with other shields and
breakouts. For the initial test, we'll use the same wiring as the "test" example from the
library:
• GND -> GND (G)
• 5v -> VIN (+)
• #2 -> SCLK (CL)
• #3 -> MOSI (SI)
Page 8 of 45
• #4 -> DC
• #5 -> OLEDCS (OC)
• #6 -> RST (R)
Hint:
If you are confused by the abbreviations on the front of the board, the full signal
names are printed on the back!
Page 9 of 45
Now we can run the test software on the Arduino.
Three libraries need to be installed using the Arduino Library Manager…this is the
preferred and modern way. From the Arduino “Sketch” menu, select “Include Library”
then “Manage Libraries…”
Type “gfx” in the search field to quickly find the first library — Adafruit_GFX:
If using an earlier version of the Arduino IDE (pre-1.8.10), locate and install Adafruit_B
usIO (newer versions handle this prerequisite automatically).
Then repeat the search and install steps, looking for the Adafruit_SSD1351 library.
After you restart, you should be able to select File→Examples→Adafruit_SSD1351→te
st - this is the example sketch that just tests the display by drawing text and shapes.
Upload the sketch and you should see the following:
The test sketch demonstrates all the basic drawing functions of the Adafruit GFX
Library. Read through the code to see how to draw text, circles, lines, etc.
For a detailed tutorial on the Adafruit GFX library, including all the functions available
please visit the GFX tutorial page (https://adafru.it/aPx)
Page 10 of 45
Drawing Bitmaps
Drawing bitmaps from the on-board micro SD card requires a few more connections
to communicate with the SD card. The library allows you to use any pins. The Arduino
connections listed below match the code in the "bmp" example from the library:
• GND -> GND (G)
• 5v -> VIN (+)
• #7 -> SDCS (SC)
• #4 -> DC
• #6 -> RST (R)
• #5 -> OLEDCS (OC)
• #11 -> MOSI (SI)
• #12 -> MISO (SO)
• #13 -> SCLK (CL)
Note that the Bitmap example code uses hardware SPI wiring for maximum
speed. You can still use software SPI, but make sure that the pin definitions
match your wiring and that you modify the example to select the Software SPI
option (#1) in the code. The SPI pins shown are for Atmega-328 processors. To
use this wiring on other processors, software SPI must be used.
Page 11 of 45
Hint:
Page 12 of 45
To display bitmaps from the on-board micro SD slot, you will need a micro SD card (ht
tp://adafru.it/102) formatted FAT16 or FAT32 (they almost always are by default).
There is a built in microSD card slot on the rear of the breakout and we can use that
to load bitmap images!
It's really easy to draw bitmaps. We have a library for it, Adafruit_ImageReader, which
can be installed through the Arduino Library Manager (Sketch→Include
Page 13 of 45
Library→Manage Libraries…). Enter “imageread” in the search field and the library is
easy to spot:
Next you can either download the image here or copy it from the images folder from
inside the library files.
https://adafru.it/Ey0
Insert the card
Insert the micro SD card into the slot on
the back of the SSD1351 breakout board.
Copy the file "lily128.bmp" from the
Adafruit_ImageReader_Library\images
folder (or wherever you saved it if you
downloaded the file) over to the root
directory of your micro-SD card.
Page 14 of 45
sketch
Select "Examples>Adafruit_ImageReader_Library>BreakoutSSD1351" and upload it to your
Arduino.
In the example, find the following section of code:
// Load full-screen BMP file 'rgbwheel.bmp' at position (0,0) (top left).
// Notice the 'reader' object performs this, with 'tft' as an argument.
Serial.print(F("Loading rgbwheel.bmp to screen..."));
stat = reader.drawBMP("/rgbwheel.bmp", tft, 0, 0);
reader.printStatus(stat);
// How'd we do?
On the line with reader.drawBMP() change "/rgbwheel.bmp" to "/
lily128.bmp" .
After that, upload it to your Arduino. When the Arduino restarts, you should see the
flower as below!
To make new bitmaps, make sure they are less than 128 by 128 pixels and save them
in 24-bit BMP format! They must be in 24-bit format, even if they are not 24-bit color
Page 15 of 45
as that is the easiest format for the Arduino to decode. You can rotate images using
the setRotation() procedure.
