DT050TFT-PTS
DT050TFT-PTS
    DISPLAYTECH(Displaytech)
    LCDDISPTFT5.0"800X480
DT050TFT-PTS 数据手册
TFT LCD Module Product Specification DT050TFT-PTS 5.0” (800(RGB) x 480 PIXELS) TFT Module with Capacitive Touch Panel June 1, 2016 Remark: Contents in this document are subject to change without notice. No part of this document may be reproduced or transmitted in any form or by any means, electronic or mechanical, for any purpose, without the express written permission of Displaytech Ltd. Displaytech Ltd. Tel: (852) 2311 2080 ; Fax: (852) 2722 6998 ; Email: sales@displaytech.com.hk Address: 31E Billion Plaza 2, No. 10 Cheung Yue Street, Cheung Sha Wan, Kowloon, Hong Kong. Website: http://www.displaytech.com.hk Displaytech Ltd. DT050TFT-PTS Rev 0.0 Revision Record REV 0.0 CHANGES First release DATE Jun 1, 2016 (Ref 1.0 20131206) 1 Displaytech Ltd. DT050TFT-PTS Rev 0.0 Table of Content Revision Record ...........................................................................0 1. Scope.....................................................................................3 2. Application ............................................................................3 3. General Information ..............................................................3 4. Outline Drawing ....................................................................4 5. Interface signals....................................................................5 6. Absolute Maximum Ratings .................................................6 7. Electrical Specifications .......................................................6 8. Command/AC Timing............................................................7 9. Optical Specification........................................................... 11 10. Environmental / Reliability Tests ....................................... 14 11. Precautions for Use of LCD Modules ................................ 14 2 Displaytech Ltd. DT050TFT-PTS Rev 0.0 1. Scope This data sheet is to introduce the specification of DT050TFT-PTS, active matrix TFT module. It is composed of a color TFT-LCD panel, driver ICs, FPC, CTP, and a backlight unit. The 5.0” display area contains 800RGB x 480 pixels. 2. Application Digital equipments which need color display, mobile navigator/video systems. 3. General Information Item Size Resolution Technology Type Interface Pixel Pitch Pixel Configuration Outline Dimension (W x H x D) Active Area Display Mode Backlight Type Contents 5.0 800(RGB) x 480 a-Si TFT RGB 24 bits 0.135 x 0.135 R.G.B. Vertical Stripe 121.10 x 76.20 x 4.75 108.00 x 64.80 Transmissive, Normally white LED 3 Unit Inch mm mm mm Displaytech Ltd. DT050TFT-PTS 4. Outline Drawing Displaytech Ltd. DT050TFT-PTS 4 Rev 0.0 Displaytech Ltd. DT050TFT-PTS Rev 0.0 5. Interface signals No 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 Symbol LED-K LED-A NC VDD R0 R1 R2 R3 R4 R5 R6 R7 G0 G1 G2 G3 G4 G5 G6 G7 B0 B1 B2 B3 B4 B5 B6 B7 GND CLK DISP HSYNC VSYNC DE NC GND XR (NC) YD (NC) XL (NC) YU (NC) Description Backlight LED Cathode Backlight LED Anode No connection Digital power supply Red data Red data Red data Red data Red data Red data Red data Red data Green data Green data Green data Green data Green data Green data Green data Green data Blue data Blue data Blue data Blue data Blue data Blue data Blue data Blue data Power ground Clock for input data Display on/off control Horizontal sync signal Vertical sync signal Data enable No connection Power ground No connection No connection No connection No connection Remark Description Remark Interface of CTP No 1 2 3 4 5 6 Symbol VDD SCL SDA INT RST GND CTP power supply I2C