SR2020PT – SR20150PT
Taiwan Semiconductor
20A, 20V - 150V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
A
VRRM
20 - 150
V
IFSM
200
A
TJ MAX
125, 150
°C
APPLICATIONS
Package
TO-247AD (TO-3P)
Configuration
Dual dies
Switching mode power supply (SMPS)
Adapters
Monitor
DC to DC converters
TV
MECHANICAL DATA
Case: TO-247AD (TO-3P)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Mounting torque: 1.13 N⋅m maximum
Polarity: As marked
Weight: 5.60g (approximately)
TO-247AD (TO-3P)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current
8.3ms single half sine wave
superimposed on rated load
Junction temperature
Storage temperature
SR
SR
SR
SR
SR
SR
SR
SR
SYMBOL 2020 2030 2040 2050 2060 2090 20100 20150 UNIT
PT
PT
PT
PT
PT
PT
PT
PT
SR
SR
SR
SR
SR
SR
SR
SR
PT
PT
PT
PT
PT
PT
PT
PT
VRRM
40
50
60
90
100
150
V
VR(RMS)
14
21
28
35
42
63
70
105
V
IF
A
IFSM
200
A
TJ
-55 to +125
TSTG
-55 to +150
-55 to +150
1
°C
°C
Version: J2103
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
1.5
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per diode
CONDITIONS
(1)
Reverse current @ rated VR
(2)
per diode
SR2020PT
SR2030PT
SR2040PT
SR2050PT
SR2060PT
SR2090PT
SR20100PT
SR20150PT
SR2020PT
SR2030PT
SR2040PT
SR2050PT
SR2060PT
SR2090PT
SR20100PT
SR20150PT
SR2020PT
SR2030PT
SR2040PT
SR2050PT
SR2060PT
SR2090PT
SR20100PT
SR20150PT
SR2020PT
SR2030PT
SR2040PT
SR2050PT
SR2060PT
SR2090PT
SR20100PT
SR20150PT
IF = 10A, TJ = 25°C
SYMBOL
VF
TYP
MAX
UNIT
0.55
V
0.70
V
0.92
V
1.02
V
500
µA
100
µA
15
mA
10
mA
mA
mA
5
mA
TJ = 25°C
TJ = 100°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SR20xPT
TO-247AD (TO-3P)
30 / Tube
SR20xPTH
TO-247AD (TO-3P)
30 / Tube
Notes:
1. “x” defines voltage from 20V(SR2020PT) to 150V(SR20150PT)
2. “H” means ACE-Q101 qualified
2
Version: J2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
SR2050PT-20150PT
CAPACITANCE (pF)
15
SR2020PT-2040PT
10
SR2020PT-2040PT
1000
SR2050PT-2060PT
100
SR2090PT-20150PT
5
f=1.0MHz
Vsig=50mVp-p
10
25
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=100°C
1
0.1
TJ=25°C
0.01
40
50
60
70
80
90
100
100010
SR2090PT-20100PT
100 1
SR2050PT-2060PT
UF1DLW
SR2020PT-2040PT
TJ=125°C
10
0.1
TJ=25°C
1
0.01
SR20150PT
0.1
0.001
0.2
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
0.4
0.4
0.5
0.6
0.6
0.8
0.7
0.8
1.0
0.9
1.2
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
220
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
200
180
160
140
120
100
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
3
(A)
AVERAGE FORWARD CURRENT (A)
25
Version: J2103
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: J2103
PACKAGE OUTLINE DIMENSIONS
TO-247AD (TO-3P)
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: J2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: J2103
很抱歉,暂时无法提供与“SR2040PTHC0G”相匹配的价格&库存,您可以联系我们找货