The BreakoutSSD1351 example sketch shows everything you need to work with BMP
images. Here’s just the vital bits broken out…
Several header files are included at the top of the sketch. All of these are required…
they let us access the SD card and the display, and provide the image-reading
functions:
#include
#include
#include
#include
#include
<SPI.h>
<SD.h>
<Adafruit_GFX.h>
// Core graphics library
<Adafruit_SSD1351.h>
// Hardware-specific library
<Adafruit_ImageReader.h> // Image-reading functions
Several #defines relate to hardware pin numbers, all fixed values when using the
shield.
Then we declare the tft screen object, and the image-reader object like so:
#define
#define
#define
#define
SD_CS
TFT_CS
TFT_DC
TFT_RST
7
5
4
6
SD card select pin
TFT select pin
TFT display/command pin
Or set to -1 and connect to Arduino RESET pin
Adafruit_SSD1351 tft = Adafruit_SSD1351(SCREEN_WIDTH, SCREEN_HEIGHT, &SPI,
TFT_CS, TFT_DC, TFT_RST);
Adafruit_ImageReader reader;
// Class w/image-reading functions
After the SD and TFT’s begin() functions have been called (see the example sketch
again, in the setup() function), you can then call reader.drawBMP() to load an
image from the card to the screen:
ImageReturnCode stat; // Status from image-reading functions
stat = reader.drawBMP("/lily128.bmp", tft, 0, 0);
You can draw as many images as you want — though remember the names must be
less than 8 characters long. Call like so:
reader.drawBMP(filename, tft, x, y);
'x' and 'y' are pixel coordinates where top-left corner of the image will be placed.
Images can be placed anywhere on screen…even partially off screen, the library will
clip the section to load.
Page 16 of 45
Image loading is explained in greater depth in the Adafruit_GFX library guide. (https:/
/adafru.it/DpM)
You will need a board capable of running CircuitPython such as the Metro M0 Express
or the Metro M4 Express. You can also use boards such as the Feather M0 Express or
the Feather M4 Express. We recommend either the Metro M4 or the Feather M4
Express because it's much faster and works better for driving a display. For this guide,
we will be using a Feather M4 Express. The steps should be about the same for the
Feather M0 Express or either of the Metros. If you haven't already, be sure to check
out our Feather M4 Express (https://adafru.it/EEm) guide.
Adafruit Feather M4 Express - Featuring
ATSAMD51
It's what you've been waiting for, the
Feather M4 Express featuring ATSAMD51.
This Feather is fast like a swift, smart like
an owl, strong like a ox-bird (it's half ox,...
https://www.adafruit.com/product/3857
Before using the TFT Breakout, you will need to solder the headers or some wires to
it. Be sure to check out the Adafruit Guide To Excellent Soldering (https://adafru.it/drI).
After that the breakout should be ready to go.
To use this display with displayio , there is only one required library.
Adafruit_CircuitPython_SSD1351
https://adafru.it/FxO
First, make sure you are running the latest version of Adafruit CircuitPython (https://
adafru.it/Amd) for your board.
Page 17 of 45
Next, you'll need to install the necessary libraries to use the hardware--carefully
follow the steps to find and install these libraries from Adafruit's CircuitPython library
bundle (https://adafru.it/zdx). Our introduction guide has a great page on how to
install the library bundle (https://adafru.it/ABU) for both express and non-express
boards.
Remember for non-express boards, you'll need to manually install the necessary
libraries from the bundle:
• adafruit_ssd1351
Before continuing make sure your board's lib folder or root filesystem has the adafrui
t_ssd1351 file copied over.
For the Code Example, you will need an additional library. We decided to make use of
a library so the code didn't get overly complicated.
Adafruit_CircuitPython_Display_Text
https://adafru.it/FiA
Go ahead and install this in the same manner as the driver library by copying the adaf
ruit_display_text folder over to the lib folder on your CircuitPython device.
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
This test will initialize the display using displayio and draw a solid green
background, a smaller purple rectangle, and some yellow text.