clock signal. Must be pulled high I2C data signal. Must be pulled high Interrupt signal Reset pin. Must be pulled high Ground 5 DT050TFT-PTS Displaytech Ltd. Rev 0.0 6. Absolute Maximum Ratings 6.1 Electrical Absolute Max. Ratings Item Supply voltage Symbol VDD Min -0.5 Max 5.0 Unit V Remark Min -20 -30 Max 70 80 Unit ℃ ℃ Remark Max 25 Unit mA Remark For each LED 6.2 Environment Conditions Item Operating Temperature Storage Temperature Symbol TOPR TSTG 6.3 LED Backlight Absolute Max. Ratings Item LED forward current Symbol ILED Min -- 7. Electrical Specifications 7.1 Electrical Characteristics Item Digital supply voltage Symbol VDD Ta=25℃ Min 3.0 Typ 3.3 Max 3.6 Unit V Remark Unit mA V mW Hr Remark 7.2 LED Backlight Item Forward current Forward voltage Power consumption LED life time Ta=25℃ Symbol IF VF WBL -- Min ----- Typ 40 19.8 792 30,000 Max 50 21.0 --- Note Note 1. The figure below shows the connection of backlight LED. Note 2. One LED: IF=20mA, VF=3.2V Note 3. The “LED life time” is defined as the module brightness decrease to 50% original brightness at Ta=25℃ and IL=40mA. The LED lifetime could be decreased if operating IL is lager than 40mA. 6 Displaytech Ltd. DT050TFT-PTS 8. Command/AC Timing 8.1 TFT-LCD Input Timing 7 Rev 0.0 Displaytech Ltd. DT050TFT-PTS 8.2 Recommended Timing Setting of TCON TCON (Embedded In Source IC ) Input Timing (DCLK, HSD, VSD, ED) 8 Rev 0.0 Displaytech Ltd. DT050TFT-PTS 8.3 Power On/Off Sequence 9 Rev 0.0 Displaytech Ltd. DT050TFT-PTS 10 Rev 0.0 DT050TFT-PTS Displaytech Ltd. Rev 0.0 9. Optical Specification Ta=25℃ Item Contrast Ratio Response Time View Angles Red Green Chromaticity Blue White NTSC Symbol Condition Min Typ Max CR θ=0° 400 500 - Ton/Toff 25℃ - 20 30 40 60 60 60 - 50 70 70 70 0.618 0.326 0.317 0.568 0.127 0.165 0.330 0.357 50 - θT θB θL θR X Y X Y X Y X Y S CR≧10 Brightness is on Unit ms Degree % L - 260 - cd/m2 Uniformity U 75 80 - % Temperature = 25℃(±3℃) LED back-light: ON, Environment brightness < 150 lx 11 Note 4 Note 1 Note 5 Luminance Note 1: Definition of optical measurement system. Remark Note 1 Note 2 Note 1 Note 3 Note 5 Note 1 Note 6 Note 1 Note 7 Displaytech Ltd. DT050TFT-PTS Rev 0.0 Note 2: Contrast ratio is defined as follow: Note 3: Response time is defined as follow: Response time is the time required for the display to transition from black to white (Rise Time, Tr) and from white to black(Decay Time, Tf). Note 4: Viewing angle range is defined as follow: Viewing angle is measured at the center point of the LCD. 12 Displaytech Ltd. DT050TFT-PTS Rev 0.0 Note 5: Color chromaticity is defined as follow: (CIE1931) Color coordinates measured at center point of LCD. Note 6: Luminance is defined as follow: Luminance is defined as the brightness of all pixels “White” at the center of display area on optimum contrast. Note 7: Luminance Uniformity is defined as follow: Active area is divided into 9 measuring areas (Refer Fig. 2). Every measuring point is placed at the center of each measuring area. 13 DT050TFT-PTS Displaytech Ltd. Rev 0.0 10. Environmental / Reliability Tests No 1 2 3 4 Test Item High Temp Operation Low Temp Operation High Temp Storage Low Temp Storage Condition Ts=+70℃, 120hrs Ta=-20℃, 120hrs Ta=+80℃, 120hrs Ta=-30℃, 120hrs 5 High Temp & High Humidity Storage Ta=+60℃, 90% RH 120 hours 6 Thermal Shock (Non-operation) 7 ESD (Operation) 8 Vibration (Non-operation) 9 Shock (Non-operation) 10 Package Drop Test -30℃ 30 min~+80℃ 30 min, Change time: 5min, 10 Cycles C=150pF, R=330Ω, 5points/panel Air: ±8KV, 5times; Contact: ±4KV, 5 times; Frequency range: 10~55Hz, Stroke: 1.5mm Sweep: 10Hz~55Hz~10Hz 2 hours for each direction