Page 1 of 2
EL WIRE/TAPE/PANEL / EL STARTER PACKS
EL Flowing Effect Wire with Inverter - Green
2.0 meter (6.5 ft)
PRODUCT ID: 952
Page 2 of 2
DESCRIPTION
If you want to make your EL project a little more dynamic, you can swap in this
nifty 'flowing effect' EL wire for the every-day stuff. Instead of a single core, this
wire is actually a bundle of three thin EL wires. Inside the inverter is a little timer
that will cycle through the strands to make it look like its moving. There's a wheel
to adjust the speed and a button to select the mode. The three modes are 'all on',
'all off' and 'flow effect'
This pack comes with 2 meters of EL flow wire attached to a 2xAA inverter, use any
AA batteries (alkalines are better and brighter but it works fine with the NiMH
rechargeables we tried). There's a belt clip on the inverter so you can attach it to
something. This EL type isn't meant to be cut and re-soldered because of the
triple-core so keep in mind that you can cut it short but we don't suggest trying to
splice or re-solder to the wire. Lasts about 5 hours on a set of batteries
http://www.adafruit.com/products/952
7/27/2015
很抱歉,暂时无法提供与“952”相匹配的价格&库存,您可以联系我们找货
