1056
    ADAFRUIT
    Ф10mm
    HOLDER BATT COIN 1220 12.5MM SMD
1056 数据手册
Sign In SHOP BLOG LEARN FORUMS 0 Items   VIDEOS COMPONENTS & PARTS / LASERS / TTL LASER DIODE - 5MW 650NM RED - 50KHZ MAX TTL Laser Diode 5mW 650nm Red 50KHz Max PRODUCT ID: 1056 49 IN STOCK ADD TO CART 1 1-9 10-99 100+ ADD TO WISHLIST DESCRIPTION TECHNICAL DETAILS DESCRIPTION You have some frickin' sharks at your lair, and you're thinking "it would be really great if I could attach some lasers to them" and then you see these little laser diode modules: what great timing! These encapsulated laser diodes are Class IIIa 5mW, with a 650nm red wavelength. They can be driven from 4.8V to 5.2V so they're great for your embedded electronics project. This module in particular is designed to be modulated/pulsed via the yellow wire. So you can use these for laser light shows, laser harps, 'wireless' communications and data transmission, electronic 'trip wires', laser-vision guidance, and more! Simply connect 5V power to the red and black wires, and pull the yellow wire to 5V or ground to turn on and off, respectively. You will be lasing in no time. Please note: this is not a laser pointer. It's a diode with integrated driver. You still need a 5VDC power supply. These diodes are 5mW output, and have a safety label marked on them. For more information on laser safety and ratings check out the Wikipedia page TECHNICAL DETAILS Weight: 11.85g Diameter: 10.11mm Length: 32.82mm Wire length: 100mm 650nm wavelength 4.8 - 5.2V DC voltage input 35mA max current draw Max TTL frequency: 50KHz Operating temperature -10°C to 40°C; MAY WE ALSO SUGGEST... Adjustable Laser Mounting Stand Laser Diode - 5mW 650nm Red Cross Laser Diode - 5mW 650nm Red Fixed Laser Mounting Stand DISTRIBUTORS CONTACT SUPPORT DISTRIBUTORS EDUCATORS Line Laser Diode - 5mW 650nm Red EXPAND TO SEE DISTRIBUTORS "Get as much education as you can. Nobody can take that away from you" - Eben Upton JOBS FAQ SHIPPING & RETURNS TERMS OF SERVICE PRIVACY & LEGAL ABOUT US ENGINEERED IN NYC Adafruit ® 4.9
很抱歉,暂时无法提供与“1056”相匹配的价格&库存,您可以联系我们找货