of X.Y.Z. 60G 6ms, ±X,±Y,±Z 3times, for each direction Height: 80 cm, 1 corner, 3 edges, 6 surfaces Inspection Appearance Alignment of LCD Panel Electrical current Function / Display Judgment Criteria Per table in below Per table in below Per table in below Per table in below Per table in below (polarizer discoloration is excluded) Per table in below Per table in below Per table in below Per table in below Per table in below Criterion (after test) No Crack on the FPC, on the LCD Panel No Bubbles in the LCD Panel No other Defects of Alignment in Active area Within device specifications No Broken Circuit, No Short Circuit or No Black line No Other Defects of Display 11. Precautions for Use of LCD Modules 11.1 Safety The liquid crystal in the LCD is poisonous. Do not put it in your mouth. If the liquid crystal touches your skin or clothes, wash it off immediately using soap and water. 11.2 Handling A. The LCD and touch panel is made of plate glass. Do not subject the panel to mechanical shock or to excessive force on its surface. B. Do not handle the product by holding the flexible pattern portion in order to assure the Reliability C. Transparency is an important factor for the touch panel. Please wear clear finger sacks, gloves and mask to protect the touch panel from finger print or stain and also hold the portion outside the view area when handling the touch panel. D. Provide a space so that the panel does not come into contact with other components. 14 Displaytech Ltd. DT050TFT-PTS Rev 0.0 E. To protect the product from external force, put a covering lens (acrylic board or similar board) and keep an appropriate gap between them. F. Transparent electrodes may be disconnected if the panel is used under environmental conditions where dew condensation occurs. G. Property of semiconductor devices may be affected when they are exposed to light, possibly resulting in IC malfunctions. H. To prevent such IC malfunctions, your design and mounting layout shall be done in the way that the IC is not exposed to light in actual use. 11.3 Static Electricity A. Ground soldering iron tips, tools and testers when they are in operation. B. Ground your body when handling the products. C. Power on the LCD module before applying the voltage to the input terminals. D. Do not apply voltage which exceeds the absolute maximum rating. E. Store the products in an anti-electrostatic bag or container. 11.4 Storage A. Store the products in a dark place at +25℃±10℃ with low humidity (40% RH to 60% RH). Don't expose to sunlight or fluorescent light. B. Storage in a clean environment, free from dust, active gas, and solvent. 11.5 Cleaning A. Do not wipe the touch panel with dry cloth, as it may cause scratch. B. Wipe off the stain on the product by using soft cloth moistened with ethanol. Do not allow ethanol to get in between the upper film and the bottom glass. It may cause peeling issue or defective operation. Do not use any organic solvent or detergent other than ethanol. 11.6 Cautions for installing and assembling Bezel edge must be positioned in the area between the Active area and View area. The bezel may press the touch screen and cause activation if the edge touches the active area. A gap of approximately 0.5mm is needed between the bezel and the top electrode. It may cause unexpected activation if the gap is too narrow. There is a tolerance of 0.2 to 0.3mm for the outside dimensions of the touch panel and tail. A gap must be made to absorb the tolerance in the case and connector. 15
DT050TFT-PTS 价格&库存
很抱歉,暂时无法提供与“DT050TFT-PTS”相匹配的价格&库存,您可以联系我们找货
DT050TFT-PTS
  • 1+689.340501+83.33160
  • 10+598.2401010+72.31880
