GBLA005 – GBLA10
Taiwan Semiconductor
4A, 50V - 1000V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
Ideal for printed circuit board
High case dielectric strength
Typical IR less than 0.1μA
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
4
A
VRRM
50 - 1000
V
IFSM
120
A
TJ MAX
150
°C
Package
GBL
Configuration
Quad
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: GBL
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 2.00g (approximately)
GBL
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak reverse voltage
VRRM
Reverse voltage, total rms value
VR(RMS)
35
70
140
280
420
560
700
V
4
A
3
A
IFSM
120
A
It
2
59
As
Junction temperature
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
Forward current
TC = 50°C
GBLA GBLA GBLA GBLA GBLA GBLA GBLA
UNIT
005
01
02
04
06
08
10
005
01
02
04
06
08
10
50
100
200
400
600
800
1000
V
TA = 40°C
Surge peak forward current,
8.3ms single half sine-wave
superimposed on rated load
Rating for fusing (t
很抱歉,暂时无法提供与“GBLA02HD2G”相匹配的价格&库存,您可以联系我们找货
