engineered to light up your design
www.vcclite.com
1.800.522.5546
2191L Series Non-Relampable LED Solid-State Indicator Lights
Description and Features
Solid-state indicator lights complete with built-in currentlimiting resistor and rectifier diode.
.380
.340
Mounting: Ø.310 MIN., supplied with push-on
speednut SN1287.
.090
Wire Leads: No. 22 AWG (105°C) 4.40/4.80 long,
stripped .430/.570
Lens: Polycarbonate
1.310
Anode(+): Red lead
Bezel: Polished stainless steel.
Ø.310 MAX.
Housing: White Nylon
All dimensions
in inches.
Lens C olor
R ed
G reen
Y ellow
Internal R es is tor
(ohms )
Model No.
(6V )
2191L1-6V
2191L5-6V
2191L7-6V
LE D S olid S tate Indicator
Model No.
(12V )
2191L1-12V
2191L5-12V
2191L7-12V
150
390
V oltage T able
Nominal
V AC
6V
12V
24V
5 to 11
10 to 20
22 to 32
V DC
3.5 to 6.5
6 to 13.5
12 to 24
Model No.
(24V )
2191L1-24V
2191L5-24V
2191L7-24V
1000
Lens C olor
Incorporates LE D*
R ed
4304H1
G reen
4304H5
Y ellow
4304H7
* Also incorporates 1N4004
(400 P.I.V.) rectifier diode.
To use 24V model: Beyond 32VAC add 30 ohms
per volt; beyond 24 VDC add 50 ohms per volt.
Use 1/2W resistor up to 50V; 1W resistor for 50V
to 70V; 2W resistor for 75V to 125V. Do not use
beyond 125V.
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“2191L5-6V”相匹配的价格&库存,您可以联系我们找货