import board
import terminalio
import displayio
from adafruit_display_text import label
from adafruit_ssd1351 import SSD1351
# Release any resources currently in use for the displays
displayio.release_displays()
spi = board.SPI()
tft_cs = board.D5
tft_dc = board.D6
Page 18 of 45
display_bus = displayio.FourWire(
spi, command=tft_dc, chip_select=tft_cs, reset=board.D9, baudrate=16000000
display = SSD1351(display_bus, width=128, height=128)
# Make the display context
splash = displayio.Group()
display.show(splash)
color_bitmap = displayio.Bitmap(128, 128, 1)
color_palette = displayio.Palette(1)
color_palette[0] = 0x00FF00 # Bright Green
bg_sprite = displayio.TileGrid(color_bitmap, pixel_shader=color_palette, x=0, y=0)
splash.append(bg_sprite)
# Draw a smaller inner rectangle
inner_bitmap = displayio.Bitmap(108, 108, 1)
inner_palette = displayio.Palette(1)
inner_palette[0] = 0xAA0088 # Purple
inner_sprite = displayio.TileGrid(inner_bitmap, pixel_shader=inner_palette, x=10,
y=10)
splash.append(inner_sprite)
# Draw a label
text = "Hello World!"
text_area = label.Label(terminalio.FONT, text=text, color=0xFFFF00, x=30, y=64)
splash.append(text_area)
while True:
pass
Let's take a look at the sections of code one by one. We're going to take a look at the
code for the 1.5" display, but there is also an example available for the 128x96 1.27"
display. The example is the same as we are covering in here but with the numbers
adjusted for the different height.
We start by importing the board so that we can initialize SPI , displayio , terminal
io for the font, a label , and the adafruit_ssd1351 driver.
import board
import displayio
import terminalio
Next we release any previously used displays. This is important because if the
Feather is reset, the display pins are not automatically released and this makes them
available for use again.
Page 19 of 45
Next, we set the SPI object to the board's SPI with the easy shortcut function board.
SPI() . By using this function, it finds the SPI module and initializes using the default
SPI parameters.
spi = board.SPI()
tft_cs = board.D5
tft_dc = board.D6
In the next line, we set the display bus to FourWire which makes use of the SPI bus.
Additionally, we need to set the baudrate to 16MHz since that is the maximum speed
that the SSD1351 chip will run at. Anything higher creates strange artifacts on the
screen.
display_bus = displayio.FourWire(spi, command=tft_dc, chip_select=tft_cs,
reset=board.D9, baudrate=16000000)
Finally, we initialize the driver with a width of 128 and a height of 128. If we stopped at
this point and ran the code, we would have a terminal that we could type at and have
the screen update.
Next we create a background splash image. We do this by creating a group that we
can add elements to and adding that group to the display. In this example, we are
limiting the maximum number of elements to 10, but this can be increased if you
would like. The display will automatically handle updating the group.
Page 20 of 45
splash = displayio.Group(max_size=10)
Next we create a Bitmap which is like a canvas that we can draw on. In this case we
are creating the Bitmap to be the same size as the screen, but only have one color.
The Bitmaps can currently handle up to 256 different colors. We create a Palette with
one color and set that color to 0x00FF00 which happens to be green. Colors are
Hexadecimal values in the format of RRGGBB. Even though the Bitmaps can only
handle 256 colors at a time, you get to define what those 256 different colors are.
With all those pieces in place, we create a TileGrid by passing the bitmap and palette
and draw it at (0, 0) which represents the display's upper left.
x=0, y=0)
Next we will create a smaller purple square. The easiest way to do this is the create a
new bitmap that is a little smaller than the full screen with a single color and place it in
a specific location. In this case, we will create a bitmap that is 10 pixels smaller on
each side. The screen is 128x128, so we'll want to subtract 20 from each of those
numbers.
Page 21 of 45
We'll also want to place it at the position (10, 10) so that it ends up centered.
x=10, y=10)
Since we are adding this after the first square, it's automatically drawn on top. Here's
what it looks like now.
Next let's add a label that says "Hello World!" on top of that. We're going to use the
built-in Terminal Font. In this example, we won't be doing any scaling because of the
small resolution compared to some of the other displays, so we'll add the label
directly the main group. If we were scaling, we would have used a subgroup.
Labels are centered vertically, so we'll place it at 64 for the Y coordinate, and around
30 pixels make it appear to be centered horizontally, but if you want to change the
text, change this to whatever looks good to you. Let's go with some yellow text, so
we'll pass it a value of 0xFFFF00 .
Finally, we place an infinite loop at the end so that the graphics screen remains in
place and isn't replaced by a terminal.
Page 22 of 45
while True:
pass
Be sure to check out this excellent guide to CircuitPython Display Support Using
displayio (https://adafru.it/EGh)
Wiring
It's easy to use display breakouts with Python and the Adafruit CircuitPython RGB
Display (https://adafru.it/u1C) module. This module allows you to easily write Python
code to control the display.
We'll cover how to wire the display to your Raspberry Pi. First assemble your display.
