TSF30L45C – TSF30L60C
Taiwan Semiconductor
30A, 45V - 60V Trench Schottky Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Low power loss/ high efficiency
High forward surge capability
Compliant RoHS
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
30
A
VRRM
45 - 60
V
IFSM
180
A
TJ MAX
150
°C
Package
ITO-220AB
Configuration
Dual dies
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Mounting torque: 0.56 N⋅m maximum
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TSF30L45C
TSF30L60C
TSF30L45C
TSF30L60C
UNIT
Repetitive peak reverse voltage
VRRM
45
60
V
Reverse voltage, total rms value
VR(RMS)
31
42
V
IF
30
A
IFSM
180
A
dv/dt
10,000
V/µs
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
Forward current
Surge peak forward current, 8.3ms single
half sine-wave superimposed on rated load
Critical rate of rise of off-state voltage
1
Version: F2105
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
4
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TSF30L45C
Forward voltage per diode
(1)
TSF30L60C
IF = 15A, TJ = 25°C
VF
TSF30L45C
TSF30L60C
Reverse current @ rated VR per diode
(2)
IF = 15A, TJ = 125°C
TJ = 25°C
TJ = 125°C
IR
TYP
MAX
UNIT
0.48
0.55
V
0.55
0.62
V
0.46
0.53
V
0.51
0.58
V
500
µA
60
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
TSF30LxC
ITO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 45V(TSF30L45C) to 60V(TSF30L60C)
2
Version: F2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
30
25
CAPACITANCE (pF)
10
1000
100
5
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS REVERSE CURRENT (mA)
INSTANTANEOUS FORWARD CURRENT (A)
100
TJ=150°C
10
TJ=125°C
1
TJ=100°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
100
Fig.4 Typical Forward Characteristics
80
90
100
100 10
TSF30L45C
10
UF1DLW
1
TJ=150°C
TJ=125°C
TJ=125°C
TJ=25°C
0.1
TJ=25°C
1
TJ=100°C
0.01
0.1
0.001
0.0
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.2
0.4
0.5
0.4
0.6
0.7
0.6
0.8
0.9
1
0.8
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
FORWARD VOLTAGE (V)
Fig.5 Typical Reverse Characteristics
Fig.6 Typical Forward Characteristics
100
Fig.3 Typical Reverse Characteristics
TSF30L45C
10
REVERSE VOLTAGE (V)
TJ=150°C
TSF30L60C
10
1
TJ=100°C
0.1
TJ=125°C
0.01
TJ=25°C
0.001
0.0001
10
40
50
60
70
80
90
100
3
(A)
25
1.1
1.2
1.1
1.2
100 10
TSF30L60C
UF1DLW
1
TJ=150°C
10
TJ=125°C
TJ=125°C
TJ=25°C
0.1
TJ=25°C
1
TJ=100°C
0.01
0.1
0.001
0.0
(A)
AVERAGE FORWARD CURRENT (A)
35
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.4
0.2
0.4
0.6
0.5
0.6 VOLTAGE
0.7
0.8
0.9
FORWARD
(V)
1
0.8
Version: F2105
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: F2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: F2105
很抱歉,暂时无法提供与“TSF30L45C C0G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.832901+0.34225
