34 Series Indicator Light for
0.375” (9.5mm) Diameter Hole
Round indicator lights with internal cylindrical flat top
lens and housing in one piece for 3/8” panel mounting hole
Applications
panel indication
electrical panels
entertainment
industrial
appliances
displays
Key features
• 3/8” (0.375”) diameter mounting hole
• one piece housing with integral cylindrical
blue, white, clear and amber
• AC or DC volts options: incandescent (6, 14
and 28V) or neon (125 and 250 V)
• up to 25,000 hours of lifetime
• wire leads: 6” (152.4mm), #18 AWG, bare cooper, PVC
insulated, black, UL/CSA rated 105°C, 600V, UL 1015,
stripped 1/2”
• UL listed: File E20356
Dimensions
1.552
[39.42]
0.409
[10.39]
0.250
[6.35]
mounting hole (dia.)
Ø 0.375
Ø [9.53]
0.375
[9.53]
0.344
[8.74]
Dimensions in inches [mm]
engineered to light up your design
www.vcclite.com
LC&D® and Leecraft® are registered trademarks of Visual Communications Company, LLC.
1.800.522.5546
07/15 Rev 1
Product specifications and ordering data
Material
Installation specification
One piece lens/housing Nylon Zytel 6/6
Wire leads
Bare Cooper, PVC, 18-11C
UL1015-1230, 105°C 600V
Material
Lens Color
Mounting hole
Panel thickness (minimum)
0.375” (9.525mm)
0.020” (0.508mm)
Wire leads
#18 AWG, 6” length
Luminosity
Lamp Type
Life (hours)
400 mcd
34-0581
Neon
34H-0581
Neon
200 mcd
34G1-0581
Incandescent
550 mcd
34G3-0581
Incandescent
500 mcd
34G18-0581
Incandescent
300 mcd
34-0582
Neon
400 mcd
34H-0582
Neon
200 mcd
34G1-0582
Incandescent
550 mcd
34G3-0582
Incandescent
500 mcd
34G18-0582
Incandescent
300 mcd
34-0583
Neon
400 mcd
34H-0583
Neon
200 mcd
34G1-0583
Incandescent
550 mcd
34G3-0583
Incandescent
500 mcd
34G18-0583
Incandescent
300 mcd
34-0584
Neon
400 mcd
34H-0584
Neon
200 mcd
34G1-0584
Incandescent
550 mcd
34G3-0584
Incandescent
500 mcd
34G18-0584
Incandescent
300 mcd
34-0585
Neon
400 mcd
34H-0585
Neon
200 mcd
34G1-0585
Incandescent
550 mcd
34G3-0585
Incandescent
500 mcd
34G18-0585
Incandescent
300 mcd
34-0587
Neon
400 mcd
34H-0587
Neon
200 mcd
34G1-0587
Incandescent
550 mcd
34G3-0587
Incandescent
500 mcd
34G18-0587
Incandescent
300 mcd
Voltage (V) P (W) or I (A)
www.vcclite.com
1.800.522.5546
07/15 Rev 1
Accessory options
Optional push-on speed nut, which secures the indicator in place
Part Number 8700431688
Description: Speednut 3400-6
• One piece, self-locking, heat-treated, spring-steel fastener that replace threaded nut, lock washer or spanner
washer.
• Eliminates timeconsuming assembly operations.
• Fast and easy to apply, the speed nut fastener provides maximum holding power at minimum cost per fastener.
• It does not shake loose from vibration, yet can be easily loosened without worry about rust-frozen screw threads.
• For smaller components where space is premium.
• Requires less torque than standard hex-nuts.
• Can be installed prior to painting processes so threads won't fill.
.56
[14.22]
.75
[19.05]
Installation Specification
Material
Speed Nut (one piece)
Spring Steel
Stud Size
0.375” (9.525mm)
Compliance & approvals
www.vcclite.com
1.800.522.5546
07/15 Rev 1
很抱歉,暂时无法提供与“34-0583”相匹配的价格&库存,您可以联系我们找货
