Page 1 of 2
EL WIRE/TAPE/PANEL / EL STARTER PACKS
EL Flowing Effect Wire with Inverter - Blue
2.0 meter (6.5 ft)
PRODUCT ID: 948
Page 2 of 2
DESCRIPTION
If you want to make your EL project a little more dynamic, you can swap in this
nifty 'flowing effect' EL wire for the every-day stuff. Instead of a single core, this
wire is actually a bundle of three thin EL wires. Inside the inverter is a little timer
that will cycle through the strands to make it look like its moving. There's a wheel
to adjust the speed and a button to select the mode. The three modes are 'all on',
'all off' and 'flow effect'.
This pack comes with 2 meters of EL flow wire attached to a 2xAA inverter, use any
AA batteries (alkalines are better and brighter but it works fine with NiMH
rechargeables). There's a belt clip on the inverter so you can attach it to something.
This EL type isn't meant to be cut and re-soldered because of the triple-core so
keep in mind that you can cut it short but we don't suggest trying to splice or resolder to the wire. Runs for about 5 hours off of two AA batteries.
Please note! EL tape, EL wire and EL panel are made with different processes - the
color and brightness will not be consistent between the different types of EL
products. The EL flow wire will not match the regular EL wire, EL tap or EL panel
exactly, they all will be slightly different colors.
http://www.adafruit.com/products/948
7/27/2015
很抱歉,暂时无法提供与“948”相匹配的价格&库存,您可以联系我们找货
