D2SB10HD2G
D2SB10HD2G
    TAIWANSEMICONDUCTOR(台半)
    SIP4
    BRIDGE RECT 1PHASE 100V 2A GBL
D2SB10HD2G 数据手册
D2SB05 – D2SB80 Taiwan Semiconductor 2A, 50V - 800V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Ideal for printed circuit board High case dielectric strength High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 2 A VRRM 50 - 800 V IFSM 80 A TJ MAX 150 °C Package GBL Configuration Quad ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: GBL Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 2.00g (approximately) GBL ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device D2SB 05 D2SB 10 D2SB 20 D2SB 40 D2SB 60 D2SB UNIT 80 D2SB05 D2SB10 D2SB20 D2SB40 D2SB60 D2SB80 Repetitive peak reverse voltage VRRM 50 100 200 400 600 800 V Reverse voltage, total rms value VR(RMS) 35 70 140 280 420 560 V Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
D2SB10HD2G 价格&库存
很抱歉,暂时无法提供与“D2SB10HD2G”相匹配的价格&库存,您可以联系我们找货
