SIT5001AI-GE-33VB-2.000000X 数据手册
Aug15, 2015
Manufacturing Notes for SiTime MEMS-Based
Silicon Timing Products
1 Introduction
These manufacturing notes apply to all of SiTime’s MEMS-based Silicon Timing products in
Quad, Flat No-Lead (QFN) package, SOT23-5 package, 2.0 x 1.2mm SMD, and WLCSP. The
information provided in this document is meant to assist customers with manufacturing set-up and
use of SiTime products designed into systems.
The materials used in the construction of SiTime’s products comply with Green standards. They
are compliant to RoHS and REACH163 requirements. Material composition reports are on file and
can be made available on request. No hazardous materials defined by OSHA are contained in the
products and MSDS reports are not required when using SiTime’s products.
All SiTime products have been qualified to JEDEC JESD47 requirements as they apply to the
type of product and packaging of the product. Reliability reports are available upon request from
your sales representative.
2 Device Packaging
Detailed mechanical dimensions for the various body sizes are provided in the data sheets as
Package Outline Drawings.
2.1 Package Marking Details - Standard Mark
The Standard Mark for all SiTime products is shown below. It contains an assembly location
code and lot code to allow tracing the manufacturing origin. This marking is used on all samples,
low volume, and mass production orders unless stipulated otherwise. The marking method is
laser mark.
The Smart Timing Choice™
1
Rev A08
Manufacturing Notes for SiTime Products
2.0x1.6 package marking diagram:
Assembly Identifier
AXXX
X
X = Mfg Lot Code
Pin 1 Indicator
Other packages marking diagram:
Assembly Identifier
Pin-1 Indicator
Mfg Lot Code
YXXXX
In the above diagrams, which show the “STANDARD MARK”:
“Y” denotes assembly identifier:
A as a first letter to indicate Vendor A (Carsem)
B as a first letter to indicate Vendor B (UTAC)
C as a first letter to indicate Vendor C (ASE)
“XXXX” denotes 4 alpha-numeric characters of the manufacturing lot code without any dashes,
periods, or symbols.
Top Marking Dimensions (otherwise indicated differently)
- All dimension are in mm
- Font type: LLGOTHIC_ STD or EO135P or EO145
- Tolerance for:
o Dimension X, X1, Y and Y1: +/- 0.25mm
o Dimension Y2: +/- 0.1mm
o Char Pitch: +/- 0.1mm
o Char Height: +/- 0.1mm
o Pin 1 Dot Diameter: +/- 0.1mm
o All other tolerances: +/- 0.20 mm
2
Rev A08
Figure 1. Standard Marking Dimensions For 2.5x2.0, 3.2x2.5, 5.0x3.2, 7.0x5.0mm, and
SOT23 Packages
X
Y
AXXX
Y2
X
Y1
X1
Figure 2. Standard Marking Dimensions for 2.0x1.6mm Package
Table 1. Marking Dimensions for Package Type
Package
X
X1
Y
Y1
Y2
Char
Height
Char
Pitch
Pin 1 Dot
diameter
2.5 x 2.0
0.30
0.30
0.85
0.25
N/A
0.45
0.35
0.25
0.40
0.35
0.16
SOT23
0.55
0.30
0.81
0.25
N/A
2.7 x 2.4
0.30
0.30
0.85
0.25
N/A
0.45
0.35
0.25
3.5 x 3.0
0.30
0.20
1.10
0.35
N/A
0.45
0.45
0.25
3.2 x 2.5
0.30
0.20
1.10
0.35
N/A
0.45
0.45
0.25
5.0 x 3.2
7.0 x 5.0
2.0 x 1.6
0.35
1.00
0.33
0.35
0.70
0.33
1.50
2.70
0.28
0.5
0.7
0.28
N/A
N/A
0.45
0.45
0.40
0.50
0.55
0.35
0.25
0.35
0.20
0.15
3
Rev A08
Figure 3. Standard Marking Dimensions for 2.0x1.2mm Package
Table 2. Marking Dimensions for SMD Package Type (2.0 mm X 1.2 mm)
Package
Char Height
2.0 x 1.2
0.38
Underline
Width
0.3
Char
Pitch
0.35
Pin 1
Diameter
0.14
4
X
Y
Y1
0.33 0.28 0.28
Rev A08
Font size tolerance: (+/- 0.05mm)
Marking shift tolerance: (+/- 0.15mm)
Figure 4. Standard Marking Dimensions for WLCSP Package
Table 3. Marking Dimensions for WLCSP Package
Height
Width
Space
