MUR160A – MUR190A
Taiwan Semiconductor
1A, 600V - 900V High Efficient Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
High efficiency, low VF
High reliability
175°C operating junction temperature
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
600 - 900
V
IFSM
35
A
TJ MAX
150 - 175
°C
Package
DO-204AL (DO-41)
Configuration
Single die
MECHANICAL DATA
Case: DO-204AL (DO-41)
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.330g (approximately)
DO-204AL (DO-41)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
MUR160A
MUR190A
MUR160A
MUR190A
UNIT
Repetitive peak reverse voltage
VRRM
600
900
V
Reverse voltage, total rms value
VR(RMS)
420
630
V
Forward current
Surge peak forward current, 8.3ms single half
sine wave superimposed on rated load
Junction temperature
IF
1
A
IFSM
35
A
TJ
-55 to +175
-55 to +150
°C
Storage temperature
TSTG
-55 to +175
-55 to +150
°C
1
Version: H2107
MUR160A – MUR190A
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJA
50
°C/W
Junction-to-ambient thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
MUR160A
Forward voltage
MUR190A
(1)
MUR160A
MUR190A
Reverse current @ rated VR
Junction capacitance
Reverse recovery time
IF = 1A, TJ = 25°C
VF
IF = 1A, TJ = 125°C
TJ = 25°C
(2)
IR
TJ = 125°C
MUR160A
MUR190A
MUR160A
MUR190A
SYMBOL
1MHz, VR = 4.0V
CJ
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
trr
TYP
MAX
UNIT
1.25
V
1.70
V
1.05
V
1.50
V
5
µA
150
µA
27
pF
15
pF
50
ns
75
ns
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MUR1xA
DO-204AL (DO-41)
5,000 / Tape & Reel
MUR1xA A0G
DO-204AL (DO-41)
3,000 / Ammo box
MUR1xAH
DO-204AL (DO-41)
5,000 / Tape & Reel
MUR1xAHA0G
DO-204AL (DO-41)
3,000 / Ammo box
Notes:
1. “x” defines voltage from 600V (MUR160A) to 900V (MUR190A)
2. “H” means AEC-Q101 qualified
2
Version: H2107
MUR160A – MUR190A
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
CAPACITANCE (pF)
1
MUR160A
MUR160A
10
MUR190A
MUR190A
50
75
100
125
150
f=1.0MHz
Vsig=50mVp-p
1
175
1
10
LEAD TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
10
1
TJ=100°C
0.1
0.01
TJ=25°C
0.001
40
50
60
70
80
90
100
1010
MUR160A
MUR190A
1
UF1DLW
TJ=100°C
TJ=125°C
TJ=25°C
10.1
TJ=25°C
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.5 0.7 0.9 1.1 1.3 1.5 1.7
0.3
0.4
0.5
0.6
0.7
0.8
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1.9
0.9
2.1
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
40
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.3 Typical Reverse Characteristics
10
100
(A)
AVERAGE FORWARD CURRENT (A)
2
35
8.3ms single half sine wave
30
25
10
5
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: H2107
1.2
MUR160A – MUR190A
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: H2107
MUR160A – MUR190A
PACKAGE OUTLINE DIMENSIONS
DO-204AL (DO-41)
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: H2107
MUR160A – MUR190A
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: H2107
很抱歉,暂时无法提供与“MUR160AHA0G”相匹配的价格&库存,您可以联系我们找货
