SF2001G – SF2008G
Taiwan Semiconductor
20A, 50V - 600V Super Fast Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
High efficiency, low VF
High current capability
High surge current capability
Low power loss
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
A
VRRM
50 - 600
V
IFSM
150
A
TJ MAX
150
°C
Package
TO-220AB
Configuration
Dual dies
● DC to DC converters
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: TO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.82g (approximately)
TO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
SF
SF
SF
SF
SF
SF
SF
SF
PARAMETER
SYMBOL
UNIT
2001G 2002G 2003G 2004G 2005G 2006G 2007G 2008G
Marking code on the
SF
SF
SF
SF
SF
SF
SF
SF
device
Repetitive peak
VRRM
50
100
150
200
300
400
500
600
V
reverse voltage
Reverse voltage, total
VR(RMS)
35
70
105
140
210
280
350
420
V
rms value
Forward current
IF
A
Surge peak forward
current, 8.3ms single
half sine wave
IFSM
150
A
superimposed on rated
load
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
1
°C
Version: I2104
SF2001G – SF2008G
THERMAL PERFORMANCE
PARAMETER
Junction-to-case thermal resistance
SYMBOL
TYP
UNIT
RӨJC
2.5
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SF2001G
SF2002G
SF2003G
SF2004G
(1)
Forward voltage per diode
I = 10A, TJ = 25°C
SF2005G F
SF2006G
SF2007G
SF2008G
TJ = 25°C
(2)
Reverse current @ rated VR per diode
TJ = 125°C
Junction capacitance per diode
Reverse recovery time
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
SYMBOL
TYP
MAX
UNIT
0.975
V
1.300
V
1.700
V
5
µA
400
µA
CJ
80
pF
trr
35
ns
VF
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SF20xG
TO-220AB
50 / Tube
SF20xGH
TO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 50V(SF2001G) to 600V(SF2008G)
2. “H” means AEC-Q101 qualified
2
Version: I2104
SF2001G – SF2008G
CHARACTERISTICS CURVES
Fig.2 Typical Junction Capacitance
24
100
CAPACITANCE (pF)
16
12
8
4
80
70
60
50
f=1.0MHz
Vsig=50mVp-p
40
25
50
75
100
125
150
1
10
CASE TEMPERATURE (°C)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
10
TJ=100°C
TJ=75°C
TJ=25°C
0.1
10
40
50
60
70
80
90
100
100 10
SF2001G-2004G
1
SF2005G-2006G
UF1DLW
10
TJ=125°C
TJ=25°C
0.1
SF2007G-2008G
1
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.4 0.30.6 0.40.8 0.51.0 0.61.2 0.7
1.4 0.8
1.6 0.9
1.8
2.0
1
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
175
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.3 Typical Reverse Characteristics
1
100
REVERSE VOLTAGE (V)
(A)
AVERAGE FORWARD CURRENT (A)
Fig.1 Forward Current Derating Curve
150
8.3ms single half sine wave
125
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: I2104
1.2
SF2001G – SF2008G
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: I2104
SF2001G – SF2008G
PACKAGE OUTLINE DIMENSIONS
TO-220AB
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: I2104
SF2001G – SF2008G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: I2104
很抱歉,暂时无法提供与“SF2005GHC0G”相匹配的价格&库存,您可以联系我们找货