Description Position Font Type
Pin 1 Dot
Line 1
Line 2
Dot
CX
XXX
NA
Left
Left
NA
S_X.FNT
S_X.FNT
0.15 mm 0.15 mm
0.20 mm 0.18 mm
0.20 mm 0.18 mm
5
Max
Marking
Width
Max
chars
NA
0.05 mm
0.05 mm
NA
0.41 mm
0.64 mm
Rev A08
NA
2
3
3 Product Packing
3.1 Tape & Reel
Carrier tape basic dimensions are based on EIA481. The pocket is designed to hold the part for
shipping and loading onto SMT manufacturing equipment, while protecting the body and the solder
terminals from damaging stresses. The individual pocket design can vary from vendor to vendor, but
width and pitch will be consistent.
Carrier tape is wound or placed onto a 7” or 13” shipping reel depending on the quantity of parts on
the reel and the package body size
The center hub design is large enough to ensure the radius formed by the carrier tape around it does
not put unnecessary stress on the parts.
Prior to shipping, parts are placed into the pockets of the carrier tape. A cover tape is sealed
over the top of the entire length of the carrier tape. The reel is sealed in a protective bag with a dry
N2 backfill.
The reel is made with high impact polystyrene and is anti-static material. It is possible that color of
the reels may be different in two different shipments depending on drop shipment location. However,
the specifications of the reel are identical. The carrier tape is made with polystyrene with carbon
impregnation and is static dissipative material. The cover tape is made with polystyrene antistatic
material.
6
Rev A08
Figure 5. Carrier Tape Dimensions
7
Rev A08
Figure 6. Reel Dimensions
8
Rev A08
Device orientation in the carrier tape is shown in the diagram below for all QFN and WLCSP
packages (Figure 7) and SOT23-5 (Figure 8).
Figure 7. Standard Tape and Reel Pin 1 orientation (all except for SOT-23)
Figure 8. SOT23 Tape and Reel Pin 1 orientation
Table 4 below provides the ordering details for tape and reel quantity, reel size, and top mark
options. The “Suffix” character is the last character in the part number string as shown in the
example below. Deviation from this table will be indicated via a custom part number (CS).
SIT8002AI-23-33E-30.00000Y
Suffix
Character
9
Rev A08
Table 4. Marking and Tape & Reel Option Selections with Part Number Coding
Suffix
Packaging Method
Package
Size (mm)
Reel Size
(inches)
M
Bulk
All
N/A
16mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
16mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
16mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
16mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
16mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
16mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
12mm Tape & Reel
7.0 x 5.0
5.0 x 3.2
3.2 x 2.5
2.7 x 2.4
2.5 x 2.0
7.0 x 5.0
5.0 x 3.2
3.2 x 2.5
2.7 x 2.4
2.5 x 2.0
7.0 x 5.0
5.0 x 3.2
3.2 x 2.5
2.7 x 2.4
2.5 x 2.0
3.2 x 2.5
2.7 x 2.4
2.5 x 2.0
2.0 x 1.6
3.2 x 2.5
2.7 x 2.4
2.5 x 2.0
2.0 x 1.6
3.2 x 2.5
2.7 x 2.4
2.5 x 2.0
2.0 x 1.6
7.0 x 5.0
5.0 x 3.2
3.2 x 2.5
2.7 x 2.4
2.5 x 2.0
7.0 x 5.0
5.0 x 3.2
3.2 x 2.5
2.7 x 2.4
2.5 x 2.0
7.0 x 5.0
5.0 x 3.2
3.2 x 2.5
2.7 x 2.4
2.5 x 2.0
13
13
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
13
13
7
7
7
7
7
7
7
7
7
7
7
7
7
V
Z
W
H
J
K
T
Y
X
Qty per Reel
Shipped in canister or ESD
bag or tube – any qty
3000
3000
3000
3000
3000
1000
1000
1000
1000
1000
250
250
250
250
250
3000
3000
3000
3000
1000
1000
1000
1000
250
250
250
250
3000
3000
3000
3000
3000
1000
1000
1000
1000
1000
250
250
250
250
250
10
Top Mark
2 Lines Frequency Mark
1 Line Standard Mark
Rev A08
Table 4 (cont.)