Since there's dozens of Linux computers/boards you can use we will show wiring for
Raspberry Pi. For other platforms, please visit the guide for CircuitPython on Linux to
see whether your platform is supported (https://adafru.it/BSN).
Connect the display as shown below to your Raspberry Pi.
Page 23 of 45
Note this is not a kernel driver that will let you have the console appear on the
TFT. However, this is handy when you can't install an fbtft driver, and want to use
the TFT purely from 'user Python' code!
You can only use this technique with Linux/computer devices that have hardware
SPI support, and not all single board computers have an SPI device so check
before continuing
2.2" Display
• CLK connects to SPI clock. On the Raspberry Pi, thats SLCK
• MOSI connects to SPI MOSI. On the Raspberry Pi, thats also MOSI
• CS connects to our SPI Chip Select pin. We'll be using CE0
• D/C connects to our SPI Chip Select pin. We'll be using GPIO 25, but this can be
changed later.
• RST connects to our Reset pin. We'll be using GPIO 24 but this can be changed
later as well.
• Vin connects to the Raspberry Pi's 3V pin
• GND connects to the Raspberry Pi's ground
Download the Fritzing Diagram
https://adafru.it/H6C
Page 24 of 45
2.4", 2.8", 3.2", and 3.5" Displays
These displays are set up to use the 8-bit data lines by default. We want to use them
for SPI. To do that, you'll need to either solder bridge some pads on the back or
connect the appropriate IM lines to 3.3V with jumper wires. Check the back of your
display for the correct solder pads or IM lines to put it in SPI mode.
changed later.
later as well.
These larger displays are set to use 8-bit data lines by default and may need to
be modified to use SPI.
https://adafru.it/H7a
1.3", 1.54", and 2.0" IPS TFT Display
Page 25 of 45
later.
changed later as well.
https://adafru.it/H7A
0.96", 1.14", and 1.44" Displays
later.
Page 26 of 45
https://adafru.it/H7B
1.8" Display
later.
• LITE connects to the Raspberry Pi's 3V pin. This can be used to separately
control the backlight.
Page 27 of 45
https://adafru.it/H8a
1.27" and 1.5" OLED Displays
later.
Page 28 of 45
https://adafru.it/H8A
0.96" OLED Display
changed later.
later as well.
Page 29 of 45
https://adafru.it/OaF
Setup
You'll need to install the Adafruit_Blinka library that provides the CircuitPython
support in Python. This may also require enabling SPI on your platform and verifying
you are running Python 3. Since each platform is a little different, and Linux changes
often, please visit the CircuitPython on Linux guide to get your computer ready (https
://adafru.it/BSN)!
If you have previously installed the Kernel Driver with the PiTFT Easy Setup, you
will need to remove it first in order to run this example.
Once that's done, from your command line run the following command:
• sudo pip3 install adafruit-circuitpython-rgb-display
If your default Python is version 3 you may need to run 'pip' instead. Just make sure
you aren't trying to use CircuitPython on Python 2.x, it isn't supported!
Page 30 of 45
If that complains about pip3 not being installed, then run this first to install it:
• sudo apt-get install python3-pip
DejaVu TTF Font
Raspberry Pi usually comes with the DejaVu font already installed, but in case it didn't,
you can run the following to install it:
• sudo apt-get install fonts-dejavu
This package was previously calls ttf-dejavu, so if you are running an older version of
Raspberry Pi OS, it may be called that.
Pillow Library
We also need PIL, the Python Imaging Library, to allow graphics and using text with
custom fonts. There are several system libraries that PIL relies on, so installing via a
package manager is the easiest way to bring in everything:
• sudo apt-get install python3-pil
That's it. You should be ready to go.
Python Usage
Now that you have everything setup, we're going to look over three different
examples. For the first, we'll take a look at automatically scaling and cropping an
image and then centering it on the display.
On some displays, the backlight is controlled by a separate pin such as the 1.3" TFT
Bonnet with Joystick. On such displays, running the below code will likely result in the
Page 31 of 45
display remaining black. To turn on the backlight, you will need to add a small snippet
of code. If your backlight pin number differs, be sure to change it in the code:
# Turn on the Backlight
backlight = DigitalInOut(board.D26)
backlight.switch_to_output()
backlight.value = True
Displaying an Image
Here's the full code to the example. We will go through it section by section to help
you better understand what is going on. Let's start by downloading an image of
Blinka. This image has enough border to allow resizing and cropping with a variety of
display sizes and rations to still look good.
