UF5JFC
Taiwan Semiconductor
5A, 600V Ultra Fast Rectifier
FEATURES
KEY PARAMETERS
High efficiency, low VF
High current capability
High reliability
High surge current capability
Low power loss
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
5
A
VRRM
600
V
IFSM
55
A
TJ MAX
150
°C
APPLICATIONS
Configuration
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
mm
Case: ITO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 1A whisker test
Polarity: As marked
Weight: 1.80g (approximately)
Single die
ITO-220AC
No
tR
eco
ITO-220AC
en
de
d
Package
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
UF5JFC
UNIT
UF5JFC
Repetitive peak revers voltage
VRRM
600
V
Reverse voltage total rms value
VR(RMS)
420
V
Forward current
Surge peak forward current, 8.3ms single half
sine wave superimposed on rated load
Junction temperature
IF
5
A
IFSM
55
A
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: B2105
UF5JFC
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead resistance
RӨJL
6.3
°C/W
Junction-to-ambient resistance
RӨJA
12
°C/W
Junction-to-case resistance
RӨJC
7.3
°C/W
Thermal Performance Note: Mounted on Heat sink Size of 4"x6"x0.25" Al-Plate
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
CONDITIONS
SYMBOL
IF = 5.0A, TJ = 25°C
(1)
IF = 2.5A, TJ = 125°C
Reverse current @ rated VR
(2)
TJ = 125°C
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
Reverse recovery time
e co
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
1.8
V
1.5
2.8
V
1.1
1.6
V
1.3
2.3
V
30
µA
200
µA
CJ
30
pF
trr
25
ns
VF
IR
mm
Junction capacitance
TJ = 25°C
UNIT
1.3
en
IF = 5.0A, TJ = 125°C
MAX
de
IF = 2.5A, TJ = 25°C
Forward voltage
TYP
d
PARAMETER
ORDERING INFORMATION
PACKAGE
PACKING
UF5JFC
ITO-220AC
50 / Tube
No
tR
ORDERING CODE
2
Version: B2105
UF5JFC
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
5
3
2
10
1
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
125
1
150
LEAD TEMPERATURE (°C)
Fig.4 Typical Forward Characteristics
10
tR
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
10
1
e co
TJ=125°C
INSTANTANEOUS FORWARD CURRENT (A)
10
0.1
100
mm
Fig.3 Typical Reverse Characteristics
1
10
REVERSE VOLTAGE (V)
UF1DLW
TJT=125°C
J=125°C
TJ=25°C
0.1
1
(A)
25
en
INSTANTANEOUS REVERSE CURRENT (µA)
100
d
4
de
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
6
TJ=25°C
0.01
Pulse width
300μs
Pulse
width
1% duty cycle
0.001
0.1
0.30.3 0.50.4 0.7 0.50.9 0.61.1 0.71.3 0.81.5 0.9
1.7
11.9 1.1
No
FORWARD VOLTAGE (V)
3
Version: B2105
1.2
UF5JFC
PACKAGE OUTLINE DIMENSIONS
e co
mm
en
de
d
ITO-220AC
No
tR
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: B2105
UF5JFC
No
tR
e co
mm
en
de
d
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: B2105
很抱歉,暂时无法提供与“UF5JFC C0G”相匹配的价格&库存,您可以联系我们找货
