FR301G – FR307G
Taiwan Semiconductor
3A, 50V - 1000V Fast Recovery Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
High current capability, Low VF
High reliability
High surge current capability
Low power loss, high efficiency
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
50 - 1000
V
IFSM
125
A
TJ MAX
150
°C
APPLICATIONS
Package
DO-201AD
Configuration
Single die
● DC to DC converter
● Switching mode converters and inverters
● General purpose
MECHANICAL DATA
Case: DO-201AD
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 1.20g (approximately)
DO-201AD
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the
device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward
current, 8.3ms single half
sine wave superimposed
on rated load
Junction temperature
Storage temperature
FR
301G
FR
301G
FR
302G
FR
302G
FR
303G
FR
303G
FR
304G
FR
304G
FR
305G
FR
305G
FR
306G
FR
306G
VRRM
50
100
200
400
600
800
1000
V
VR(RMS)
35
70
140
280
420
560
700
V
SYMBOL
FR
UNIT
307G
FR
307G
IF
3
A
IFSM
125
A
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
1
Version: H2105
FR301G – FR307G
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
SYMBOL
TYP
UNIT
RӨJA
35
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 3A, TJ = 25°C
TJ = 25°C
(2)
Junction capacitance
Reverse recovery time
SYMBOL
TYP
MAX
UNIT
VF
1.3
V
5
µA
100
µA
30
pF
150
ns
250
ns
500
ns
IR
TJ = 125°C
1MHz, VR = 4.0V
FR301G
FR302G
FR303G
FR304G IF = 0.5A, IR = 1.0A,
I = 0.25A
FR305G rr
FR306G
FR307G
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
FR3xG
DO-201AD
1,250 / Tape & Reel
FR3xG A0G
DO-201AD
500 / Ammo box
FR3xGH
DO-201AD
1,250 / Tape & Reel
FR3xGHA0G
DO-201AD
500 / Ammo box
Notes:
1. "x" defines voltage from 50V (FR301G) to 1000V (FR307G)
2. “H” means AEC-Q101 qualified
2
Version: H2105
FR301G – FR307G
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
3
CAPACITANCE (pF)
2
1
10
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
125
1
150
10
ANBIENT TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
100
TJ=125°C
10
TJ=75°C
1
TJ=25°C
0.1
40
50
60
70
80
90
100
1010
UF1DLW
1
TJ=125°C
TJ=25°C
10.1
0.01
0.1
0.001
0.60.3 0.7 0.40.8 0.5
0.9
Pulse
Pulse width
width 300μs
300μs
1% duty cycle
Pulse width
1
0.6
1.1
0.7 1.20.8 1.3 0.91.4
11.5
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
150
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.3 Typical Reverse Characteristics
10
100
(A)
AVERAGE FORWARD CURRENT (A)
4
8.3ms single half sine wave
125
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: H2105
1.2
FR301G – FR307G
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: H2105
FR301G – FR307G
PACKAGE OUTLINE DIMENSIONS
DO-201AD
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: H2105
FR301G – FR307G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: H2105
很抱歉,暂时无法提供与“FR306G B0G”相匹配的价格&库存,您可以联系我们找货