Make sure you save it as blinka.jpg and place it in the same folder as your script.
Here's the code we'll be loading onto the Raspberry Pi. We'll go over the interesting
parts.
Be sure to check the learn guides for more usage information.
This example is for use on (Linux) computers that are using CPython with
Adafruit Blinka to support CircuitPython libraries. CircuitPython does
not support PIL/pillow (python imaging library)!
Author(s): Melissa LeBlanc-Williams for Adafruit Industries
import digitalio
import board
from PIL import Image, ImageDraw
from adafruit_rgb_display import ili9341
from adafruit_rgb_display import st7789 # pylint: disable=unused-import
Page 32 of 45
from
from
from
from
import
import
import
import
hx8357 # pylint: disable=unused-import
st7735 # pylint: disable=unused-import
ssd1351 # pylint: disable=unused-import
ssd1331 # pylint: disable=unused-import
# Configuration for CS and DC pins (these are PiTFT defaults):
cs_pin = digitalio.DigitalInOut(board.CE0)
dc_pin = digitalio.DigitalInOut(board.D25)
reset_pin = digitalio.DigitalInOut(board.D24)
# Config for display baudrate (default max is 24mhz):
BAUDRATE = 24000000
# Setup SPI bus using hardware SPI:
spi = board.SPI()
# pylint: disable=line-too-long
# Create the display:
# disp = st7789.ST7789(spi, rotation=90,
# 2.0" ST7789
# disp = st7789.ST7789(spi, height=240, y_offset=80, rotation=180, # 1.3", 1.54"
ST7789
# disp = st7789.ST7789(spi, rotation=90, width=135, height=240, x_offset=53,
y_offset=40, # 1.14" ST7789
# disp = hx8357.HX8357(spi, rotation=180,
# 3.5" HX8357
# disp = st7735.ST7735R(spi, rotation=90,
# 1.8" ST7735R
# disp = st7735.ST7735R(spi, rotation=270, height=128, x_offset=2, y_offset=3,
1.44" ST7735R
# disp = st7735.ST7735R(spi, rotation=90, bgr=True,
# 0.96" MiniTFT
ST7735R
# disp = ssd1351.SSD1351(spi, rotation=180,
# 1.5" SSD1351
# disp = ssd1351.SSD1351(spi, height=96, y_offset=32, rotation=180, # 1.27" SSD1351
# disp = ssd1331.SSD1331(spi, rotation=180,
# 0.96" SSD1331
disp = ili9341.ILI9341(
spi,
rotation=90, # 2.2", 2.4", 2.8", 3.2" ILI9341
cs=cs_pin,
dc=dc_pin,
rst=reset_pin,
baudrate=BAUDRATE,
# pylint: enable=line-too-long
# Create blank image for drawing.
# Make sure to create image with mode 'RGB' for full color.
if disp.rotation % 180 == 90:
height = disp.width # we swap height/width to rotate it to landscape!
width = disp.height
else:
width = disp.width # we swap height/width to rotate it to landscape!
height = disp.height
image = Image.new("RGB", (width, height))
# Get drawing object to draw on image.
draw = ImageDraw.Draw(image)
# Draw a black filled box to clear the image.
draw.rectangle((0, 0, width, height), outline=0, fill=(0, 0, 0))
disp.image(image)
image = Image.open("blinka.jpg")
# Scale the image to the smaller screen dimension
image_ratio = image.width / image.height
screen_ratio = width / height
if screen_ratio < image_ratio:
scaled_width = image.width * height // image.height
scaled_height = height
else:
scaled_width = width
Page 33 of 45
scaled_height = image.height * width // image.width
image = image.resize((scaled_width, scaled_height), Image.BICUBIC)
# Crop and center the image
x = scaled_width // 2 - width // 2
y = scaled_height // 2 - height // 2
image = image.crop((x, y, x + width, y + height))
# Display image.
disp.image(image)
So we start with our usual imports including a couple of Pillow modules and the
display drivers. That is followed by defining a few pins here. The reason we chose
these is because they allow you to use the same code with the PiTFT if you chose to
do so.
import digitalio
import board
import adafruit_rgb_display.ili9341 as ili9341
import adafruit_rgb_display.st7789 as st7789
import adafruit_rgb_display.hx8357 as hx8357
import adafruit_rgb_display.st7735 as st7735
import adafruit_rgb_display.ssd1351 as ssd1351
import adafruit_rgb_display.ssd1331 as ssd1331
Next we'll set the baud rate from the default 24 MHz so that it works on a variety of
displays. The exception to this is the SSD1351 driver, which will automatically limit it to
16MHz even if you pass 24MHz. We'll set up out SPI bus and then initialize the display.
