SFAF1601G – SFAF1608G
Taiwan Semiconductor
16A, 50V - 600V Super Fast Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
High efficiency, Low VF
High current capability
High reliability
High surge current capability
Low power loss
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
16
A
VRRM
50 - 600
V
IFSM
200
A
TJ MAX
150
°C
Package
ITO-220AC
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: ITO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on
the device
Repetitive peak
reverse voltage
Reverse voltage
total rms value
Forward current
Surge peak
forward current,
8.3ms single half
sine wave
superimposed on
rated load
Junction
temperature
Storage
temperature
SYMBOL
SFAF SFAF SFAF SFAF SFAF SFAF SFAF SFAF
UNIT
1601G 1602G 1603G 1604G 1605G 1606G 1607G 1608G
SFAF
SFAF
SFAF
SFAF
SFAF
SFAF
SFAF
SFAF
VRRM
50
100
150
200
300
400
500
600
V
VR(RMS)
35
70
105
140
210
280
350
420
V
IF
16
A
IFSM
200
A
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
1
Version: H2105
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
1.3
°C/W
Junction-to-case resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
(1)
Reverse current @ rated VR
(2)
Junction capacitance
Reverse recovery time
CONDITIONS
SFAF1601G
SFAF1602G
SFAF1603G
SFAF1604G
I = 16A, TJ = 25°C
SFAF1605G F
SFAF1606G
SFAF1607G
SFAF1608G
TJ = 25°C
TJ = 100°C
SFAF1601G
SFAF1602G
SFAF1603G
SFAF1604G
1MHz, VR = 4.0V
SFAF1605G
SFAF1606G
SFAF1607G
SFAF1608G
IF = 0.5A, IR = 1.0A
Irr = 0.25A
SYMBOL
TYP
MAX
UNIT
0.975
V
1.300
V
1.700
V
10
µA
400
µA
130
pF
100
pF
35
ns
VF
IR
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SFAF16xG
ITO-220AC
50 / Tube
SFAF16xGH
ITO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 50V(SFAF1601G) to 600V(SFAF1608G)
2. “H” means AEC-Q101 qualified
2
Version: H2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
300
250
16
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
8
4
200
SFAF1601G-1604G
150
SFAF1605G-1608G
100
50
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
150
1
10
CASE TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
TJ=100°C
10
TJ=75°C
1
TJ=25°C
0.1
40
50
60
70
80
90
100
100 10
SFAF1601G-1604G
1
10
UF1DLW
TJ=125°C
TJ=25°C
0.1
(A)
INSTANTANEOUS FORWARD CURRENT (A)
100
SFAF1605G-1606G
1
0.01
SFAF1607G-1608G
Pulse
width
Pulse width
300μs
1% duty cycle
0.001
0.1
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
1.1
0.4 0.6 0.8
1
1.2 1.4 1.6 1.8
2
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
225
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
10
100
200
175
150
125
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: H2105
1.2
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: H2105
PACKAGE OUTLINE DIMENSIONS
ITO-220AC
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: H2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: H2105
很抱歉,暂时无法提供与“SFAF1607G C0G”相匹配的价格&库存,您可以联系我们找货
