SRAF1020 – SRAF10150
Taiwan Semiconductor
10A, 20V - 150V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for over-voltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
10
A
VRRM
20 - 150
V
IFSM
200
A
TJ MAX
125, 150
°C
Package
ITO-220AC
Configuration
Single die
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converter
MECHANICAL DATA
Case: ITO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on
the device
Repetitive peak
reverse voltage
Reverse voltage
total rms value
Forward current
Surge peak forward
current, 8.3ms
single half sine wave
superimposed on
rated load
Critical rate of rise
of off-state voltage
Junction
temperature
Storage
temperature
SRAF
1020
SRAF
1020
SRAF
1030
SRAF
1030
SRAF
1040
SRAF
1040
SRAF
1050
SRAF
1050
SRAF
1060
SRAF
1060
VRRM
40
50
60
90
100
150
V
VR(RMS)
14
21
28
35
42
63
70
105
V
SYMBOL
SRAF SRAF SRAF
UNIT
1090 10100 10150
SRAF SRAF SRAF
1090
10100 10150
IF
10
A
IFSM
200
A
dv/dt
10,000
V/µs
TJ
-55 to +125
-55 to +150
TSTG
-55 to +150
1
°C
°C
Version: I2105
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
4
°C/W
Junction-to-case resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
SRAF1020
SRAF1030
SRAF1040
SRAF1050
SRAF1060
SRAF1090
SRAF10100
SRAF10150
SRAF1020
SRAF1030
SRAF1040
SRAF1050
SRAF1060
SRAF1090
SRAF10100
SRAF10150
SRAF1020
SRAF1030
SRAF1040
SRAF1050
SRAF1060
SRAF1090
SRAF10100
SRAF10150
SRAF1020
SRAF1030
SRAF1040
SRAF1050
SRAF1060
SRAF1090
SRAF10100
SRAF10150
IF = 10A, TJ = 25°C
SYMBOL
VF
TYP
MAX
UNIT
0.55
V
0.70
V
0.85
V
0.95
V
500
µA
100
µA
15
mA
10
mA
mA
mA
5
mA
TJ = 25°C
TJ = 100°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SRAF10x
ITO-220AC
50 / Tube
SRAF10xH
ITO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 20V(SRAF1020) to 150V(SRAF10150)
2. “H” means AEC-Q101 qualified
2
Version: I2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
SRAF1050-10150
10
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
12
8
6
SRAF1020-1040
4
SRAF1020-1040
1000
SRAF1050-1060
SRAF1090-10150
2
f=1.0MHz
Vsig=50mVp-p
100
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
1
TJ=25°C
0.01
40
50
60
70
80
90
100
10 10
SRAF1020-1040
1
UF1DLW
TJ=125°C
SRAF1050-1060
TJ=25°C
10.1
(A)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=100°C
SRAF1090-10100
0.01
SRAF10150
0.1
0.001
0.1 0.2 0.3 0.4
0.3
0.4
0.5
Pulse width 300μs
1% duty cycle
Pulse width
0.5
0.6
0.6 0.7 0.8 0.9
1
0.7
0.8
0.9
1
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
220
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
10
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
0.1
10
200
180
160
140
120
100
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: I2105
1.2
Fig.6 Typical Transient Thermal Characteristics
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: I2105
PACKAGE OUTLINE DIMENSIONS
ITO-220AC
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: I2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: I2105
很抱歉,暂时无法提供与“SRAF1020 C0G”相匹配的价格&库存,您可以联系我们找货