We wanted to make these examples work on as many displays as possible with very
few changes. The ILI9341 display is selected by default. For other displays, go ahead
and comment out the line that starts with:
disp = ili9341.ILI9341(spi,
and uncomment the line appropriate for your display. The displays have a rotation
property so that it can be set in just one place.
BAUDRATE = 24000000
spi = board.SPI()
#disp = st7789.ST7789(spi, rotation=90,
# 2.0" ST7789
#disp = st7789.ST7789(spi, height=240, y_offset=80, rotation=180, # 1.3", 1.54"
ST7789
#disp = st7789.ST7789(spi, rotation=90, width=135, height=240, x_offset=53,
Page 34 of 45
#disp = hx8357.HX8357(spi, rotation=180,
# 3.5" HX8357
#disp = st7735.ST7735R(spi, rotation=90,
# 1.8" ST7735R
#disp = st7735.ST7735R(spi, rotation=270, height=128, x_offset=2, y_offset=3,
1.44" ST7735R
#disp = st7735.ST7735R(spi, rotation=90, bgr=True,
# 0.96" MiniTFT
ST7735R
#disp = ssd1351.SSD1351(spi, rotation=180,
# 1.5" SSD1351
#disp = ssd1351.SSD1351(spi, height=96, y_offset=32, rotation=180, # 1.27" SSD1351
#disp = ssd1331.SSD1331(spi, rotation=180,
# 0.96" SSD1331
disp = ili9341.ILI9341(spi, rotation=90,
# 2.2", 2.4",
2.8", 3.2" ILI9341
cs=cs_pin, dc=dc_pin, rst=reset_pin, baudrate=BAUDRATE)
Next we read the current rotation setting of the display and if it is 90 or 270 degrees,
we need to swap the width and height for our calculations, otherwise we just grab the
width and height. We will create an image with our dimensions and use that to create
a draw object. The draw object will have all of our drawing functions.
height = disp.width
width = disp.height
else:
width = disp.width
image = Image.new('RGB', (width, height))
Next we clear whatever is on the screen by drawing a black rectangle. This isn't
strictly necessary since it will be overwritten by the image, but it kind of sets the
stage.
disp.image(image)
Next we open the Blinka image, which we've named blinka.jpg, which assumes it is in
the same directory that you are running the script from. Feel free to change it if it
doesn't match your configuration.
Page 35 of 45
Here's where it starts to get interesting. We want to scale the image so that it matches
either the width or height of the display, depending on which is smaller, so that we
have some of the image to chop off when we crop it. So we start by calculating the
width to height ration of both the display and the image. If the height is the closer of
the dimensions, we want to match the image height to the display height and let it be
a bit wider than the display. Otherwise, we want to do the opposite.
Once we've figured out how we're going to scale it, we pass in the new dimensions
and using a Bicubic rescaling method, we reassign the newly rescaled image back to
image . Pillow has quite a few different methods to choose from, but Bicubic does a
great job and is reasonably fast.
else:
Next we want to figure the starting x and y points of the image where we want to
begin cropping it so that it ends up centered. We do that by using a standard
centering function, which is basically requesting the difference of the center of the
display and the center of the image. Just like with scaling, we replace the image
variable with the newly cropped image.
Finally, we take our image and display it. At this point, the image should have the
exact same dimensions at the display and fill it completely.
disp.image(image)
Page 36 of 45
In the next example, we'll take a look at drawing shapes and text. This is very similar
to the displayio example, but it uses Pillow instead. Here's the code for that.
