34-0581
    VCC
    INDPMINEONRED6"
34-0581 数据手册
34 Series Indicator Light for 0.375” (9.5mm) Diameter Hole Round indicator lights with internal cylindrical flat top lens and housing in one piece for 3/8” panel mounting hole Applications • • panel indication electrical panels • • entertainment industrial • • appliances displays Key features • 3/8” (0.375”) diameter mounting hole • one piece housing with integral cylindrical blue, white, clear and amber • AC or DC volts options: incandescent (6, 14 and 28V) or neon (125 and 250 V) • up to 25,000 hours of lifetime • wire leads: 6” (152.4mm), #18 AWG, bare cooper, PVC insulated, black, UL/CSA rated 105°C, 600V, UL 1015, stripped 1/2” • UL listed: File E20356 Dimensions 1.552 [39.42] 0.409 [10.39] 0.250 [6.35] mounting hole (dia.) Ø 0.375 Ø [9.53] 0.375 [9.53] 0.344 [8.74] Dimensions in inches [mm] engineered to light up your design www.vcclite.com LC&D® and Leecraft® are registered trademarks of Visual Communications Company, LLC. 1.800.522.5546 07/15 Rev 1 Product specifications and ordering data Material Installation specification One piece lens/housing Nylon Zytel 6/6 Wire leads Bare Cooper, PVC, 18-11C UL1015-1230, 105°C 600V Material Lens Color Mounting hole Panel thickness (minimum) 0.375” (9.525mm) 0.020” (0.508mm) Wire leads #18 AWG, 6” length Luminosity Lamp Type Life (hours) 400 mcd 34-0581 Neon 34H-0581 Neon 200 mcd 34G1-0581 Incandescent 550 mcd 34G3-0581 Incandescent 500 mcd 34G18-0581 Incandescent 300 mcd 34-0582 Neon 400 mcd 34H-0582 Neon 200 mcd 34G1-0582 Incandescent 550 mcd 34G3-0582 Incandescent 500 mcd 34G18-0582 Incandescent 300 mcd 34-0583 Neon 400 mcd 34H-0583 Neon 200 mcd 34G1-0583 Incandescent 550 mcd 34G3-0583 Incandescent 500 mcd 34G18-0583 Incandescent 300 mcd 34-0584 Neon 400 mcd 34H-0584 Neon 200 mcd 34G1-0584 Incandescent 550 mcd 34G3-0584 Incandescent 500 mcd 34G18-0584 Incandescent 300 mcd 34-0585 Neon 400 mcd 34H-0585 Neon 200 mcd 34G1-0585 Incandescent 550 mcd 34G3-0585 Incandescent 500 mcd 34G18-0585 Incandescent 300 mcd 34-0587 Neon 400 mcd 34H-0587 Neon 200 mcd 34G1-0587 Incandescent 550 mcd 34G3-0587 Incandescent 500 mcd 34G18-0587 Incandescent 300 mcd engineered to light up your design Voltage (V) P (W) or I (A) www.vcclite.com LC&D® and Leecraft® are registered trademarks of Visual Communications Company, LLC. 1.800.522.5546 07/15 Rev 1 Accessory options Optional push-on speed nut, which secures the indicator in place Part Number 8700431688 Description: Speednut 3400-6 • One piece, self-locking, heat-treated, spring-steel fastener that replace threaded nut, lock washer or spanner washer. • Eliminates timeconsuming assembly operations. • Fast and easy to apply, the speed nut fastener provides maximum holding power at minimum cost per fastener. • It does not shake loose from vibration, yet can be easily loosened without worry about rust-frozen screw threads. • For smaller components where space is premium. • Requires less torque than standard hex-nuts. • Can be installed prior to painting processes so threads won't fill. .56 [14.22] .75 [19.05] Dimensions in inches [mm] Installation Specification Material Speed Nut (one piece) Spring Steel Stud Size 0.375” (9.525mm) Compliance & approvals engineered to light up your design www.vcclite.com LC&D® and Leecraft® are registered trademarks of Visual Communications Company, LLC. 1.800.522.5546 07/15 Rev 1
34-0581 价格&库存
很抱歉,暂时无法提供与“34-0581”相匹配的价格&库存,您可以联系我们找货
