TST40L60CW C0G
TST40L60CW C0G
    TAIWANSEMICONDUCTOR(台半)
    TO-220-3
    DIODE SCHOTTKY 60V 20A TO220AB
TST40L60CW C0G 数据手册
TST40L45CW – TST40L60CW Taiwan Semiconductor 40A, 45V - 60V Trench Schottky Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Low power loss/ High efficiency High forward surge capability RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 40 A VRRM 45 - 60 V IFSM 250 A TJ MAX 150 °C APPLICATIONS Package TO-220AB Configuration Dual dies ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 1A whisker test Polarity: As marked Weight: 1.88g (approximately) TO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TST40L45CW TST40L60CW TST40L45CW TST40L60CW UNIT Repetitive peak reverse voltage VRRM 45 60 V Reverse voltage, total rms value VR(RMS) 31 42 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of off-state voltage IF 40 A IFSM 250 A dv/dt 10,000 V/μs Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: C2104 TST40L45CW – TST40L60CW Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 3 °C/W Junction-to-case thermal resistance RӨJC 3 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS TST40L45CW Forward voltage per (1) diode TST40L60CW TST40L45CW TST40L60CW Reverse current @ rated VR per diode (2) SYMBOL IF = 20A, TJ = 25°C VF IF = 20A, TJ = 125°C TJ = 25°C TJ = 125°C IR TYP MAX UNIT 0.49 0.59 V 0.53 0.63 V 0.43 0.53 V 0.47 0.57 V - 500 µA - 100 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING TST40LxCW TO-220AB 50 / Tube Notes: 1. “x” defines voltage from 45V(TST40L45CW) to 60V(TST40L60CW) 2 Version: C2104 TST40L45CW – TST40L60CW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 40 TST40L45CW 35 CAPACITANCE (pF) 30 25 20 15 1000 TST40L60CW 10 f=1.0MHz Vsig=50mVp-p 5 0 100 50 75 100 125 150 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 1000 TST40L45CW TJ=150°C 10 TJ=125°C TJ=100°C 1 0.1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 90 100 100 10 TST40L45CW 10 J 1 TJ=25°C 0.01 0.1 0.001 0.0 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TJ=150°C TJ=125°C TJ=100°C TJ=25°C 0.01 10 20 30 40 50 60 70 80 90 Pulse width 300μs 1% duty cycle Pulse width 0.3 0.1 0.4 0.2 0.5 0.3 0.4 0.6 0.7 0.8 0.5 0.9 0.6 1 1.1 1.2 1.1 1.2 Fig.6 Typical Forward Characteristics TST40L60CW 0.1 T =25°C TJ=100°C J 0.1 FORWARD VOLTAGE (V) 1000 1 TJ=150°C TJ=125°C T =125°C Fig.5 Typical Reverse Characteristics 10 UF1DLW 1 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 100 10 (A) 25 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 10 TST40L60CW 10 1 UF1DLW TJ=150°C TJ=125°C TJ=125°C 0.1 1 0.01 0.1 0.001 0.0 TJ=100°C TJ=25°C (A) AVERAGE FORWARD CURRENT (A) 45 TJ=25°C Pulse width 300μs 1% duty cycle Pulse width 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.3 0.4 0.5 0.6 0.7 0.8 0.9 0.8 1 FORWARD VOLTAGE (V) 3 Version: C2104 TST40L45CW – TST40L60CW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.7 Maximum Non-Repetitive Forward Surge Current PEAK FORWARD SURGE CURRENT (A) 300 250 8.3ms single half sine wave 200 150 100 50 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 Version: C2104 TST40L45CW – TST40L60CW Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AB MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: C2104 TST40L45CW – TST40L60CW Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: C2104
TST40L60CW C0G 价格&库存
很抱歉,暂时无法提供与“TST40L60CW C0G”相匹配的价格&库存,您可以联系我们找货
