HDBLS106G RDG
HDBLS106G RDG
    TAIWANSEMICONDUCTOR(台半)
    SMD4
    BRIDGE RECT 1PHASE 800V 1A DBLS
HDBLS106G RDG 数据手册
HDBLS101G – HDBLS107G Taiwan Semiconductor 1A, 50V - 1000V High Efficient Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Ideal for printed circuit board Reliable low cost construction utilizing molded plastic technique High surge current capability UL Recognized File # E-326854 Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1 A VRRM 50 - 1000 V IFSM 50 A TJ MAX 150 °C Package DBLS Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: DBLS Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.360g (approximately) DBLS ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER HDBLS 101G HDBLS 101G HDBLS 102G HDBLS 102G HDBLS 103G HDBLS 103G HDBLS 104G HDBLS 104G HDBLS 105G HDBLS 105G HDBLS 106G HDBLS 106G VRRM 50 100 200 400 600 800 1000 V VR(RMS) 35 70 140 280 420 560 700 V SYMBOL Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
HDBLS106G RDG 价格&库存
很抱歉,暂时无法提供与“HDBLS106G RDG”相匹配的价格&库存,您可以联系我们找货