Suffix
D
E
G
S
Blank
Devices
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
8mm Tape & Reel
Package Size
(mm)
3.2 x 2.5
2.7 x 2.4
2.5 x 2.0
2.0 x 1.6
2.0 x 1.2
WLCSP
3.2 x 2.5
2.7 x 2.4
2.5 x 2.0
2.0 x 1.2
2.0 x 1.6
WLCSP
3.2 x 2.5
2.7 x 2.4
2.5 x 2.0
2.0 x 1.6
2.0 x 1.2
WLCSP
Reel Size
(inches)
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
13
13
Bulk
All
N/A
Packaging Method
Qty per Reel
3000
3000
3000
3000
3000
3000
1000
1000
1000
1000
1000
1000
250
250
250
250
10000
10000
Top Mark
Two Line Standard Mark
ESD bag or tube – any qty
Tape leader and trailer are per EIA-481-B as shown below:
Table 5. Leader and Trailer Lengths
All Reels
Minimum Length
Leader
400 mm
Trailer
160 mm
Peel Strength
The force required to peel off the cover tape from the carrier tape will fall within the range of 0.1
Newton to 1.3 Newton (10 grams to 130 grams) at a peeling speed to 300 mm per minute. This
complies with the EIA standard.
11
Rev A08
4 Storage and Handling
It is recommended that the sealed tape be stored in conditions where the environment does not
exceed:
→ Temperature: 40oC maximum
→ Relative humidity: 90% maximum
→ No direct exposure to sunlight
5 ESD
SiTime’s products are semiconductor based and as such have sensitivity to Electro-Static
Discharge. Care must be taken to insure careful handling to avoid damaging the components.
Reference to JEDEC document JESD625, Requirements for Handling Electrostatic-DischargeSensitive Devices. This standard establishes the minimum requirements for Electrostatic
Discharge (ESD) control methods and materials used to protect electronic devices that are
susceptible to damage or degradation from electrostatic discharge (ESD). The passage of a static
charge through an electrostatic-discharge-sensitive (ESDS) device can result in
catastrophic failure or performance degradation of the part. Device sensitivity to ESD is
determined by test methods such as EIA/JESD22-A114.
6 Moisture Sensitivity Level
All SiTime’s products have been qualified to Moisture Sensitivity Level 1 for Pb-Free devices per
JEDEC J-STD-020 and are deemed to not be moisture sensitive. This means partially
consumed reels may be stored indefinitely without re-sealing the protective storage bags in which
the reels are shipped in. It also means unused reels with a damaged bag seal may be used
without baking. Because the parts meet moisture sensitivity level 1, the protective storage bags in
which the reels are shipped do not require desiccant or HIC cards and are not required to
maintain a tight vacuum seal or dry nitrogen purge.
