MBRF30L45CT
Taiwan Semiconductor
30A, 45V Low VF Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
30
A
VRRM
45
V
IFSM
220
A
TJ MAX
150
°C
Package
ITO-220AB
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
SYMBOL
PARAMETER
MBRF30L45CT
UNIT
MBRF30L45CT
Marking code on the device
Repetitive peak reverse voltage
VRRM
45
V
Reverse voltage, total rms value
VR(RMS)
31
V
IF
30
A
Forward current
Surge peak forward current, 8.3ms single half sine
wave superimposed on rated load
(1)
Peak repetitive reverse surge current
IFSM
220
A
IRRM
1
A
Critical rate of rise of off-state voltage
dv/dt
10,000
V/µs
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
Notes:
1. tp = 2.0μs, 1.0KHz
1
Version: L2105
MBRF30L45CT
THERMAL PERFORMANCE
PARAMETER
Junction-to-case thermal resistance
SYMBOL
TYP
UNIT
RӨJC
1
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
IF = 15A,TJ = 25°C
Forward voltage per diode
IF = 30A,TJ = 25°C
(1)
IF = 15A,TJ = 125°C
VF
IF = 30A,TJ = 125°C
Reverse current @ rated VR per diode
(2)
TJ = 25°C
TJ = 125°C
IR
TYP
MAX
UNIT
0.55
V
0.74
V
0.50
V
0.67
V
400
µA
200
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
MBRF30L45CT
ITO-220AB
50 / Tube
MBRF30L45CTH
ITO-220AB
50 / Tube
Notes:
1. “H” means AEC-Q101 qualified
2
Version: L2105
MBRF30L45CT
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
30
25
CAPACITANCE (pF)
10
1000
100
5
f=1.0MHz
Vsig=50mVp-p
10
25
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
10
TJ=125°C
1
0.1
TJ=25°C
0.001
10
40
50
60
70
80
100
Fig.4 Typical Forward Characteristics
100
90
100
100 10
10
1
UF1DLW
TJ=125°C
TJ=125°C
TJ=25°C
0.1
TJ=25°C
1
0.01
0.1
0.001
0.1
Pulse width 300μs
1% duty cycle
Pulse width
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.3
0.4
0.5
0.5
0.6
0.7
0.7
0.8
0.9
0.9
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
240
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.3 Typical Reverse Characteristics
0.01
10
REVERSE VOLTAGE (V)
220
200
8.3ms single half sine wave
180
160
140
120
100
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
3
(A)
AVERAGE FORWARD CURRENT (A)
35
Version: L2105
1.2
MBRF30L45CT
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: L2105
MBRF30L45CT
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: L2105
MBRF30L45CT
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: L2105
很抱歉,暂时无法提供与“MBRF30L45CTHC0G”相匹配的价格&库存,您可以联系我们找货
