MBRF735 – MBRF7150
Taiwan Semiconductor
7.5A, 35V - 150V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for over-voltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
7.5
A
VRRM
35 - 150
V
IFSM
150
A
TJ MAX
150
°C
Package
ITO-220AC
Configuration
Single die
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converter
MECHANICAL DATA
Case: ITO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
MBRF MBRF MBRF MBRF MBRF MBRF MBRF
UNIT
735
745
750
760
790
7100 7150
735
745
750
760
790
7100
7150
35
45
50
60
90
100
150
V
Repetitive peak revers voltage
VRRM
Reverse voltage total rms value
VR(RMS)
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Peak repetitive reverse
(1)
surge current
Peak repetitive forward current
(Rated VR, Square wave,
20KHz)
Critical rate of rise of off-state
voltage
Junction temperature
IF
7.5
A
IFSM
150
A
Storage temperature
IRRM
24
31
35
42
1.0
63
0.5
70
105
V
A
IFRM
15
A
dv/dt
10,000
V/µs
TJ
-55 to +150
°C
TSTG
-55 to +175
°C
Notes:
1. tp = 2.0μs, 1.0KHz
1
Version: K2105
MBRF735 – MBRF7150
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
7
°C/W
Junction-to-case resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
MBRF735
MBRF745
MBRF750
MBRF760
MBRF790
MBRF7100
MBRF7150
MBRF735
MBRF745
MBRF750
MBRF760
MBRF790
MBRF7100
MBRF7150
MBRF735
MBRF745
MBRF750
MBRF760
MBRF790
MBRF7100
MBRF7150
MBRF735
MBRF745
MBRF750
MBRF760
MBRF790
MBRF7100
MBRF7150
MBRF735
MBRF745
MBRF750
MBRF760
MBRF790
MBRF7100
MBRF7150
MBRF735
MBRF745
MBRF750
MBRF760
MBRF790
MBRF7100
MBRF7150
SYMBOL
IF = 7.5A, TJ = 25°C
IF = 15A, TJ = 25°C
VF
IF = 7.5A, TJ = 125°C
IF = 15A, TJ = 125°C
TJ = 25°C
TYP
MAX
UNIT
V
0.75
V
0.92
V
1.02
V
0.84
V
V
V
V
0.57
V
0.65
V
0.82
V
0.92
V
0.72
V
V
V
V
100
µA
15
mA
10
mA
5
mA
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
2
Version: K2105
MBRF735 – MBRF7150
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MBRF7x
ITO-220AC
50 / Tube
MBRF7xH
ITO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 35V(MBRF735) to 150V(MBRF7150)
2. “H” means AEC-Q101 qualified
3
Version: K2105
MBRF735 – MBRF7150
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
MBRF750-7150
MBRF735-745
7.5
CAPACITANCE (pF)
6
4.5
MBRF735-745
3
MBRF750-760
100
MBRF790-7150
1.5
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
10
TJ=125°C
1
TJ=75°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
10
100
Fig.4 Typical Forward Characteristics
100
90
100
100
10
MBRF735-745
MBRF750-760
UF1DLW
1MBRF790-7100
10
TJ=125°C
TJ=125°C
TJ=25°C
0.1
MBRF7150
1
0.01
TJ=25°C
Pulse width 300μs
Pulse width
1% duty cycle
0.001
0.1
0.4 0.40.50.5 0.6
0.70.8 0.8
0.10.3
0.2 0.3
0.6 0.7
0.9
10.9 1.1 11.2 1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
175
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.3 Typical Reverse Characteristics
MBRF735-745
MBRF750-7150
1
REVERSE VOLTAGE (V)
(A)
AVERAGE FORWARD CURRENT (A)
9
150
125
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: K2105
1.2
MBRF735 – MBRF7150
Fig.6 Typical Transient Thermal Characteristics
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: K2105
MBRF735 – MBRF7150
PACKAGE OUTLINE DIMENSIONS
ITO-220AC
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: K2105
MBRF735 – MBRF7150
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: K2105
很抱歉,暂时无法提供与“MBRF760HC0G”相匹配的价格&库存,您可以联系我们找货
