S380Y
S380Y
    GENESICSEMICONDUCTOR
    DO-205AB
    Diode Standard 1600V (1.6kV) 380A Chassis, Stud Mount DO-205AB, DO-9
S380Y 数据手册
S380Y thru S380ZR Silicon Standard Recovery Diode VRRM = 1600 V - 2000 V IF = 380 A Features • High Surge Capability • Types from 1600 V to 2000 V VRRM DO-9 Package • Not ESD Sensitive A C Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. A C Stud Stud (R) 3. Stud is base. Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) S380Y (R) S380Z (R) Unit VRRM 1600 2000 V VRMS 1131 1414 V VDC 1600 2000 V Parameter Symbol Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Conditions Continuous forward current IF TC ≤ 100 °C 380 380 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 6335 6335 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Conditions S380Y (R) S380Z (R) Unit IF = 380 A, Tj = 25 °C VR = 1600 V, Tj = 25 °C VR = 1600 V, Tj = 175 °C 1.2 10 12 1.2 10 12 μA mA 0.16 0.16 °C/W Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol VF IR V Thermal characteristics Thermal resistance, junction case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/s380y.pdf 1 S380Y thru S380ZR Oct. 2018 http://www.diodemodule.com/silicon_products/studs/s380y.pdf 2 S380Y thru S380ZR Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO-9 (DO--205AB) 9(DO205AB) H I F A C B D A C Stud Stud (R) G C E A Oct. 2018 http://www.diodemodule.com/silicon_products/studs/s380y.pdf 3 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: GeneSiC Semiconductor: S380Y
S380Y 价格&库存
很抱歉,暂时无法提供与“S380Y”相匹配的价格&库存,您可以联系我们找货
