TS25P01G – TS25P07G
Taiwan Semiconductor
25A, 50V - 1000V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
Ideal for printed circuit board
Typical IR less than 0.1μA
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
25
A
VRRM
50 - 1000
V
IFSM
350
A
TJ MAX
150
°C
Package
TS-6P
Configuration
Quad
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: TS-6P
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Mounting torque: 0.92 N⋅m maximum
Polarity: As marked
Weight: 7.15g (approximately)
TS-6P
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak reverse voltage
Reverse voltage, total rms
value
Forward current
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load
Rating of fusing (t
很抱歉,暂时无法提供与“TS25P05G C2G”相匹配的价格&库存,您可以联系我们找货