This demo will draw a few rectangles onto the screen along with some text
on top of that.
import digitalio
import board
from PIL import Image, ImageDraw, ImageFont
from adafruit_rgb_display import hx8357 # pylint: disable=unused-import
from adafruit_rgb_display import st7735 # pylint: disable=unused-import
from adafruit_rgb_display import ssd1351 # pylint: disable=unused-import
from adafruit_rgb_display import ssd1331 # pylint: disable=unused-import
# First define some constants to allow easy resizing of shapes.
BORDER = 20
FONTSIZE = 24
Page 37 of 45
BAUDRATE = 24000000
spi = board.SPI()
# 2.0" ST7789
ST7789
# 3.5" HX8357
# 1.8" ST7735R
1.44" ST7735R
# 0.96" MiniTFT
ST7735R
# 1.5" SSD1351
# 0.96" SSD1331
spi,
cs=cs_pin,
dc=dc_pin,
rst=reset_pin,
baudrate=BAUDRATE,
width = disp.height
else:
# Draw a green filled box as the background
draw.rectangle((0, 0, width, height), fill=(0, 255, 0))
disp.image(image)
# Draw a smaller inner purple rectangle
draw.rectangle(
(BORDER, BORDER, width - BORDER - 1, height - BORDER - 1), fill=(170, 0, 136)
# Load a TTF Font
font = ImageFont.truetype("/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf",
FONTSIZE)
# Draw Some Text
(font_width, font_height) = font.getsize(text)
draw.text(
(width // 2 - font_width // 2, height // 2 - font_height // 2),
text,
font=font,
fill=(255, 255, 0),
Page 38 of 45
# Display image.
disp.image(image)
Just like in the last example, we'll do our imports, but this time we're including the Im
ageFont Pillow module because we'll be drawing some text this time.
import digitalio
import board
Next we'll define some parameters that we can tweak for various displays. The BORD
ER will be the size in pixels of the green border between the edge of the display and
the inner purple rectangle. The FONTSIZE will be the size of the font in points so that
we can adjust it easily for different displays.
BORDER = 20
FONTSIZE = 24
Next, just like in the previous example, we will set up the display, setup the rotation,
and create a draw object. If you have are using a different display than the ILI9341, go
ahead and adjust your initializer as explained in the previous example. After that, we
will setup the background with a green rectangle that takes up the full screen. To get
green, we pass in a tuple that has our Red, Green, and Blue color values in it in that
order which can be any integer from 0 to 255 .
disp.image(image)
Next we will draw an inner purple rectangle. This is the same color value as our
example in displayio quickstart, except the hexadecimal values have been converted
to decimal. We use the BORDER parameter to calculate the size and position that we
want to draw the rectangle.
draw.rectangle((BORDER, BORDER, width - BORDER - 1, height - BORDER - 1),
fill=(170, 0, 136))
Next we'll load a TTF font. The DejaVuSans.ttf font should come preloaded on
your Pi in the location in the code. We also make use of the FONTSIZE parameter
that we discussed earlier.
# Load a TTF Font
font = ImageFont.truetype('/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf',
FONTSIZE)
Page 39 of 45
Now we draw the text Hello World onto the center of the display. You may recognize
the centering calculation was the same one we used to center crop the image in the
previous example. In this example though, we get the font size values using the gets
ize() function of the font object.
# Draw Some Text
draw.text((width//2 - font_width//2, height//2 - font_height//2),
text, font=font, fill=(255, 255, 0))
Finally, just like before, we display the image.
disp.image(image)
In this last example we'll take a look at getting the system information and displaying
it. This can be very handy for system monitoring. Here's the code for that example:
This will show some Linux Statistics on the attached display. Be sure to adjust
to the display you have connected. Be sure to check the learn guides for more
usage information.
Page 40 of 45
import time
import subprocess
import digitalio
import board
BAUDRATE = 24000000
spi = board.SPI()
# 2.0" ST7789
ST7789
# 3.5" HX8357
# 1.8" ST7735R
1.44" ST7735R
# 0.96" MiniTFT
ST7735R
# 1.5" SSD1351
# 0.96" SSD1331
spi,
cs=cs_pin,
dc=dc_pin,
rst=reset_pin,
baudrate=BAUDRATE,
width = disp.height
else:
disp.image(image)
Page 41 of 45
# First define some constants to allow easy positioning of text.
padding = -2
x = 0
# Load
# same
# Some
font =
a TTF font. Make sure the .ttf font file is in the
directory as the python script!
