REV.
B
DESCRIPTION
DATE
02/27/04
Engineering Update w/o Changes
APPROVED
M. C.
0.070 [1.8mm]
0.150 [3.8mm]
TYP.
0.360 [9.1mm]
1.800 [45.7mm]
0.150 [3.8mm]
TYP.
Ø.049+.003 TYP.
-.002
Ø.032+.003
-.002 TYP.
0.150 [3.8mm]
0.050 [1.3mm]
0.100 [2.5mm]
Recommended Mounting Holes for 12 Station of H-XRV-X
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
2. MATERIAL: NYLON 6/6, 94V-0, BLACK. BIVAR MATERIAL CODE 22-BK.
RTP POLYAMIDE NYLON 6/6, 0200 FR, BLACK OR MODIFIED PLASTICS MN6/6-SE BK.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
Shane Irving
CHECKED:
Shane Irving
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
05/05/99
DATE:
02/27/04
FAX: (949) 951-3974
H-3RV SERIES
12 STATION COUPLING BAR
PART NO:
REVISION:
H-3RVC
CAGE CODE : 32559
B
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“H-3RV-C”相匹配的价格&库存,您可以联系我们找货
