engineered to light up your design
www.vcclite.com
1.800.522.5546
2191QU Series Non-Relampable LED Solid-State Indicator Lights
Description and Features
All dimensions
in inches.
.380
Solid-state indicator lights complete with built-in currentlimiting resistor and rectifier diode.
Mounting: Ø.310 MIN., supplied with push-on
speednut SN1287.
.090
.280
Terminals: Quick-connect, tinned brass .187 x .020
Lens: Polycarbonate
Anode(+): Marked above terminal
1.310
Bezel: Polished stainless steel.
Ø.310 MAX.
Housing: White Nylon
.690
Lens C olor
R ed
G reen
Y ellow
Internal R es is tor
(ohms )
.187 T E R MINALS
LE D S olid S tate Indicator
Model No.
Model No.
(12V )
(24V )
2191QU 1 -12V
2191QU 1 -24V
2191QU 5 -12V
2191QU 5 -24V
2191QU 7 -12V
2191QU 7-24V
390
1000
V oltage T able
Nominal
V AC
12V
24V
10 to 20
22 to 32
V DC
6 t o 13.5
12 to 24
Lens C olor
Incorporates LE D*
R ed
4304H1
G reen
4304H5
Y ellow
4304H7
* Also incorporates 1N4004
(400 P.I.V.) rectifier diode.
To use 24V model: Beyond 32VAC add 30 ohms
per volt; beyond 24 VDC add 50 ohms per volt.
Use 1/2W resistor up to 50V; 1W resistor for 50V
to 70V; 2W resistor for 75V to 125V. Do not use
beyond 125V.
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“2191QU7-12V”相匹配的价格&库存,您可以联系我们找货