12
Rev A08
7 PCB Assembly Guidelines
7.1 Solder Reflow Profile
The solder reflow profile shown in Figure 9 is IPC/JEDEC J-STD-020 compliant and applies to all
SiTime packages; QFN, SOT23-5, 2.0x1.2 SMD, and WLCSP. Maximum reflow temperature is
260°C. An optimized reflow profile depends on several factors such as the solder paste, board
density, and type of reflow equipment used. Additional reflow information can be obtained from
solder paste vendor data sheets. It is recommended that any reflow profile be characterized with a
fully populated production PCB and thermocouple placed on or closest to the SiTime component
during profile. Thermocouples are generally used to record temperatures across the surface and
any sensitive components on the PCB. Ensure that a thermocouple is placed in contact with the
top surface of any moisture sensitive component to ensure maximum temperature is not
exceeded.
Figure 9. Convection Reflow Soldering Profile, per IPC/JEDEC J-STD-020
13
Rev A08
Table 6. High Temperature Infrared/Convection Reflow Conditions IPC/JEDEC J-STD-020
IPC/JEDEC Standard
IPC/JEDEC J-STD-020
Level 1
TS MAX to TL (Ramp-up Rate)
3°C/second Maximum
Preheat
- Temperature Minimum (TS MIN)
150°C
- Temperature Typical (TS TYP)
175°C
- Temperature Maximum (TS MAX)
200°C
- Time (tS)
60 - 180 Seconds
Ramp-up Rate (TL to TP)
3°C/second Maximum
Time Maintained Above:
- Temperature (TL)
217°C
- Time (TL)
60 - 150 Seconds
Peak Temperature (TP)
260°C Maximum
Target Peak Temperature (TP Target)
255°C
Time within 5°C of actual peak (tP)
20 - 40 seconds
Max. Number of Reflow Cycles
3
Ramp-down Rate
6°C/second Maximum
Time 25°C to Peak Temperature (t)
8 minutes Maximum
60 - 150 Seconds
260
60 - 150 Seconds
260
Note: Temperatures shown are applied to body of device.
Table 7. Manual Soldering Conditions
Manual Soldering (Iron)
350ºC Maximum for 3 seconds
Caution: Small package body parts heat up very
quickly and can be damaged
14
Rev A08
7.2 PCB Cleaning After Assembly
Cleaning PCB assemblies after reflow is a common process requirement to remove residual flux
and loose solder. No-Clean and water soluble fluxes are left behind and require removal to meet
assembly inspection standards. The package materials of the SiTime products are not
susceptible to water or other common solvents (alcohol and acetone) used for assembly
cleaning. SiTime recommends not using cleaning baths operating at ultrasonic frequencies.
Instead, SiTime recommends that the customer use IPA (Isopropyl Alcohol) baths.
8 Additional Questions?
If you have any questions about the information contained in this manufacturing note or other
manufacturing questions, please contact your sales representative.
SiTime Corporation
990 Almanor Avenue
Sunnyvale, CA 94085
USA
Phone: 4088-328-4400
http://www.sitime.com
© SiTime Corporation, 2013. The information contained herein is subject to change at any time without notice. SiTime
assumes no responsibility or liability for any loss, damage or defect of a Product which is caused in whole or in part by (I) use of any
circuitry other than circuitry embodied in a SiTime product, (ii) misuse or abuse including static discharge, neglect or accident, (iii)
unauthorized modification or repairs which have been soldered or altered during assembly and are not capable of being tested by
SiTime under its normal test conditions, or (iv) improper installation, storage, handling, warehousing or transportation, or (v) being
subjected to unusual physical, thermal, or electrical stress.
Disclaimer: SiTime makes no warranty of any kind, express or implied, with regard to this material, and specifically disclaims any
and all express or implied warranties, either in fact or by operation of law, statutory or otherwise, including the implied warranties of
merchantability and fitness for use or a particular purpose, and any implied warranty arising from course of dealing or usage of
trade, as well as any common-law duties relating to accuracy or lack of negligence, with respect to this material, any SiTime product
and any product documentation. Products sold by SiTime are not suitable or intended to be used in a life support applicat ion or
component, to operate nuclear facilities, or in other mission critical applications where human life may be involved or at stake.
15
Rev A08
