HS1AFL – HS1MFL
Taiwan Semiconductor
1A, 50V - 1000V High Efficient Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low profile package
Low power loss, high efficiency
Fast switching for high efficiency
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
50 - 1000
V
IFSM
30
A
TJ MAX
150
°C
Package
SOD-123FL
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: SOD-123FL
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: Indicated by cathode band
Weight: 0.019g (approximately)
SOD-123FL
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the
device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward
current, 8.3ms single half
sine-wave superimposed
on rated load
Junction temperature
Storage temperature
SYMBOL
HS1A HS1B HS1D HS1F HS1G HS1J HS1K HS1M
UNIT
FL
FL
FL
FL
FL
FL
FL
FL
HAF
HBF
HDF
HFF
HGF
HJF
HKF
HMF
VRRM
50
100
200
300
400
600
800
1000
V
VR(RMS)
35
70
140
210
280
420
560
700
V
IF
1
A
IFSM
30
A
TJ
- 55 to +150
°C
TSTG
- 55 to +150
°C
1
Version: B2103
HS1AFL – HS1MFL
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
17
°C/W
Junction-to-ambient thermal resistance
RӨJA
85
°C/W
Junction-to-case thermal resistance
RӨJC
19
°C/W
Thermal Performance Note: Units mounted on PCB (5mm x 5mm Cu pad test board)
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
HS1AFL
HS1BFL
HS1DFL
HS1FFL
Forward voltage
(1)
HS1GFL
TYP
MAX
UNIT
0.82
V
0.89
0.95
V
0.67
V
IF = 1.0A, TJ = 125°C
0.75
0.81
V
IF = 0.5A, TJ = 25°C
0.93
V
1.01
1.30
V
0.74
V
0.85
1.10
V
1.21
V
1.36
1.70
V
0.94
V
1.10
1.38
V
5
µA
150
µA
11
pF
6
pF
50
ns
75
ns
IF = 1.0A, TJ = 25°C
IF = 0.5A, TJ = 125°C
HS1JFL IF = 1.0A, TJ = 25°C
HS1KFL
HS1MFL IF = 0.5A, TJ = 125°C
Reverse current @ rated VR
TJ = 25°C
(2)
Junction capacitance
Reverse recovery time
VF
VF
VF
IR
TJ = 125°C
HS1AFL
HS1BFL
HS1DFL
HS1FFL
HS1GFL
HS1JFL
HS1KFL
HS1MFL
HS1AFL
HS1BFL
HS1DFL
HS1FFL
HS1GFL
HS1JFL
HS1KFL
HS1MFL
SYMBOL
1MHz, VR = 4.0V
IF = 0.5A , IR = 1.0A
Irr = 0.25A
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
HS1xFL
SOD-123FL
10,000 / Tape & Reel
Notes:
1. “x” defines voltage from 50V(HS1AFL) to 1000V(HS1MFL)
2
Version: B2103
HS1AFL – HS1MFL
CHARACTERISTICS CURVES
Fig.2 Typical Junction Capacitance
1.5
100
1
10
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
Fig.1 Forward Current Derating Curve
0.5
HS1AFL - HS1GFL
HS1JFL - HS1MFL
1
f=1.0MHz
Vsig=50mVp-p
25
50
75
100
125
150
1
10
REVERSE VOLTAGE (V)
LEAD TEMPERATURE (°C)
Fig.3 Typical Reverse Characteristics
Fig.4 Typical Forward Characteristics
10
10
HS1AFL - HS1FFL
1
TJ=125°C
0.1
0.01
TJ=25°C
0.001
10HS1AFL - HS1FFL
UF1DLW
1
TJT=125°C
J=125°C
TJ=25°C
0.1
(A)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
100
1
TJ=25°C
0.01
Pulse width
0.001
0.3
0.4
0.5
0.6
Pulse0.9
width 300μs
0.8
1
1.1
1% duty cycle
0.7
0.1
10
40
50
60
70
80
90
100
0.4
0.5
0.6
0.7
0.8
0.9
1
1.1
1.2
1.3
1.4
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
3
Version: B2103
1.2
HS1AFL – HS1MFL
Fig.6 Typical Forward Characteristics
HS1GFL
1
TJ=125°C
0.1
0.01
TJ=25°C
10HS1GFL
UF1DLW
1
TJ=125°C
TJ=125°C
1
TJ=25°C
0.1
TJ=25°C
0.01
Pulse width
0.001
0.3
0.4
0.5
0.6
0.7
Pulse width 300μs
1% duty
0.8
0.9cycle1
1.1
1.2
0.1
0.001
10
40
50
60
70
80
90
100
0.5
0.7
0.9
1.1
1.3
1.5
1.7
FORWARD VOLTAGE (V)
Fig.7 Typical Reverse Characteristics
Fig.8 Typical Forward Characteristics
1.9
10
HS1JFL - HS1MFL
TJ=125°C
10
1
0.1
TJ=25°C
10HS1JFL - HS1MFL
UF1DLW
1
TJ=125°C
TJ=125°C
1
TJ=25°C
0.1
(A)
100
10
(A)
10
Fig.5 Typical Reverse Characteristics
TJ=25°C
0.01
0.7
Pulse width
Pulse width 300μs
1% duty
0.8
0.9cycle1
1.1
1.6
1.8
0.001
0.3
0.4
0.5
0.6
0.1
0.01
10
40
50
60
70
80
90
0.6
100
0.8
1
1.2
1.4
2
2.2
2.4
FORWARD VOLTAGE (V)
4
Version: B2103
1.2
HS1AFL – HS1MFL
PACKAGE OUTLINE DIMENSIONS
SOD-123FL
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
YW
= Date Code
F
= Factory Code
Version: B2103
HS1AFL – HS1MFL
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: B2103
很抱歉,暂时无法提供与“HS1FFL”相匹配的价格&库存,您可以联系我们找货
