SRA820 – SRA8150
Taiwan Semiconductor
8A, 20V - 150V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
8
A
VRRM
20 - 150
V
IFSM
150
A
TJ MAX
125, 150
°C
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
Package
TO-220AC
Configuration
Single die
MECHANICAL DATA
Case: TO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.85g (approximately)
TO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak reverse voltage
VRRM
Reverse voltage, total rms value
VR(RMS)
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Critical rate of rise of off-state
voltage
Junction temperature
Storage temperature
SRA SRA SRA SRA SRA SRA SRA SRA
UNIT
820 830 840 850 860 890 8100 8150
820
830
840
850
860
890 8100 8150
40
50
60
90
100
150
V
14
21
28
35
42
63
70
105
V
IF
8
A
IFSM
150
A
dv/dt
10,000
V/µs
TJ
-55 to +125
TSTG
-55 to +150
-55 to +150
1
°C
°C
Version: J2103
SRA820 – SRA8150
THERMAL PERFORMANCE
PARAMETER
Junction-to-case resistance
SYMBOL
TYP
UNIT
RӨJC
4
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
SRA820
SRA830
SRA840
SRA850
SRA860
SRA890
SRA8100
SRA8150
SRA820
SRA830
SRA840
SRA850
SRA860
SRA890
SRA8100
SRA8150
SRA820
SRA830
SRA840
SRA850
SRA860
SRA890
SRA8100
SRA8150
SRA820
SRA830
SRA840
SRA850
SRA860
SRA890
SRA8100
SRA8150
IF = 8A, TJ = 25°C
SYMBOL
VF
TYP
MAX
UNIT
0.55
V
0.70
V
0.85
V
0.95
V
500
µA
100
µA
15
mA
10
mA
mA
mA
5
mA
TJ = 25°C
TJ = 100°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SRA8x
TO-220AC
50 / Tube
SRA8xH
TO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 20V(SRA820) to 150V(SRA8150)
2. “H” means AEC-Q101 qualified
2
Version: J2103
SRA820 – SRA8150
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
SRA850-SRA8150
8
CAPACITANCE (pF)
6
SRA820-SRA840
4
SRA820-SRA860
SRA890-SRA8100
1000
SRA8150
2
f=1.0MHz
Vsig=50mVp-p
100
50
75
100
125
0.1
150
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=75°C
0.01
TJ=25°C
0.001
40
50
60
70
80
90
100
100
10
UF1DLW
SRA850-SRA860
1
10
SRA820-SRA840
TJ=125°C
TJ=25°C
0.1
1
0.01
SRA890-SRA8100
SRA8150
Pulse width 300μs
Pulse width
1% duty cycle
0.1
0.001
0.20.3 0.30.4 0.4
0.5
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.5
0.6
0.6
0.7
0.7
0.8
0.8
0.9
10.9 1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
180
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
TJ=100°C
10
100
Fig.4 Typical Forward Characteristics
10
0.1
10
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
1
1
(A)
AVERAGE FORWARD CURRENT (A)
10
150
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: J2103
1.2
SRA820 – SRA8150
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: J2103
SRA820 – SRA8150
PACKAGE OUTLINE DIMENSIONS
TO-220AC
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: J2103
SRA820 – SRA8150
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: J2103
很抱歉,暂时无法提供与“SRA840HC0G”相匹配的价格&库存,您可以联系我们找货
