GB02SHT03-46
High Temperature Silicon Carbide
Power Schottky Diode
VRRM
IF (Tc=25°C)
QC
Features
Package
RoHS Compliant
300 V Schottky rectifier
210 °C maximum operating temperature
Zero reverse recovery charge
Superior surge current capability
Positive temperature coefficient of VF
Temperature independent switching behavior
Lowest figure of merit QC/IF
Available screened to Mil-PRF-19500
300 V
4A
9 nC
1
2
TO – 46
Advantages
Applications
High temperature operation
Improved circuit efficiency (Lower overall cost)
Low switching losses
Ease of paralleling devices without thermal runaway
Smaller heat sink requirements
Industry’s lowest reverse recovery charge
Industry’s lowest device capacitance
Ideal for output switching of power supplies
Best in class reverse leakage current at operating temperature
Down Hole Oil Drilling
Geothermal Instrumentation
Solenoid Actuators
General Purpose High-Temperature Switching
Amplifiers
Solar Inverters
Switched-Mode Power Supply (SMPS)
Power Factor Correction (PFC)
Maximum Ratings at Tj = 210 °C, unless otherwise specified
Parameter
Repetitive peak reverse voltage
Continuous forward current
RMS forward current
Surge non-repetitive forward current, Half Sine
Wave
Non-repetitive peak forward current
2
I t value
Power dissipation
Operating and storage temperature
Symbol
VRRM
IF
IF
IF(RMS)
Conditions
TC = 25 °C
TC ≤ 180 °C
TC ≤ 180 °C
Values
300
4
2
4
Unit
V
A
A
A
IF,SM
TC = 25 °C, tP = 10 ms
10
A
IF,max
2
∫i dt
Ptot
Tj , Tstg
TC = 25 °C, tP = 10 µs
65
0.5
64
-55 to 210
A
2
AS
W
°C
TC = 25 °C
Electrical Characteristics at Tj = 210 °C, unless otherwise specified
Parameter
Symbol
Diode forward voltage
VF
Reverse current
IR
Total capacitive charge
QC
Switching time
ts
Total capacitance
C
Conditions
IF = 1 A, Tj = 25 °C
IF = 1 A, Tj = 210 °C
VR = 300 V, Tj = 25 °C
VR = 300 V, Tj = 210 °C
IF ≤ IF,MAX
VR = 300 V
dIF/dt = 200 A/μs
VR = 300 V
Tj = 210 °C
VR = 1 V, f = 1 MHz, Tj = 25 °C
VR = 300 V, f = 1 MHz, Tj = 25 °C
min.
Values
typ.
1.6
2.6
1
5
9
< 17
76
15
max.
Unit
V
5
50
µA
nC
ns
pF
Thermal Characteristics
Thermal resistance, junction - case
RthJC
5.55
°C/W
0.6
Nm
Mechanical Properties
Mounting torque
Dec 2014
M
http://www.genesicsemi.com/high-temperature-sic/high-temperature-sic-schottky-rectifiers/
Pg 1 of 4
Figure 1: Typical Forward Characteristics
Figure 2: Typical Reverse Characteristics
Figure 3: Power Derating Curve
Figure 4: Current Derating Curves (D = tP/T, tP= 400 µs)
(Considering worst case Zth conditions )
Figure 5: Current vs Pulse Duration Curves at TC = 190 °C
Figure 6: Transient Thermal Impedance
Dec 2014
GB02SHT03-46
Pg 2 of 4
GB02SHT03-46
Package Dimensions:
TO-46
PACKAGE OUTLINE
NOTE
1. CONTROLLED DIMENSION IS INCH. DIMENSION IN BRACKET IS MILLIMETER.
2. DIMENSIONS DO NOT INCLUDE END FLASH, MOLD FLASH, MATERIAL PROTRUSIONS
Revision History
Date
Revision
Comments
2014/08/29
Initial release
Supersedes
Published by
GeneSiC Semiconductor, Inc.
43670 Trade Center Place Suite 155
Dulles, VA 20166
GeneSiC Semiconductor, Inc. reserves right to make changes to the product specifications and data in this document without notice.
GeneSiC disclaims all and any warranty and liability arising out of use or application of any product. No license, express or implied to any
intellectual property rights is granted by this document.
Unless otherwise expressly indicated, GeneSiC products are not designed, tested or authorized for use in life-saving, medical, aircraft
navigation, communication, air traffic control and weapons systems, nor in applications where their failure may result in death, personal
injury and/or property damage.
Dec 2014
Pg 3 of 4
GB02SHT03-46
SPICE Model Parameters
This is a secure document. Copy this code from the SPICE model PDF file on our website into a SPICE
software program for simulation of the GB02SHT03-46.
MODEL OF GeneSiC Semiconductor Inc.
$Revision:
1.0
$Date:
29-AUG-2014
43670 Trade Center Place Ste. 155
Dulles, VA 20166
COPYRIGHT (C) 2014 GeneSiC Semiconductor Inc.
ALL RIGHTS RESERVED
* These models are provided "AS IS, WHERE IS, AND WITH NO WARRANTY
* OF ANY KIND EITHER EXPRESSED OR IMPLIED, INCLUDING BUT NOT LIMITED
* TO ANY IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
* PARTICULAR PURPOSE."
* Models accurate up to 2 times rated drain current.
* Start of GB02SHT03-46 SPICE Model
.SUBCKT GB02SHT03ANODE KATHODE
D1 ANODE KATHODE GB02SHT03_25C; Call the Schottky Diode Model
D2 ANODE KATHODE GB02SHT03_PIN; Call the PiN Diode Model
.MODEL GB02SHT03_25C D
+ IS
3.57E-18
RS
0.49751
+ TRS1
0.0057
TRS2
2.40E-05
+ N
1
IKF
322
+ EG
1.2
XTI
3
+ CJO
9.12E-11
VJ
0.371817384
+ M
1.527759838
FC
0.5
+ TT
1.00E-10
BV
300
+ IBV
1.00E-03
VPK
300
+ IAVE
2
TYPE
SiC_Schottky
+ MFG
GeneSiC_Semiconductor
.MODEL GB02SHT03_PIN D
+ IS
5.73E-11
RS
0.72994
+ N
5
IKF
800
+ EG
3.23
XTI
-14
+ FC
0.5
TT
+ BV
300
IBV
1.00E-03
+ VPK
300
IAVE
2
+ TYPE
SiC_PiN
.ENDS
* End of GB02SHT03 SPICE Model
Dec 2014
Page 1 of 1
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
GeneSiC Semiconductor:
GB02SHT03-46
很抱歉,暂时无法提供与“GB02SHT03-46”相匹配的价格&库存,您可以联系我们找货