other nice fonts to try: http://www.dafont.com/bitmap.php
ImageFont.truetype("/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf", 24)
while True:
draw.rectangle((0, 0, width, height), outline=0, fill=0)
# Shell scripts for system monitoring from here:
# https://unix.stackexchange.com/questions/119126/command-to-display-memoryusage-disk-usage-and-cpu-load
cmd = "hostname -I | cut -d' ' -f1"
IP = "IP: " + subprocess.check_output(cmd, shell=True).decode("utf-8")
cmd = "top -bn1 | grep load | awk '{printf \"CPU Load: %.2f\", $(NF-2)}'"
CPU = subprocess.check_output(cmd, shell=True).decode("utf-8")
cmd = "free -m | awk 'NR==2{printf \"Mem: %s/%s MB %.2f%%\",
$3,$2,$3*100/$2 }'"
MemUsage = subprocess.check_output(cmd, shell=True).decode("utf-8")
cmd = 'df -h | awk \'$NF=="/"{printf "Disk: %d/%d GB %s", $3,$2,$5}\''
Disk = subprocess.check_output(cmd, shell=True).decode("utf-8")
cmd = "cat /sys/class/thermal/thermal_zone0/temp | awk '{printf \"CPU Temp: %.
1f C\", $(NF-0) / 1000}'" # pylint: disable=line-too-long
Temp = subprocess.check_output(cmd, shell=True).decode("utf-8")
# Write four lines of text.
y = padding
draw.text((x, y), IP, font=font, fill="#FFFFFF")
y += font.getsize(IP)[1]
draw.text((x, y), CPU, font=font, fill="#FFFF00")
y += font.getsize(CPU)[1]
draw.text((x, y), MemUsage, font=font, fill="#00FF00")
y += font.getsize(MemUsage)[1]
draw.text((x, y), Disk, font=font, fill="#0000FF")
y += font.getsize(Disk)[1]
draw.text((x, y), Temp, font=font, fill="#FF00FF")
# Display image.
disp.image(image)
time.sleep(0.1)
Just like the last example, we'll start by importing everything we imported, but we're
adding two more imports. The first one is time so that we can add a small delay and
the other is subprocess so we can gather some system information.
import time
import subprocess
import digitalio
import board
Next, just like in the first two examples, we will set up the display, setup the rotation,
Page 42 of 45
Just like in the first example, we're going to draw a black rectangle to fill up the
screen. After that, we're going to set up a couple of constants to help with positioning
text. The first is the padding and that will be the Y-position of the top-most text and
the other is x which is the X-Position and represents the left side of the text.
padding = -2
x = 0
Next, we load a font just like in the second example.
font = ImageFont.truetype('/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf', 24)
Now we get to the main loop and by using while True: , it will loop until Control+C
is pressed on the keyboard. The first item inside here, we clear the screen, but notice
that instead of giving it a tuple like before, we can just pass 0 and it will draw black.
Next, we run a few scripts using the subprocess function that get called to the
Operating System to get information. The in each command is passed through awk in
order to be formatted better for the display. By having the OS do the work, we don't
have to. These little scripts came from https://unix.stackexchange.com/
questions/119126/command-to-display-memory-usage-disk-usage-and-cpuload
cmd = "hostname -I | cut -d\' \' -f1"
IP = "IP: "+subprocess.check_output(cmd, shell=True).decode("utf-8")
cmd = "free -m | awk 'NR==2{printf \"Mem: %s/%s MB %.2f%%\", $3,$2,$3*100/$2 }'"
cmd = "df -h | awk '$NF==\"/\"{printf \"Disk: %d/%d GB %s\", $3,$2,$5}'"
cmd = "cat /sys/class/thermal/thermal_zone0/temp | awk \'{printf \"CPU Temp: %.1f
C\", $(NF-0) / 1000}\'" # pylint: disable=line-too-long
Now we display the information for the user. Here we use yet another way to pass
color information. We can pass it as a color string using the pound symbol, just like we
would with HTML. With each line, we take the height of the line using getsize()
and move the pointer down by that much.
y = padding
Page 43 of 45
Finally, we write all the information out to the display using disp.image() . Since we
are looping, we tell Python to sleep for 0.1 seconds so that the CPU never gets too
busy.
disp.image(image)
time.sleep(.1)
Downloads and Links
Data Sheets:
• SSD1351 Display Controller Datasheet (https://adafru.it/sVb)
• 1.5" OLED Display Module datasheet (https://adafru.it/cBE)
• Fritzing objects in the Adafruit Fritzing library (https://adafru.it/aP3)
• EagleCAD PCB for 1.27" Color OLED (https://adafru.it/rqB)
• EagleCAD PCB for the 1.5" Color OLED (https://adafru.it/rqC)
Page 44 of 45
Schematic
Click to enlarge
For the level shifter we use the CD74HC4050 (https://adafru.it/Ekk) which has a
typical propagation delay of ~10ns
Page 45 of 45
