5110F1-5V
5110F1-5V
    VCC
    LED Panel Indicator Red Diffused 5V 20mA Round with Domed Top, 3mm (T-1) Wire Leads
5110F1-5V 数据手册
5110F Series Panel Mount LED Indicator Light for mounting hole 0.157” (4.0mm) Press fit round indicator light for super bright LED T-1 (3 mm) Applications panel indication electrical panels • • • • entertainment industrial • • appliances displays Key features • • • • • • super bright T-1 (3mm) LED • include low current option (2mA) 4 colors available: red, green, yellow, amber voltage options: 2, 5 or 12V volt supply, no external resistor needed. • recommended the use of an installation tool to Product dimensions Ø.190 [Ø 4.8] LED T-1 .190 max [4.8 max] .41 [4.8] .03 [0.8] Ø.157” [Ø 4.0] Housing Mounting Hole Wire Leads Dimensions in inches [mm] engineered to light up your design www.vcclite.com CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. 1.800.522.5546 07/15 Rev 1 Product specifications and ordering data Electro-optical Characteristics 12V 5V Low Current Standard Part Number Color Typ. Intensity Rated Current (mcd) (mA) Continuous Foward Current Max. (mA) Forward Voltage Typ. (V) Forward Voltage Max. (V) Peak Forward Reverse Current @ Break-down 1ms- 300pps Voltage Min. (V) (A) Peak Wavelenght (nm) 5110F1 Red 10.0 10 30 2.0 3.0 1.0 5 635 5110F5 Green 16.0 20 30 2.2 3.0 0.09 4 562 5110F7 Yellow 6.3 20 30 2.1 3.0 1.0 5 585 5110F1LC Red 2.5 2 7 1.8 2.2 0.007 5 635 5110F5LC Green 2.1 2 7 1.8 2.2 0.007 5 565 5110F7LC Yellow 1.8 2 7 1.9 2.7 0.007 5 583 5110F1-5V Red 8.0 10 20 5 7.5 - 5 655 5110F3-5V Amber 8.0 10 15 5 7.5 - 5 583 5110F5-5V Green 8.0 10 15 5 7.5 - 5 565 5110F1-12V Red 8.0 13 20 12 15 - 5 655 5110F3-12V Amber 8.0 13 20 12 15 - 5 583 5110F5-12V Green 8.0 13 20 12 15 - 5 565 Material Housing Wire Leads Operating parameters Operating temperature Installation specification Nylon (Black) 0.009” (0.23mm) Wall PVC, Red (Anode), Black (Cathode) Mounting hole Panel thickness (minimum) 0.155/0.158” (3.94/4.01mm) 0.031/0.062” (0.79/1.58mm) Wire leads 4.4” (111.8) min. long, #26 AWG, stripped 0.250” Anode (+) Red lead -13°F (-25°C) to 185°F (85°C) Compliance & approvals engineered to light up your design www.vcclite.com CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. 1.800.522.5546 07/15 Rev 1
5110F1-5V 价格&库存
很抱歉,暂时无法提供与“5110F1-5V”相匹配的价格&库存,您可以联系我们找货
5110F1-5V
    • 5+3.38826
