22mm TuffLED™
Panel Mount Indicator
Ruggedized CNX 722 Series with built-in LED offers fast, easy
installation in harsh environments
Applications
control cabinets
instrument panels
disinfection and sterilization environments
transportation dashboards
switch stations
safety applications
outdoor signage
aircraft and military
industrial machinery
vending and gaming machines
wide angle viewable
resistant to shock and vibration
custom LEDs and lens colors available
optional bezel available in many colors
moisture sealed, IP 67/NEMA 6P rated
RoHS compliant
Key features
• designed for extreme harsh and outdoor environments
• variety of connection options for fast, easy installation
• built-in LED can be used with 5, 12 or 24 volt D/C
circuits
• fast pitch threads ease assembly, requiring only1 turn
or with 1” hextool
• special nut assembles by
• direct sunlight visibility
Product dimensions
1.06 in[26.9mm]
o 1.01 in[25.6mm]
.86 in[21.9mm]
Indicator
Assemblies
.81 in[20.6mm]
o 1.26 in[32mm]
.50 in[12.8mm]
.47 in[11.8mm]
6 in[152.4mm]
.12 in[3mm]
Bezels
o 1.26 in[32mm]
engineered to light up your design
www.vcclite.com
1.800.522.5546
Product specifications
LED color**
red
green
white
blue
yellow
body
retaining nut
wire
moisture seal
bezel- plastic
bezel- metal
LED output
typ intensity, mcd
1300-1900
700-1400
1300-1700
200-280
80-200
Installation specification
mounting hole .855-.910” (21.7-23.1mm)
panel
Up to .300” (7.6mm)
thickness
Operating parameters
operating
-40°F (-40°C) to
temperature
176°F (80°C)
current
20mA
Materials
polycarbonate, UL 94-V2
PBT/glass filled, UL 94-V0
22 AWG 1007/1569
EPDM
ABS, UL 94-HB
aluminum alloy
Ordering data
CNX 722 22mm indicator
ordering code (example)
Body Type
X= material
C colored*
N
clear
*Body color to match
LED color
CNX 722 X X00 XX X
LED Color
X00=
color
200
red
400
yellow
500
green
600
blue
900
white
Voltage
input
XX=
voltage
05
5VDC
12
12VDC
24
24VDC
Bezel Color
*Optional bezel: BZL 722-X
Bezel size = 22mm
*Sold Separately
Termination Style
X=
termination style
B
screw block
quick disconnect/
T
terminals
W
wire leads
www.vcclite.com
X=
4
5
6
9
A
B
C
color
black
red
yellow
green
blue
white
actual aluminum
brushed aluminum
chrome
1.800.522.5546
很抱歉,暂时无法提供与“CNX722N20024B”相匹配的价格&库存,您可以联系我们找货
