333
    ADAFRUIT
    Round Standoff Threaded #4-40 Brass 0.625" (15.88mm) 5/8" Yellow
333 数据手册
Page 1 of 2 SENSORS / TOUCH Touch screen (Nintendo DSL digitizer) PRODUCT ID: 333 Page 2 of 2 DESCRIPTION - Want to poke at your projects? This resistive touch screen can be used with a stylus or fingertip and is easy to use with a microcontroller. You can put it over a paper overlay for a touch control panel or attach it to an LCD to DIY a touch-activated display. • • • • • • its 2.2" x 2.75" (55mm x 70mm) overall dimensions, 1.5mm thick 3.2" diagonal active area, 80mm 600 ohms across X pins, 300 ohms across Y pins 4 wire resistive display, on a 0.5mm FPC connector Use any microcontroller with 2 digital pins and two analog input pins Adhesive backing, it fits onto our ST7565 LCD (not as well on a KS0108 LCD, a little too small) The connector is very fine so we suggest using our touch screen breakout board to make it easier to connect. We don't have a detailed tutorial yet but we do have great example Arduino library code that shows how to get readings, debounce, and read the pressure (so you can detect when its being touched and how hard) The code is not complex and is easily ported to other microcontrollers. To understand how touchscreens work, and the techniques used to read from them, we suggest this great app note http://www.adafruit.com/products/333 7/21/2015
很抱歉,暂时无法提供与“333”相匹配的价格&库存,您可以联系我们找货
