6010M, 6011M, 6012M, 6013M and 6091M Series
Oil-Tight Non-Relampable Neon-LED Indicator Lights
Description and Features
All dimensions
in inches (mm)
.38 (9.7)
Solid-state indicator lights complete with built-in current-limiting
resistor and rectifier diode.
Ø.63 (16.0)
Ø.39 (9.9)
Meets NEMA Class 13
Mounting: Ø.380(9.65) hole. Supplied with internal tooth lock washer
and hex nut.
.11(2.8)
Wire Leads: Neon Models: No. 18 AWG (105°C) 4.4 (111.8)/4.8
(121.9) long, stripped .43 (10.9)/.57 (14.5)
LED Models: No. 22 AWG (105°C) 4.4 (111.8)/4.8
O-RING
(SUPPLIED)
.50 (12.7)
3/8-24 THREAD
1.60 (40.6)
Lens: Polycarbonate
Bezel: Polished stainless steel.
Gaskets: Buna-N
Housing: Black Nylon
BASE:
POLYCARBONATE
Mounting Hole: "D" flat is optional
Panel Thickness: .03 (.8)/.25 (6.4)
.375 (9.53)/.380 (9.65)
.350 (8.89)/.355 (9.02)
Neon Indicator
Lens Color
Model No.
Model No.
LED Solid State Indicator
Lens Color
Model No.
Model No.
Incorporates
LED**
(105-125VAC)
(208-250VAC)
for 12V
for 24V
Red
6010M1
6011M1
Red
6091M1-12V
6091M1-24V
4304H1
Amber
6010M3
6011M3
Green
6091M5-12V
6091M5-24V
4304H5
Green
6012M5*
6013M5*
Yellow
6091M7-12V
6091M7-24V
4304H7
Internal
Resistor
(ohms)
390
Lamp used
C2A+Resistor
C2A+Resistor
Lamp Color
Black
1 Black/1 Red
* Incorporates G2B lamp and resistor.
Underwriters Laboratories (UL) File
No. E20356
engineered to light up your design
1000
**Note: Also incorporates IN4004 (400 P.I.V.) rectifier
diode. Red lead positive.
www.vcclite.com
1.800.522.5546
02/15 Rev 1
很抱歉,暂时无法提供与“6091M1-24V”相匹配的价格&库存,您可以联系我们找货
