LED CONTROLLER
The LED Dual Remote Controller is designed for
LED lighting control. It can control modules,
LED ribbons, LED bars, High Power LED modules
and other LED lighting fixtures.
FEATURES
Seven Button Wireless Remote Control.
Common Anode CMOS Outputs.
Multiple Controllers with One Remote
RATINGS
CHARACTERISTICS
Input Voltage
Load Current
Operating Temperature
UNIT
Volts DC
Amps
degrees C
MINIMUM
TYPICAL
12
MAXIMUM
24
10
60
-20
55.6mm
(2.20")
65.0mm
(2.56")
114.0mm
(4.50")
56.0mm
(2.20")
OUTPUT
INPUT
WW CW V+ V+ V-
DIMENSIONS ARE FOR REFERENCE ONLY.
JKL PART NO.: ZCTR-05
METRIC
DIMENSIONS ARE
IN mm (INCHES)
TOLERANCE UNLESS
OTHERWISE SPECIFIED
THIRD ANGLE
PROJECTION
A NEW DESIGN & PHOTO
RELEASE
REV.
NO.
DESCRIPTION/ECO
NUMBER
DRAWN BY
APPV'D BY
7/10/14
L. WENGSTROM L.R.
3/31/14
APPV'D
DATE
REF.
1 PL +/2 PL +/ANGLE +/-
DATE
7/10/14
- CAD DRAWING -
MANUAL REVISIONS NOT PERMITTED
COMPONENTS CORPORATION
TITLE
LED DUAL WHITE CONTROLLER
SIZE
A
SCALE
FSCM NO.
55335
NONE
DRAWING
NO.
RELEASED
DATE
ZCTR-05
3/31/14
REVISION
DATE
7/10/14
REV.
NO.
A
SHEET
1
OF
2
The ZCTR-05 is a multi-function touch LED remote control with a receiver controller for dual
color temperature LED flex ribbon. It is used to adjust the warmth of color seen as well as the
brightness of the LEDs. In conjunction with the ZFS-105000-DBW flex ribbon the controller
can adjust the color temperature of the flex ribbon from 6000°K to 3000°K continuously and
adjust the brightness from 100% to 20%. Once the light color and brightness is set the
controller’s memory will retain the setting even after the power has been turned off.
The ZCTR-05 receiver controller can handle up to 10 Amps of load, 5.0 Amps for each color
string, with either 12 Volts DC or 24 Volts DC for the input voltage. This is equivalent to
running 11.9 meters or 39 feet of the ZFS-105000-DBW. Other flex ribbons or ridged bars can
be used; please consult with your JKL company representative for information on how to use
other LED devices with the ZCTR-05 controller.
The ZCTR-05 controller is easy to set-up and use. The remote control needs 3 AAA batteries
(supplied) placed in it and the cover snapped shut. The LED flex ribbon should be placed out
where it is to be used and the wiring should be connected to the receiver controller. The tan wire
should be connected to the V+ on the output of the controller box. The center white wire should
be connected to the CW output and the outside white wire should be connected to the WW
output. Power can be applied by connecting a power supply to the input terminal of the
connector making sure that the red or positive line goes to the “+”terminal and the black or
negative line goes to the “–“terminal. Apply power to the power supply and the system is ready
to use. There are two more buttons on the receiver controller. One labeled “match” and the
other labeled “function”. The match button allows the user to match multiple controllers to one
remote control increasing the amount of light controlled by one remote control. Different areas
or equipment can be synced together to form a unified lighting field. The function key will
adjust the color temperature of the individual controller’s LEDs from cool white to warm white
in 11 steps and in 10 % increments.
With the remote control held in your hand with the red and green buttons to the top and the large
circle to the bottom press the red button in the center of the remote control to turn on the LEDs.
To turn off the LEDs press the same button. The top green button will give 100% brightness
when pressed, the right green button will give 75% of the total amount of light, the bottom
button will give 50% of the total amount of light, and the left button will give 25% of the total
amount of light. To control the color temperature of the light use the right half of the circle by
placing a finger on the circle and moving it up or down the circle to change the color of the light.
Up will make the light a warmer color and down will make the light cooler. The brightness can
also be controlled by using the left half of the circle. Up will make the light brighter and as you
slide your finger down the left side of the circle the light will get dimmer.
There are several precautions that should be taken while planning and assembling the light
ribbon, controller, and power supply. Make sure the power supply is of the constant voltage
type. Plan the installation of the controller in a well-ventilated area so the controller temperature
will not rise above the maximum operating temperature. Make sure all connections are tight,
loose connections can lead to overheating and fires. Make sure all connections are done
correctly; all positive indications connected together, all negative indications connected together.
Do not connect the power to the power supply until all other connections are completed first.
Turn off the power before making any changes to the system.
SIZE
A
FSCM NO.
55335
DRAWING
NO.
ZCTR-05
SHEET
2 OF 2
很抱歉,暂时无法提供与“ZCTR-05”相匹配的价格&库存,您可以联系我们找货
