SFA1001G – SFA1008G
Taiwan Semiconductor
10A, 50V - 600V Super Fast Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
High efficiency, low VF
High current capability
High reliability
High surge current capability
Low power loss
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
10
A
VRRM
50 - 600
V
IFSM
125
A
TJ MAX
150
°C
Package
TO-220AC
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: TO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.80g (approximately)
TO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the
device
Repetitive peak
reverse voltage
Reverse voltage, total
rms value
Forward current
Surge peak forward
current, 8.3ms single
half sine wave
superimposed on rated
load
Junction temperature
Storage temperature
SYMBOL
SFA
SFA
SFA
SFA
SFA
SFA
SFA
SFA
UNIT
1001G 1002G 1003G 1004G 1005G 1006G 1007G 1008G
SFA
SFA
SFA
SFA
SFA
SFA
SFA
SFA
VRRM
50
100
150
200
300
400
500
600
V
VR(RMS)
35
70
105
140
210
280
350
420
V
IF
10
A
IFSM
125
A
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
1
Version: K2103
SFA1001G – SFA1008G
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
3.5
°C/W
Junction-to-case resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
(1)
Reverse current @ rated VR
(2)
Junction capacitance
Reverse recovery time
CONDITIONS
SFA1001G
SFA1002G
SFA1003G
SFA1004G
I = 10A, TJ = 25°C
SFA1005G F
SFA1006G
SFA1007G
SFA1008G
TJ = 25°C
TJ = 100°C
SFA1001G
SFA1002G
SFA1003G
SFA1004G
1MHz, VR = 4.0V
SFA1005G
SFA1006G
SFA1007G
SFA1008G
IF = 0.5A, IR = 1.0A
Irr = 0.25A
SYMBOL
TYP
MAX
UNIT
0.975
V
1.300
V
1.700
V
10
µA
400
µA
70
pF
50
pF
35
ns
VF
IR
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SFA10xG
TO-220AC
50 / Tube
SFA10xGH
TO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 50V(SFA1001G) to 600V(SFA1008G)
2. “H” means AEC-Q101 qualified
2
Version: K2103
SFA1001G – SFA1008G
CHARACTERISTICS CURVES
Fig.2 Typical Junction Capacitance
12
100
10
90
CAPACITANCE (pF)
8
6
4
2
SFA1001G-1004G
80
70
SFA1005G-1008G
60
50
f=1.0MHz
Vsig=50mVp-p
40
25
50
75
100
125
150
1
10
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=100°C
10
1
TJ=25°C
0.1
30
40
50
60
70
80
90
100
10
100
1
SFA1001G-1004G
UF1DLW
10
TJ=125°C
TJ=25°C
0.1
SFA1005G-1006G
1
0.01
SFA1007G-1008G
Pulse width
300μs
Pulse
width
1% duty cycle
0.001
0.1
0.40.3 0.60.4 0.80.5 1 0.61.2 0.71.4 0.81.6 0.9
1.8 1 2 1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
150
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (uA)
Fig.4 Typical Forward Characteristics
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
100
(A)
AVERAGE FORWARD CURRENT (A)
Fig.1 Forward Current Derating Curve
125
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: K2103
1.2
SFA1001G – SFA1008G
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: K2103
SFA1001G – SFA1008G
PACKAGE OUTLINE DIMENSIONS
TO-220AC
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: K2103
SFA1001G – SFA1008G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: K2103
很抱歉,暂时无法提供与“SFA1001G C0G”相匹配的价格&库存,您可以联系我们找货
