588
    ADAFRUIT
    THERMAL BONDING FILM 16"X60 YD
588 数据手册
Page 1 of 2 EL WIRE/TAPE/PANEL / EL STARTER PACKS EL wire starter pack - Pink 2.5 meter (8.2 ft) PRODUCT ID: 588 Page 2 of 2 DESCRIPTION - A little bundle to get you started! This project pack contains: • 2.5 meters (over 8 ft) of high-brightness, long-life EL wire in Pink. 2.5 meters is the maximum amount for the pocket driver - it is cut and soldered so it's ready to go! • Pocket EL inverter runs on 2 AA Alkaline or rechargeable batteries (not included) • 2 inches of heat shink, both 1/8" and 1/4" for protecting the EL wire after soldering if you end up wanting to change the wire up • 2 inches of copper tape, used when soldering EL wire • 2 inches of foam tape, we use this to pad the inside of the inverter to quiet it down We used this to make our awesome TRON bag Soldering to EL wire is a little tricky but luckily we wrote a detailed step-by-step tutorial! You'll need wire strippers, a soldering iron & solder, copper tape and heat shrink. A third-hand tool is really useful as well. Please note! EL tape, EL wire and EL panel are made with different processes - the color and brightness will not be consistent between the different types of EL products. The EL tape will not match the EL wire or EL panel exactly, they all will be slightly different colors. http://www.adafruit.com/products/588 7/24/2015
很抱歉,暂时无法提供与“588”相匹配的价格&库存,您可以联系我们找货
    • 250+174.53338
